Handling time out for lte_lc_connect_async
I want to set and catch a timeout event when connecting async to LTE, but I fail to see how this would work.
For lte_lc_connect this is clear:
But for the async variant lte_lc_connect_async , the CONFIG_LTE_NETWORK_TIMEOUT doesn't seem to be used in lte_lc.c.
in lte_connect(false):
	err = lte_lc_func_mode_set(LTE_LC_FUNC_MODE_NORMAL);
	if (err || !blocking) {
		goto exit; // Exit when non-blocking and never using the timeout value
	err = k_sem_take(&link, K_SECONDS(CONFIG_LTE_NETWORK_TIMEOUT));
	if (err == -EAGAIN) {
		LOG_INF("Network connection attempt timed out");
  • Is it possible to LTE_NETWORK_TIMEOUT for lte_lc_connect_async?
    • If so, how?
  • If not, what would be the best solution to avoid the device to search forever?
    • We started from asset tracker v2 app which has a dedicated modem_module thread, so we could switch to a sync blocking call for the network connection?
    • Or implement or own timeout timer on top of the existing code
Thanks in advance!
