I am migrating a project to NRF Connect SDK and an having an issue changing the RX/TX pins so that I can talk to s different device via same UART instance.
On previous SDK, this was quite simple and worked fine using nrf_libuarte_async_uninit(&libuarte);
However with NRF Connect SDK (I'm using 2.4.0), it is more complex. I have looked at the documentation here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/hardware/pinctrl/index.html#
And also posts such as:
How to switch uart pins while runtime using pinctrl (Zephyr) (nrf52832) ?
However, I am still unable to progress.
One issue is that when I try and define additional pinctrl states as per docs:
periph0: periph@0 { ... /* state 0 ("default") */ pinctrl-0 = <...>; ... /* state N ("mystate") */ pinctrl-N = <...>; /* names for state 0 up to state N */ pinctrl-names = "default", ..., "mystate"; ... };
I get compilation errors.
For example the following works:
modem_uart: &uart1 { status = "okay"; current-speed = <115200>; // pinctrl-0 = <&uart1_default_alt>; // pinctrl-1 = <&uart1_sleep_alt>; pinctrl-0 = <&uart1_default>; pinctrl-1 = <&uart1_sleep>; pinctrl-names = "default","sleep"; //pinctrl-names = "default-alt","sleep-alt","default","sleep"; }; &pinctrl { compatible = "nordic,nrf-pinctrl"; uart1_default_alt: uart1_default_alt { group1 { psels = <NRF_PSEL(UART_RX, 0, 30)>, <NRF_PSEL(UART_TX, 0, 31)>; }; }; uart1_sleep_alt: uart1_sleep_alt { group1 { psels = <NRF_PSEL(UART_RX, 0, 30)>, <NRF_PSEL(UART_TX, 0, 31)>; }; }; uart1_default: uart1_default { group1 { psels = <NRF_PSEL(UART_RX, 0, 8)>, <NRF_PSEL(UART_TX, 0, 7)>; }; }; uart1_sleep: uart1_sleep { group1 { psels = <NRF_PSEL(UART_RX, 0, 8)>, <NRF_PSEL(UART_TX, 0, 7)>; }; }; };
But if I try and add two more pinctrl states, the code no longer compiles:
modem_uart: &uart1 { status = "okay"; current-speed = <115200>; pinctrl-0 = <&uart1_default_alt>; pinctrl-1 = <&uart1_sleep_alt>; pinctrl-2 = <&uart1_default>; pinctrl-3 = <&uart1_sleep>; //pinctrl-names = "default","sleep"; pinctrl-names = "default-alt","sleep-alt","default","sleep"; }; &pinctrl { compatible = "nordic,nrf-pinctrl"; uart1_default_alt: uart1_default_alt { group1 { psels = <NRF_PSEL(UART_RX, 0, 30)>, <NRF_PSEL(UART_TX, 0, 31)>; }; }; uart1_sleep_alt: uart1_sleep_alt { group1 { psels = <NRF_PSEL(UART_RX, 0, 30)>, <NRF_PSEL(UART_TX, 0, 31)>; }; }; uart1_default: uart1_default { group1 { psels = <NRF_PSEL(UART_RX, 0, 8)>, <NRF_PSEL(UART_TX, 0, 7)>; }; }; uart1_sleep: uart1_sleep { group1 { psels = <NRF_PSEL(UART_RX, 0, 8)>, <NRF_PSEL(UART_TX, 0, 7)>; }; }; };
The error is:
/opt/nordic/ncs/v2.4.0/zephyr/include/zephyr/drivers/pinctrl.h:93:17: error: 'PINCTRL_STATE_DEFAULT_ALT' undeclared here (not in a function);
I have also tried using groups which compiles OK but unfortunately, only the last group is ever referenced - this seems to be a known limitation.
My plan (if I can get more than two states to work) is use the pause/resume approach:
// Suspend UART pm_device_action_run(modem_uart, PM_DEVICE_ACTION_SUSPEND); // Select state > 1U which hopefully maps to my new pin configs pinctrl_apply_state(config->pcfg, PINCTRL_STATE_PRIV_START); // Resume UART pm_device_action_run(modem_uart, PM_DEVICE_ACTION_RESUME);
Any help would be appreciated as I am out of ideas...
Nick
