Update from nRF5 SDK to nRF Connect SDK
For a month I have been trying to find a solution to update my devices which are at my customers (these devices have a bootloader, softdevice and app coming from the nrf5 SDK) to the mcuboot and app coming from the NCS SDK.
To do this, I relied on this link: https://devzone.nordicsemi.com/f/nordic-q-a/79571/dfu-update-from-nrf5-sdk-to-nrf-connect-sdk
Here are my steps:
  1. I modified the secure_bootloader_uart_mbr_pca10056_debug of the nrf5 SDK so that it accepts replacing the sofdevice and the app (nrf5 SDK) with my new app (NCS SDK):
    - comments "return NRF_ERROR_INTERNAL" in the sd_activate() function of the nrf_bootloader_fw_activation.c file
    - comments "result = false;" of the if(SD_MAGIC_NUMBER_GET(sd_start_addr) of the softdevice_info_ok(...) function of the nrf_dfu_validation.c file
  2. I created a file containing this bootloader patched with the softdevice and my app (nrf5 SDK):
    nrfutil settings generate --family NRF52840 --application BT840-FW-0.1.0.12.hex --application-version-string "1.0.12" --bootloader-version 3 --bl-settings-version 2 --softdevice BT840- SD-0.7.2.0.hex --key-file priv.pem bootloader_setting.hex
    mergehex --merge bootloader_setting.hex BT840-BL-0.3.hex --output boot_with_settings.hex
    mergehex --merge boot_with_settings.hex BT840-SD-0.7.2.0.hex --output boot_with_settingsAndSofdevice.hex
    mergehex --merge boot_with_settingsAndSofdevice.hex BT840-FW-0.1.0.12.hex --output firmware-BT840-HW3-SD7_2_0-BOOT3-FW1_0_12.hex
  3. I uploaded this file to my nrf52840
  4. To generate the update packages for the bootloader (MCUboot) and my app from the NCS SDK, I did this:
    nrfutile pkg generate --hw-version 3 --app-boot-validation VALIDATE_GENERATED_CRC --bootloader-version 4 --sd-req 0x0,0xCA,0x0100,0x0101 --bootloader Application/TA_Smart/mcuboot/zephyr/zephyr.hex - -key-file Application/child_image/key/mcuboot_private.pem BT840_update_with_boot.zip
    nrfuutil pkg generate --hw-version 3 --app-boot-validation VALIDATE_GENERATED_CRC --sd-req 0x0,0xCA,0x0100,0x0101 --softdevice Application/TA_Smart/zephyr/app_update.bin --key-file Application/child_image/ key/mcuboot_private.pem BT840_update_with_app.zip
  5. I send the DFU update of the softdevice
  6. Once it is finished, I send the bootloader DFU update
Here are the logs of these 2 updates:
 Test_update_to_new_sdk.log
Here is the memory map of my devices working with the nrf5 SDK:
mbr: 0x0 -> 0x1000
softdevice: 0x1000 -> 0x27000
app: 0x27000 -> 0xD0000 --------> the application uses BLE and Thread
storage: 0xD0000 -> 0xD1000
unused page: 0xD1000 + 0xE0000
ot_flash_data: 0xE0000 -> 0xE4000
bootloader: 0xE4000 -> 0xF0000
unused_page2: 0xF0000 -> 0xFE000
mbr_params_page: 0xFE000 -> 0xFF000
bootloader_settings_page: 0xFF000 -> 0x100000
Here is the content of my pm_static.yml from my project using the NCS SDK:
mbr:
  address: 0x0
  region: flash_primary
app:
  address: 0x1200
mcuboot:
  address: 0xE4000
  placement:
    after:
    - mcuboot_secondary
mcuboot_pad:
  address: 0x1000
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x1000
  orig_span: &id001
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x1200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0xD2000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
settings_storage:
  address: 0xE2000
  placement:
    before:
    - mcuboot
mbr_params_page:
  address: 0xFE000
  address: 0xFF000
sram_primary:
  address: 0x20000000
  region: sram_primary
Additional information:
  • After updating the softdevice (step 5), my file was written between address 0x1000 and address 0xC11DF (thus overwriting the old softdevice and app). On the other hand, in the logs, I see "<debug> nrf_dfu_validation: Hash verification. start address: 0x27000, size: 0x9A1D4": is it normal that it says "0x27000" and not "0x1000"?
  • If after this update, I send the bootloader (step 6), it also writes the file at address 0x1000 and not at address 0xE4000: do you know why?
  • If I update the bootloader before the softdevice, I see in the logs that it starts writing from address 0x99000 (in the logs and physically): why is it at this address?
  • It's obvious but of course, my project using the NCS SDK works when I use it with the immutable bootloader + MCUboot + app
Once I updated my device to MCUboot and the app from the NCS SDK, I no longer see anything in the RTT logs and I can't see which instruction the nrf52840 is stuck on.
Do you have any idea where the problem could be coming from?
Thank you
  • I'm glad to hear you were able to identify the problem. Thank you for the update. However, if the target was unexpectedly reset, I would still have expected the activation process to continue on the next reboot assuming the DFU process was completed.
  • Apparently, if the reboot is done during the copy phase, it no longer continues the update.
    With this solution, is it still possible to update the bootloader once the memory has been overwritten by the MCUboot+app?
    What phase is this, is it after the zephyr app + mcuboot bootloader has been uploaded and when the images are being copied from bank 0 to their destinations?
    The original bootloader will be replaced by the MCUBoot bootloader if the update was completed, and this bootloader is not upgradable.
  • After the file was written to nrf52840 at address 0x27000, I had a reboot during the phase of copying the fisrt part of the file to the app partition (0x1000).
    In fact, if there was a restart during the copy, afther the restart it goes into the postvalidate_sd_bl() function and since softdevice_info_ok(...) returns false (SD_MAGIC_NUMBER_GET(sd_start_addr) != SD_MAGIC_NUMBER) because the address does not is no longer the right one.
    To continue to be able to update the bootlaoder, what more should I do?
  • It appears that the problem arises in the nrf_bootloader_fw_activate() function, where SD_MAGIC_NUMBER_GET() is checked:
    00> <debug> app: Enter nrf_bootloader_fw_activate
    00> <debug> app: Valid SD + BL
    00> <debug> app: Enter nrf_dfu_sd_bl_continue
    00> <debug> app: Enter nrf_bootloader_dfu_sd_continue
    00> <error> app: Source address does not contain a valid SoftDevice.
    00> <error> app: SD+BL: SD copy failed
    This is after the sd+bl image has been postvalidated. What doesn't make sense is why the bootloader fails to read the magic number in nrf_bootloader_dfu_sd_continue(). To debug this further, it would help if you could print the 'src_addr' before the SD_MAGIC_NUMBER_GET() check.
