Update from nRF5 SDK to nRF Connect SDK
For a month I have been trying to find a solution to update my devices which are at my customers (these devices have a bootloader, softdevice and app coming from the nrf5 SDK) to the mcuboot and app coming from the NCS SDK.
To do this, I relied on this link: https://devzone.nordicsemi.com/f/nordic-q-a/79571/dfu-update-from-nrf5-sdk-to-nrf-connect-sdk
Here are my steps:
  1. I modified the secure_bootloader_uart_mbr_pca10056_debug of the nrf5 SDK so that it accepts replacing the sofdevice and the app (nrf5 SDK) with my new app (NCS SDK):
    - comments "return NRF_ERROR_INTERNAL" in the sd_activate() function of the nrf_bootloader_fw_activation.c file
    - comments "result = false;" of the if(SD_MAGIC_NUMBER_GET(sd_start_addr) of the softdevice_info_ok(...) function of the nrf_dfu_validation.c file
  2. I created a file containing this bootloader patched with the softdevice and my app (nrf5 SDK):
    nrfutil settings generate --family NRF52840 --application BT840-FW-0.1.0.12.hex --application-version-string "1.0.12" --bootloader-version 3 --bl-settings-version 2 --softdevice BT840- SD-0.7.2.0.hex --key-file priv.pem bootloader_setting.hex
    mergehex --merge bootloader_setting.hex BT840-BL-0.3.hex --output boot_with_settings.hex
    mergehex --merge boot_with_settings.hex BT840-SD-0.7.2.0.hex --output boot_with_settingsAndSofdevice.hex
    mergehex --merge boot_with_settingsAndSofdevice.hex BT840-FW-0.1.0.12.hex --output firmware-BT840-HW3-SD7_2_0-BOOT3-FW1_0_12.hex
  3. I uploaded this file to my nrf52840
  4. To generate the update packages for the bootloader (MCUboot) and my app from the NCS SDK, I did this:
    nrfutile pkg generate --hw-version 3 --app-boot-validation VALIDATE_GENERATED_CRC --bootloader-version 4 --sd-req 0x0,0xCA,0x0100,0x0101 --bootloader Application/TA_Smart/mcuboot/zephyr/zephyr.hex - -key-file Application/child_image/key/mcuboot_private.pem BT840_update_with_boot.zip
    nrfuutil pkg generate --hw-version 3 --app-boot-validation VALIDATE_GENERATED_CRC --sd-req 0x0,0xCA,0x0100,0x0101 --softdevice Application/TA_Smart/zephyr/app_update.bin --key-file Application/child_image/ key/mcuboot_private.pem BT840_update_with_app.zip
  5. I send the DFU update of the softdevice
  6. Once it is finished, I send the bootloader DFU update
Here are the logs of these 2 updates:
 Test_update_to_new_sdk.log
Here is the memory map of my devices working with the nrf5 SDK:
mbr: 0x0 -> 0x1000
softdevice: 0x1000 -> 0x27000
app: 0x27000 -> 0xD0000 --------> the application uses BLE and Thread
storage: 0xD0000 -> 0xD1000
unused page: 0xD1000 + 0xE0000
ot_flash_data: 0xE0000 -> 0xE4000
bootloader: 0xE4000 -> 0xF0000
unused_page2: 0xF0000 -> 0xFE000
mbr_params_page: 0xFE000 -> 0xFF000
bootloader_settings_page: 0xFF000 -> 0x100000
Here is the content of my pm_static.yml from my project using the NCS SDK:
mbr:
  address: 0x0
  region: flash_primary
app:
  address: 0x1200
mcuboot:
  address: 0xE4000
  placement:
    after:
    - mcuboot_secondary
mcuboot_pad:
  address: 0x1000
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x1000
  orig_span: &id001
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x1200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0xD2000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
settings_storage:
  address: 0xE2000
  placement:
    before:
    - mcuboot
mbr_params_page:
  address: 0xFE000
  address: 0xFF000
sram_primary:
  address: 0x20000000
  region: sram_primary
Additional information:
  • After updating the softdevice (step 5), my file was written between address 0x1000 and address 0xC11DF (thus overwriting the old softdevice and app). On the other hand, in the logs, I see "<debug> nrf_dfu_validation: Hash verification. start address: 0x27000, size: 0x9A1D4": is it normal that it says "0x27000" and not "0x1000"?
  • If after this update, I send the bootloader (step 6), it also writes the file at address 0x1000 and not at address 0xE4000: do you know why?
  • If I update the bootloader before the softdevice, I see in the logs that it starts writing from address 0x99000 (in the logs and physically): why is it at this address?
  • It's obvious but of course, my project using the NCS SDK works when I use it with the immutable bootloader + MCUboot + app
Once I updated my device to MCUboot and the app from the NCS SDK, I no longer see anything in the RTT logs and I can't see which instruction the nrf52840 is stuck on.
Do you have any idea where the problem could be coming from?
Thank you
  • Thank you for your explanation.
    Ah I thought when I saw the image that we had to send an update of the app with a file which contains the NCS App and MCUboot. So you should instead do a combined update of the softdevice+bootloader (in which the softdevice update file will contain the NCS app and the bootloader update file will contain the MCUboot)?
    Can we send the softdevice and after the next reboot to send the bootloader or must both be written at the same time?
    Does this solution require you to first go through a patched bootlaoder?
  • Ah I thought when I saw the image that we had to send an update of the app with a file which contains the NCS App and MCUboot. So you should instead do a combined update of the softdevice+bootloader (in which the softdevice update file will contain the NCS app and the bootloader update file will contain the MCUboot)?
    Correct.
    They must be written at the same time.
    You can include the Softdevice info structure in the zephyr app to trick the bootloader into thinking it is a valid Softdevice. See the example attached to my other devzone post for how you can include this structure.
  • Hi Vidar,
    Thank you very much for your help: I have made a lot of progress :)
    But here I still have a problem: the file that I am trying to write is not completely written in memory (the end of the file is missing) although according to the logs everything was written correctly.
    Just to check that there is no problem in the bootloader code for writing large files, I tested what it would do if I had only updated the application by filling almost all the "app" partition. For this, I wrote from address 0x27000 to address 0xC2C3B (size=0x9BC3B) and everything was written correctly.
    If I now send my file containing the NCS App + MCUboot to overwrite the softdevice (file of 0xA9E80 bytes), it writes in flash from the address 0x1000 to an address around the address 0x7EB00 (I say "around" since if I change the delay between sending 2 frames to the bootloader, the last written address changes (but not much)) whereas it should go up to address 0xAAE80.
    Here is the memory map of my nrf52840 before the update:
    • mbr: 0x0 -> 0x1000
    • softdevice: 0x1000 -> 0x26000
    • app: 0x27000 -> 0xD0000 (0xA9000) -> in reality my app goes from 0x27000 to 0x98CEB
    • storage: 0xD0000 -> 0xD1000
    • unused page: 0xd1000 -> 0xe0000
    • ot_flash_data: 0xe0000 -> 0xe4000
    • bootloader: 0xE4000 -> 0xF0000
    • unused_page2: 0xF0000 -> 0xFE000
    • mbr_params_page: 0xFE000 -> 0xFF000
    • bootloader_settings_page: 0xFF000 -> 0x100000
    Here are the bootloader logs during the update:
    Test_BT840_V0.1.0.12.log
    I'm trying to send these files:
    sd_bl.bin
    sd_bl.dat
    This file was built from these 2 files:
    app_signed.hex 1411.zephyr.hex
    Remarks:
    • We see that physically, the update overwrites in flash the softdevice and part of the NRF5 application with part of the NCS SDK application. On the other hand, we see this in the logs:
      <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027000, src=0x200046A0, len=64 bytes), queue usage: 1
      <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000D0E40, src=0x2000461C, len=64 bytes), queue usage: 1
      Why is it indicated "0x27000" as the starting address and not 0x1000 because physically that is where it is written? Isn't the problem I'm having related to this?
    • I can write the entire "app" partition if I don't start writing by starting at the address of the softdevice so we already know that there is no problem writing in flash for large files and no problem writing to addresses where I have a problem.
    • In the logs, all the writes are marked as "success" but in reality, rereading the flash, I see that the end is not saved, do you have any idea?
  • If I flash the app_signed.hex and zephyr.hex file to my nrf52840, I have these logs:
    00> *** Booting nRF Connect SDK v2.5.0 ***
    00> [00:00:00.000,213] <inf> mcuboot: Starting bootloader
    00> [00:00:00.000,701] <wrn> mcuboot: Cannot upgrade: not a compatible amount of sectors
    00> [00:00:10.572,021] <inf> mcuboot: Bootloader chainload address offset: 0x1000
    00> [00:00:10.572,021] <inf> mcuboot: Jumping to the first image slot
    00> [00:00:10.572,052] <err> mcuboot: Protect mcuboot flash failed, cancel startup.
    Do you know what can cause this kind of problem?
    For this error:
    Try to build mcuboot with CONFIG_FPROTECT=n. I recall there were some issues with the flash protection mechanism after relocating the bootloader to the end of flash (in nRF Connect SDK the bootloader starts at the beginning of flash).
    This suggests that the MCUBoot secondary slot is not allocated in flash. Please run the "memory report" action in VS code and post the flash partition layout here.
    Vidar
