nrf52810 lower power consumption
I am developing a low power Bluetooth device based on the nrf52810. The firmware is simple, the device powers up and advertises. Once connected, a timer is started which reads from an accelerometer every second using TWI. If this value changes outside of a certain range, a notification is sent to the central device. Once disconnected, the accelerometer is shut down and the device begins advertising again. With my current code, I get around 24uA when advertising, and 50uA when connected. The accelerometer is responsible for around 10uA of current while connected, so the chip is using around 40uA. I am curious if there is a good way to lower both these values further. The device is powered from a 50mah LIR2032 battery, so I get a little over a month of use currently, but I would like this to be longer. I will post my code here as well. Thank you for any assistance you can provide.
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "boards.h"
#include "app_timer.h"
#include "app_button.h"
#include "ble_lbs.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "ble_bas.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_clock.h"
#define TWI_INSTANCE_ID     0
//---ACC Addresses---
#define KXTJ3_COMM_OK            (0)
#define KXTJ3_COMM_ERROR         (-1)
#define KXTJ3_WAI_ERROR          (-2)
#define KXTJ3_PARAM_ERROR        (-3)
#define KXTJ3_DEVICE_ADDRESS     (0x0E)
#define KXTJ3_XOUT_L             (0x06)
#define KXTJ3_YOUT_L             (0x08)
#define KXTJ3_ZOUT_L             (0x0A)
#define KXTJ3_XOUT_H             (0x07)
#define KXTJ3_YOUT_H             (0x09)
#define KXTJ3_ZOUT_H             (0x0B)
#define KXTJ3_WHO_AM_I           (0x0F)
#define KXTJ3_CNTL1              (0x1B)
#define KXTJ3_DATA_CNTL          (0x21)
#define KXTJ3_WAI_VAL            (0x35)
#define KXTJ3_CNTL1_WUFE         (1 << 1)
#define KXTJ3_CNTL1_TDTE         (1 << 2)
#define KXTJ3_CNTL1_EN16GMASK    (0x04)
#define KXTJ3_CNTL1_GSEL_16G     (0x04)
#define KXTJ3_CNTL1_GSELMASK     (0x18)
#define KXTJ3_CNTL1_GSEL_14BIT   (0x18)
#define KXTJ3_CNTL1_GSEL_2G      (0x00)
#define KXTJ3_CNTL1_GSEL_4G      (0x08)
#define KXTJ3_CNTL1_GSEL_8G      (0x10)
#define KXTJ3_CNTL1_DRDYE        (1 << 5)
#define KXTJ3_CNTL1_RES          (1 << 6)
#define KXTJ3_CNTL1_LOWPOWER     (0x00)
#define KXTJ3_CNTL1_HIGHRESO     (0x40)
#define KXTJ3_CNTL1_PC1          (1 << 7)
#define KXTJ3_DATA_CNTL_OSA_50HZ (2)
#define KXTJ3_CNTL1_VAL          (KXTJ3_CNTL1_LOWPOWER | KXTJ3_CNTL1_GSEL_2G)
#define KXTJ3_DATA_CNTL_VAL      (KXTJ3_DATA_CNTL_OSA_50HZ)
#define KXTJ3_DRIVER_VERSION     ("1.0\n")
#define KXTJ3_GSENS_2G           (2)
#define KXTJ3_GSENS_4G           (4)
#define KXTJ3_GSENS_8G           (8)
#define KXTJ3_GSENS_16G          (16)
#define KXTJ3_GSENS_ERROR        (0xFF)
#define KXTJ3_READ_DATA_SIZE     (6)
#define KXTJ3_AXIS_SIZE          (KXTJ3_READ_DATA_SIZE / 2)
#define KXTJ3_DIVIDE_SHIFT       (15)
#define LEDS_ACTIVE_STATE 0
#define ACC_CHECK_INTERVAL              APP_TIMER_TICKS(1000)
#define BOARD_LED                       6                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   0//BSP_BOARD_LED_1                         /**< Is on when device has connected.
#define LEDBUTTON_LED                   0//BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service.
#define LEDBUTTON_BUTTON                0//BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service
#define DEVICE_NAME                     "Autolith"                         /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER                    "AutolithInc"
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                1600                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
//#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define PIN_IN                          NRF_GPIO_PIN_MAP(0,29)
BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);
//BLE_BAS_DEF(m_bas);
//saadc defines
#define SAMPLES_IN_BUFFER 5
volatile uint8_t state = 1;
//static bool low_Battery = false;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(1);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
APP_TIMER_DEF(m_app_timer_id);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
//"BluetoothLE#BluetoothLE78:2b:46:2d:24:35-a4:c1:38:f9:09:41"
//static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
//BLE_ITS_DEF(m_its, NRF_SDH_BLE_PERIPHERAL_LINK_COUNT);
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
//records the previous prosition of the display
uint8_t old_Orientation = 0;
// saadc battery level detection
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t button_action)
    ret_code_t err_code;
    NRF_LOG_INFO("Send button state change.");
    err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
    if (err_code != NRF_SUCCESS &&
        err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
        err_code != NRF_ERROR_INVALID_STATE &&
        err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
static void led_event_handler(uint8_t led_action)
    //err_code = ble_lbs_on_led_change(m_conn_handle, &m_lbs, led_action);
//void saadc_sampling_event_init(void)
//    ret_code_t err_code;
//    //app_timer_init();
//    err_code = nrf_drv_ppi_init();
//    APP_ERROR_CHECK(err_code);
//    nrf_drv_timer_config_t timer_cfg = NRF_DRV_TIMER_DEFAULT_CONFIG;
//    timer_cfg.bit_width = NRF_TIMER_BIT_WIDTH_32;
//    err_code = nrf_drv_timer_init(&m_timer, &timer_cfg, timer_handler);
//    /* setup m_timer for compare event every 400ms */
//    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 500);//28800000);//86400000);
//    nrf_drv_timer_extended_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
//    nrf_drv_timer_enable(&m_timer);
//    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
//    uint32_t saadc_sample_task_addr   = nrf_drv_saadc_sample_task_get();
//    /* setup ppi channel so that timer compare event is triggering sample task in SAADC */
//    err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel);
//    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_task_addr);
//void saadc_sampling_event_enable(void)
//    ret_code_t err_code = nrf_drv_ppi_channel_enable(m_ppi_channel);
//void saadc_callback(nrf_drv_saadc_evt_t const * p_event)
//    uint8_t low_Battery = 0;
//    if (p_event->type == NRF_DRV_SAADC_EVT_DONE)
//        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
//        int i;
//        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
//        int adc_result =  p_event->data.done.p_buffer[0];
//        //for (i = 0; i < SAMPLES_IN_BUFFER; i++)
//        //    adc_result = p_event->data.done.p_buffer[i];
//        //    //adc_result = (adc_result * 3600) >> 10;
//        //    NRF_LOG_INFO("%d", adc_result);
//        //TODO: If under 1023, low battery indication
//        NRF_LOG_INFO("%d", p_event->data.done.p_buffer[0]);
//        if (adc_result < 1023)
//            //set characteristic low battery to true (desktop will send notification)
//            if (low_Battery == 0)
//                low_Battery = 1;
//                led_event_handler(low_Battery);
//        else
//            //set characteristic low battery to false
//            if (low_Battery == 1)
//                low_Battery = 0;
//        m_adc_evt_counter++;
//void saadc_init(void)
//    nrf_saadc_channel_config_t channel_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
//    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
//    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
//    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
//    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
//-----------------TWI--------------------------
uint8_t acc_shutdown(void)
    uint8_t buf[2];
    buf[0] = KXTJ3_CNTL1;
    buf[1] = 0x00;
    nrf_drv_twi_tx(&m_twi, KXTJ3_DEVICE_ADDRESS, &buf, sizeof(buf), false);
uint8_t who_am_i(void)
    uint8_t data;
    uint8_t buf[2] = {KXTJ3_WHO_AM_I};
    err_code = nrf_drv_twi_tx(&m_twi, KXTJ3_DEVICE_ADDRESS, &buf, 1, false);
    err_code = nrf_drv_twi_rx(&m_twi, KXTJ3_DEVICE_ADDRESS, &data, sizeof(data));
    if (err_code == NRF_SUCCESS && data == KXTJ3_WHO_AM_I){
        return KXTJ3_COMM_OK;
    else{
        return KXTJ3_COMM_ERROR;
uint8_t acc_start(void)
    uint8_t data;
    uint8_t buf[2];
    buf[1] = 0x00;
    err_code = nrf_drv_twi_tx(&m_twi, KXTJ3_DEVICE_ADDRESS, &buf, sizeof(buf), false);
    buf[1] = 0x80;
    err_code = nrf_drv_twi_tx(&m_twi, KXTJ3_DEVICE_ADDRESS, &buf, 2, false);
    uint8_t control_val;
    err_code = nrf_drv_twi_rx(&m_twi, KXTJ3_DEVICE_ADDRESS, &control_val, sizeof(buf));
    if (err_code == NRF_SUCCESS && control_val == 0x80){
    else{
uint8_t acc_get_xyz(uint8_t *acc_values)
    uint8_t bufX[1];
    uint8_t data;
    uint8_t reg_values[6] = {KXTJ3_XOUT_L, KXTJ3_XOUT_H, KXTJ3_YOUT_L, KXTJ3_YOUT_H, KXTJ3_ZOUT_L, KXTJ3_ZOUT_H};
    uint8_t j = 1;
    for (uint8_t i = 0; i < 5; i = i + 2){
        bufX[0] = reg_values[i];
        err_code = nrf_drv_twi_tx(&m_twi, KXTJ3_DEVICE_ADDRESS, &bufX, sizeof(bufX), true);
        bufX[0] = reg_values[j];
        acc_values[i] = data;
        acc_values[j] = data;
        j = j + 2;
    if (err_code == NRF_SUCCESS){
    else{
void acc_translate_values(uint8_t *acc_values, uint16_t *xyz_values)
      //x
      uint8_t x_a[2] = {acc_values[0], acc_values[1]};
      int16_t x = (*(int16_t*) x_a) >> 10;
      //y
      uint8_t y_a[2] = {acc_values[2], acc_values[3]};
      int16_t y = (*(int16_t*) y_a) >> 10;
      //z
      uint8_t z_a[2] = {acc_values[4], acc_values[5]};
      int16_t z = (*(int16_t*) z_a) >> 10;
      xyz_values[0] = x;
      xyz_values[1] = y;
      xyz_values[2] = z;
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                uint8_t acc_values[6];
                acc_get_xyz(&acc_values);
            m_xfer_done = true;
void  twi_init (void)
    const nrf_drv_twi_config_t twi_vnet_config = {
       .scl                = NRF_GPIO_PIN_MAP(0,9),
       .sda                = NRF_GPIO_PIN_MAP(0,10),
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOW,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_vnet_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
    err_code = who_am_i();
    err_code = acc_start();
//---------------Board LED------------------------
uint8_t led_blink(uint8_t count)
    uint32_t LED = NRF_GPIO_PIN_MAP(0, 11);
    nrf_gpio_cfg_output(LED);
    for (int i = 0; i < count; i++)
        nrf_gpio_pin_set(LED);
        nrf_delay_ms(100);
        nrf_gpio_pin_clear(LED);
        nrf_delay_ms(100);
uint8_t led_on(void)
uint8_t led_off(void)
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scan_response_data,
//static ble_uuid_t m_adv_uuids[] =                                               /**< Universally unique service identifiers. */
//    {0x2c2bd69f59d6492ab085607672de3947, BLE_UUID_TYPE_BLE}
/**@brief Function for assert macro callback.
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    // Initialize timer module, making it use the scheduler
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    err_code = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    ble_advdata_t advdata;
    ble_advdata_t srdata;
    ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
    //TODO: ADD service for battery monitoring
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = true;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    memset(&srdata, 0, sizeof(srdata));
    srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    srdata.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    ble_gap_adv_params_t adv_params;
    // Set advertising parameters.
    memset(&adv_params, 0, sizeof(adv_params));
    adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
    adv_params.duration        = APP_ADV_DURATION;
    adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    adv_params.p_peer_addr     = NULL;
    adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    adv_params.interval        = APP_ADV_INTERVAL;
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling write events to the LED characteristic.
 * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
 * @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (!BLE_GAP_EVT_DISCONNECTED)
        bsp_board_led_on(BOARD_LED);
        NRF_LOG_INFO("LED ON");
        bsp_board_led_off(BOARD_LED);
        NRF_LOG_INFO("LED OFF");
    ble_lbs_init_t     init     = {0};
    // Initialize LBS.
    init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module that
 *          are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply
 *       setting the disconnect_on_fail config parameter, but instead we use the event
 *       handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    //bsp_board_led_on(ADVERTISING_LED);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            acc_start();
            app_timer_start(m_app_timer_id, ACC_CHECK_INTERVAL, NULL);
            led_blink(2);
            NRF_LOG_INFO("Disconnected");
            acc_shutdown();
            app_timer_stop(m_app_timer_id);
            advertising_start();
            led_blink(2);
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
//static void battery_level_meas_timeout_handler(void * p_context)
//    UNUSED_PARAMETER(p_context);
//    adc_configure();
//    err_code = nrf_drv_saadc_sample();
    uint32_t ram_start = 0;
    // Enable BLE stack.
static void log_init(void)
        nrf_pwr_mgmt_run();
static void app_timer_handler(void * p_context)
    NRF_LOG_INFO("Timer Firing!");
    uint8_t acc_err_code;
    acc_err_code = acc_get_xyz(&acc_values);
    uint8_t new_Orientation = 0;
    if (acc_err_code != KXTJ3_COMM_OK){
        NRF_LOG_INFO("Accelerometer Error (2)");
    //z
    if (x > 0 && y < 10 && y > -10){ //0 degrees
        new_Orientation = 2;//0
    else if (y < 0 && x < 10 && x > -10){ //270 degrees
        new_Orientation = 3;//1
    else if (x < 0 && y > -10 && y < 10){
        new_Orientation = 0;//2
    else if (y > 0 && x < 10 && x > -10){
        new_Orientation = 1;//3
    if (new_Orientation != old_Orientation){
        button_event_handler(new_Orientation);
        old_Orientation = new_Orientation;
        led_blink(1);
static void acc_timer_init(void)
    err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, app_timer_handler);
/**@brief Function for application main entry.
    err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
    // Initialize.
    //log_init();
    leds_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    twi_init();
    //saadc_init();
    //saadc_sampling_event_init();
    //saadc_sampling_event_enable();
    led_blink(2);
    acc_shutdown();
    acc_timer_init();
    // Enter main loop.
    for (;;)
        idle_state_handle();
