I want to enable both spi and iic simultaneously on 52840
我在prj.conf中我同时开启如上图中的两个宏,但是发现编译报错如下所示
You must disable CONFIG_I2C and/or CONFIG_SPI to use the NRF_TWIM1 and NRF_SPIM1 instances in your application.
Please note that the same instance(s) cannot be used simultaneously, meaning that you must de-init SPIM1 before initing TWIM1.
If at all possible, I would recommend that you use SPIM1 + TWIM2 instead.
Håkon
OK thanks i have solve the problem as you said, thanks
Glad to hear that you got it working.
Hope you have a wonderful day!
Håkon
