I am trying to use Eclipse+GCC for my projects. I found a similar issue as stated in the following post:
devzone.nordicsemi.com/.../nan-29-nrf51-sdk-no-project-files
I have downloaded the blinky_example, but my workspace did not have the common makefiles included in the last line of the blinky_example makefiles in the folder:
include $(SDK_PATH)Source/templates/gcc/Makefile.common
Then I found this files in an old release backup and copied them but at the time of building I found the following error
17:18:23 **** Incremental Build of configuration Default for project blinkyEclipse ****
make all
"C:/Program Files (x86)\GNU Tools ARM Embedded\4.7 2013q3/bin/arm-none-eabi-gcc" -L"C:/Program Files (x86)\GNU Tools ARM Embedded\4.7 2013q3/arm-none-eabi/lib/armv6-m" -L"C:/Program Files (x86)\GNU Tools ARM Embedded\4.7 2013q3/lib/gcc/arm-none-eabi/4.7.4/armv6-m" -Xlinker -Map=_build/blinky_gcc.map -mcpu=cortex-m0 -mthumb -mabi=aapcs -L ../../../../Source//templates/gcc/ -Tgcc_nrf51_blank.ld _build/main.o _build/nrf_delay.o _build/system_nrf51.o _build/gcc_startup_nrf51.o -o _build/blinky_gcc.out
c:/program files (x86)/gnu tools arm embedded/4.7 2013q3/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/bin/ld.exe: cannot find -lcs3
c:/program files (x86)/gnu tools arm embedded/4.7 2013q3/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/bin/ld.exe: cannot find -lcs3unhosted
collect2.exe: error: ld returned 1 exit status
make: *** [_build/blinky_gcc.out] Error 1
17:18:24 Build Finished (took 947ms)
lcs3unhosted and lcs3 libraries are missing. I suppose this is because these common makfiles are using Sourcery CodeBench package(nAN-29 v1.0) and not GNU Tools for ARM Embedded Processors package(nAN-29 v1.1). I have not found in the last SDKs or in the Nordic website a workspace to work with the nAN-29 v1.1 or at least the common makefiles. It would be great if someone from Nordic can shed some light into this issue and upload the right workspace/files.
Thanks.
