Update from nRF5 SDK to nRF Connect SDK
For a month I have been trying to find a solution to update my devices which are at my customers (these devices have a bootloader, softdevice and app coming from the nrf5 SDK) to the mcuboot and app coming from the NCS SDK.
To do this, I relied on this link: https://devzone.nordicsemi.com/f/nordic-q-a/79571/dfu-update-from-nrf5-sdk-to-nrf-connect-sdk
Here are my steps:
  1. I modified the secure_bootloader_uart_mbr_pca10056_debug of the nrf5 SDK so that it accepts replacing the sofdevice and the app (nrf5 SDK) with my new app (NCS SDK):
    - comments "return NRF_ERROR_INTERNAL" in the sd_activate() function of the nrf_bootloader_fw_activation.c file
    - comments "result = false;" of the if(SD_MAGIC_NUMBER_GET(sd_start_addr) of the softdevice_info_ok(...) function of the nrf_dfu_validation.c file
  2. I created a file containing this bootloader patched with the softdevice and my app (nrf5 SDK):
    nrfutil settings generate --family NRF52840 --application BT840-FW-0.1.0.12.hex --application-version-string "1.0.12" --bootloader-version 3 --bl-settings-version 2 --softdevice BT840- SD-0.7.2.0.hex --key-file priv.pem bootloader_setting.hex
    mergehex --merge bootloader_setting.hex BT840-BL-0.3.hex --output boot_with_settings.hex
    mergehex --merge boot_with_settings.hex BT840-SD-0.7.2.0.hex --output boot_with_settingsAndSofdevice.hex
    mergehex --merge boot_with_settingsAndSofdevice.hex BT840-FW-0.1.0.12.hex --output firmware-BT840-HW3-SD7_2_0-BOOT3-FW1_0_12.hex
  3. I uploaded this file to my nrf52840
  4. To generate the update packages for the bootloader (MCUboot) and my app from the NCS SDK, I did this:
    nrfutile pkg generate --hw-version 3 --app-boot-validation VALIDATE_GENERATED_CRC --bootloader-version 4 --sd-req 0x0,0xCA,0x0100,0x0101 --bootloader Application/TA_Smart/mcuboot/zephyr/zephyr.hex - -key-file Application/child_image/key/mcuboot_private.pem BT840_update_with_boot.zip
    nrfuutil pkg generate --hw-version 3 --app-boot-validation VALIDATE_GENERATED_CRC --sd-req 0x0,0xCA,0x0100,0x0101 --softdevice Application/TA_Smart/zephyr/app_update.bin --key-file Application/child_image/ key/mcuboot_private.pem BT840_update_with_app.zip
  5. I send the DFU update of the softdevice
  6. Once it is finished, I send the bootloader DFU update
Here are the logs of these 2 updates:
 Test_update_to_new_sdk.log
Here is the memory map of my devices working with the nrf5 SDK:
mbr: 0x0 -> 0x1000
softdevice: 0x1000 -> 0x27000
app: 0x27000 -> 0xD0000 --------> the application uses BLE and Thread
storage: 0xD0000 -> 0xD1000
unused page: 0xD1000 + 0xE0000
ot_flash_data: 0xE0000 -> 0xE4000
bootloader: 0xE4000 -> 0xF0000
unused_page2: 0xF0000 -> 0xFE000
mbr_params_page: 0xFE000 -> 0xFF000
bootloader_settings_page: 0xFF000 -> 0x100000
Here is the content of my pm_static.yml from my project using the NCS SDK:
mbr:
  address: 0x0
  region: flash_primary
app:
  address: 0x1200
mcuboot:
  address: 0xE4000
  placement:
    after:
    - mcuboot_secondary
mcuboot_pad:
  address: 0x1000
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x1000
  orig_span: &id001
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x1200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0xD2000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
settings_storage:
  address: 0xE2000
  placement:
    before:
    - mcuboot
mbr_params_page:
  address: 0xFE000
  address: 0xFF000
sram_primary:
  address: 0x20000000
  region: sram_primary
Additional information:
  • After updating the softdevice (step 5), my file was written between address 0x1000 and address 0xC11DF (thus overwriting the old softdevice and app). On the other hand, in the logs, I see "<debug> nrf_dfu_validation: Hash verification. start address: 0x27000, size: 0x9A1D4": is it normal that it says "0x27000" and not "0x1000"?
  • If after this update, I send the bootloader (step 6), it also writes the file at address 0x1000 and not at address 0xE4000: do you know why?
  • If I update the bootloader before the softdevice, I see in the logs that it starts writing from address 0x99000 (in the logs and physically): why is it at this address?
  • It's obvious but of course, my project using the NCS SDK works when I use it with the immutable bootloader + MCUboot + app
Once I updated my device to MCUboot and the app from the NCS SDK, I no longer see anything in the RTT logs and I can't see which instruction the nrf52840 is stuck on.
Do you have any idea where the problem could be coming from?
Thank you
