nRF7002Dk send wifi beacon on 3 channel with the samples "raw_tx_packet"
Hi Supporter:
  I want make a wifi position card with nRF7002 which support low power and fast beacon sending.
  I evaluate it with nRF7002.
  Now i have some problem about this(Environment:  nrf-sdk main branch, samples\wifi\raw_tx_packet):
1. i want to send the beacon on 3 channel(1,6,11) every 250ms.
       The code:
uint8_t channel_info[3] = {6,1,11};
static void wifi_send_raw_tx_packets(void)
        for (int i = 0; i < 3; i++) {
            wifi_set_channel(channel_info[i]);
            memcpy(test_frame + sizeof(struct raw_tx_pkt_header),
                   &test_beacon_frame, sizeof(test_beacon_frame));
            ret = sendto(sockfd, test_frame, buf_length, 0,
                    (struct sockaddr *)&sa, sizeof(sa));
            if (ret < 0) {
                LOG_ERR("Unable to send beacon frame: %s", strerror(errno));
                num_failures++;
            increment_seq_control();
            k_msleep(CONFIG_RAW_TX_PACKET_SAMPLE_INTER_FRAME_DELAY_MS);
The beacon is sending success when it slowly. But when the beacon interval update to 250ms, There have some error:
[00:01:20.487,121] [1;31m<err> wifi_nrf: umac_cmd_alloc: Failed to allocate UMAC cmd[0m
[00:01:20.487,152] [1;31m<err> wifi_nrf: nrf_wifi_fmac_set_channel: umac_cmd_alloc failed[0m
[00:01:20.487,182] [1;31m<err> wifi_nrf: nrf_wifi_channel: set channel failed[0m
[00:01:20.487,182] [1;31m<err> raw_tx_packet: Channel setting failed -1
I thought that the beacon sending is fast, not need wait so long time, ,Could you tell me if it has some better way to implement this feature.
2. The low power is 120uA when the nRF7002DK sleep. I thought that it should be lower power consumption.
I test the current refer to the document "nRF7002_DK_User_Guide_v1.0.0.pdf".
I get 3uA when the net shutdown refer to the sample "shutdown"(suspend the debug serial).
Could you please tell if there have a register description document available for reference
  • You don't have any issue with code errors when switching channels?
    The datasheet is not published, Don't know how does the low level code implement . I am waiting the new version of this feature.
  • No, i don't have any LOG errors
    sdk 2.6.0
    and I can see the packets on the sniffer.
    but still this is not relevant for real world..
    opened a ticket
    nrf7002-DK - Wifi channel switching raw packets
     * Copyright (c) 2023 Nordic Semiconductor ASA
    /** @file
     * @brief Wi-Fi Raw Tx Packet sample
    LOG_MODULE_REGISTER(raw_tx_packet, CONFIG_LOG_DEFAULT_LEVEL);
    #include <zephyr/net/socket.h>
    #include <nrf_wifi/fw_if/umac_if/inc/default/fmac_structs.h>
    #include "net_private.h"
    #include "wifi_connection.h"
    #define BEACON_PAYLOAD_LENGTH 256
    #define CONTINUOUS_MODE_TRANSMISSION 0
    #define FIXED_MODE_TRANSMISSION 1
    #define IEEE80211_SEQ_CTRL_SEQ_NUM_MASK 0xFFF0
    #define IEEE80211_SEQ_NUMBER_INC BIT(4) /* 0-3 is fragment number */
    struct beacon {
    	uint16_t frame_control;
    	uint16_t duration;
    	uint8_t da[6];
    	uint8_t sa[6];
    	uint8_t bssid[6];
    	uint16_t seq_ctrl;
    	uint8_t payload[BEACON_PAYLOAD_LENGTH];
    } __packed;
    static struct beacon test_beacon_frame = {
    	.frame_control = htons(0X8000),
    	.duration = 0X0000,
    	.da = {0XFF, 0XFF, 0XFF, 0XFF, 0XFF, 0XFF},
    	/* Transmitter Address: A0:69:60:E3:52:15 */
    	.sa = {0XA0, 0X69, 0X60, 0XE3, 0X52, 0X15},
    	.bssid = {0XA0, 0X69, 0X60, 0XE3, 0X52, 0X15},
    	.seq_ctrl = 0X0001,
    	/* SSID: NRF_RAW_TX_PACKET_APP */
    	.payload = {
    		0X0C, 0XA2, 0X28, 0X00, 0X00, 0X00, 0X00, 0X00, 0X64, 0X00,
    		0X11, 0X04, 0X00, 0X15, 0X4E, 0X52, 0X46, 0X5F, 0X52, 0X41,
    		0X57, 0X5F, 0X54, 0X58, 0X5F, 0X50, 0X41, 0X43, 0X4B, 0X45,
    		0X54, 0X5F, 0X41, 0X50, 0X50, 0X01, 0X08, 0X82, 0X84, 0X8B,
    		0X96, 0X0C, 0X12, 0X18, 0X24, 0X03, 0X01, 0X06, 0X05, 0X04,
    		0X00, 0X02, 0X00, 0X00, 0X2A, 0X01, 0X04, 0X32, 0X04, 0X30,
    		0X48, 0X60, 0X6C, 0X30, 0X14, 0X01, 0X00, 0X00, 0X0F, 0XAC,
    		0X04, 0X01, 0X00, 0X00, 0X0F, 0XAC, 0X04, 0X01, 0X00, 0X00,
    		0X0F, 0XAC, 0X02, 0X0C, 0X00, 0X3B, 0X02, 0X51, 0X00, 0X2D,
    		0X1A, 0X0C, 0X00, 0X17, 0XFF, 0XFF, 0X00, 0X00, 0X00, 0X00,
    		0X00, 0X00, 0X00, 0X2C, 0X01, 0X01, 0X00, 0X00, 0X00, 0X00,
    		0X00, 0X00, 0X00, 0X00, 0X00, 0X3D, 0X16, 0X06, 0X00, 0X00,
    		0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
    		0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X7F, 0X08, 0X04, 0X00,
    		0X00, 0X02, 0X00, 0X00, 0X00, 0X40, 0XFF, 0X1A, 0X23, 0X01,
    		0X78, 0X10, 0X1A, 0X00, 0X00, 0X00, 0X20, 0X0E, 0X09, 0X00,
    		0X09, 0X80, 0X04, 0X01, 0XC4, 0X00, 0XFA, 0XFF, 0XFA, 0XFF,
    		0X61, 0X1C, 0XC7, 0X71, 0XFF, 0X07, 0X24, 0XF0, 0X3F, 0X00,
    		0X81, 0XFC, 0XFF, 0XDD, 0X18, 0X00, 0X50, 0XF2, 0X02, 0X01,
    		0X01, 0X01, 0X00, 0X03, 0XA4, 0X00, 0X00, 0X27, 0XA4, 0X00,
    		0X00, 0X42, 0X43, 0X5E, 0X00, 0X62, 0X32, 0X2F, 0X00
    #ifdef CONFIG_RAW_TX_PKT_SAMPLE_NON_CONNECTED_MODE
    static void wifi_set_channel(void)
    	struct net_if *iface;
    	struct wifi_channel_info channel_info = {0};
    	int ret;
    	channel_info.oper = WIFI_MGMT_SET;
    	iface = net_if_get_first_wifi();
    	if (iface == NULL) {
    		LOG_ERR("Failed to get Wi-Fi iface");
    		return;
    	channel_info.if_index = net_if_get_by_iface(iface);
    	channel_info.channel = CONFIG_RAW_TX_PKT_SAMPLE_CHANNEL;
    	if ((channel_info.channel < WIFI_CHANNEL_MIN) ||
    		   (channel_info.channel > WIFI_CHANNEL_MAX)) {
    		LOG_ERR("Invalid channel number. Range is (1-233)");
    		return;
    	ret = net_mgmt(NET_REQUEST_WIFI_CHANNEL, iface,
    		       &channel_info, sizeof(channel_info));
    	if (ret) {
    		LOG_ERR(" Channel setting failed %d\n", ret);
    			return;
    	LOG_INF("Wi-Fi channel set to %d", channel_info.channel);
    static void wifi_set_channel_cyclic(void)
    	int ret;
    	static int i = 0;
    		return;
    	i++;
    	int i_mod = i % 3;
    	if(i_mod == 0)
    		channel_info.channel = 1;
    	else if(i_mod == 1)
    		channel_info.channel = 6;
    	else if(i_mod == 2)
    		channel_info.channel = 11;
    		return;
    	if (ret) {
    			return;
    static void wifi_set_mode(int mode_val)
    	int ret;
    	struct net_if *iface = NULL;
    	struct wifi_mode_info mode_info = {0};
    	mode_info.oper = WIFI_MGMT_SET;
    		return;
    	mode_info.if_index = net_if_get_by_iface(iface);
    	mode_info.mode = mode_val;
    	ret = net_mgmt(NET_REQUEST_WIFI_MODE, iface, &mode_info, sizeof(mode_info));
    	if (ret) {
    		LOG_ERR("Mode setting failed %d", ret);
    #ifdef CONFIG_RAW_TX_PKT_SAMPLE_INJECTION_ENABLE
    static int wifi_set_tx_injection_mode(void)
    	if (!iface) {
    		return -1;
    	if (net_eth_txinjection_mode(iface, true)) {
    		LOG_ERR("TX Injection mode enable failed");
    		return -1;
    	LOG_INF("TX Injection mode enabled");
    	return 0;
    #endif /* CONFIG_RAW_TX_PKT_SAMPLE_INJECTION_ENABLE */
    static int setup_raw_pkt_socket(int *sockfd, struct sockaddr_ll *sa)
    	int ret;
    	*sockfd = socket(AF_PACKET, SOCK_RAW, IPPROTO_RAW);
    	if (*sockfd < 0) {
    		LOG_ERR("Unable to create a socket %d", errno);
    		return -1;
    	if (!iface) {
    		LOG_ERR("Failed to get Wi-Fi interface");
    		return -1;
    	sa->sll_family = AF_PACKET;
    	sa->sll_ifindex = net_if_get_by_iface(iface);
    	/* Bind the socket */
    	ret = bind(*sockfd, (struct sockaddr *)sa, sizeof(struct sockaddr_ll));
    	if (ret < 0) {
    		LOG_ERR("Error: Unable to bind socket to the network interface:%s",
    			strerror(errno));
    		close(*sockfd);
    		return -1;
    	return 0;
    static void fill_raw_tx_pkt_hdr(struct raw_tx_pkt_header *raw_tx_pkt)
    	/* Raw Tx Packet header */
    	raw_tx_pkt->magic_num = NRF_WIFI_MAGIC_NUM_RAWTX;
    	raw_tx_pkt->data_rate = CONFIG_RAW_TX_PKT_SAMPLE_RATE_VALUE;
    	raw_tx_pkt->packet_length = sizeof(test_beacon_frame);
    	raw_tx_pkt->tx_mode = CONFIG_RAW_TX_PKT_SAMPLE_RATE_FLAGS;
    	raw_tx_pkt->queue = CONFIG_RAW_TX_PKT_SAMPLE_QUEUE_NUM;
    	/* The byte is reserved and used by the driver */
    	raw_tx_pkt->raw_tx_flag = 0;
    	if(raw_tx_pkt->tx_mode == 0)
    		LOG_INF("tx mode LEGACY");
    int wifi_send_raw_tx_pkt(int sockfd, char *test_frame,
    			size_t buf_length, struct sockaddr_ll *sa)
    	return sendto(sockfd, test_frame, buf_length, 0,
    			(struct sockaddr *)sa, sizeof(*sa));
    static int get_pkt_transmit_count(unsigned int *mode_of_transmission,
    					unsigned int *num_tx_pkts)
    #ifdef CONFIG_RAW_TX_PKT_SAMPLE_TX_MODE_FIXED
    	*mode_of_transmission = 1;
    	*num_tx_pkts = CONFIG_RAW_TX_PKT_SAMPLE_FIXED_NUM_PACKETS;
    	if (*num_tx_pkts == 0) {
    		LOG_ERR("Can't send %d number of raw tx packets", *num_tx_pkts);
    		return -1;
    	LOG_INF("Sending %d number of raw tx packets", *num_tx_pkts);
    #else
    	*mode_of_transmission = 0;
    	*num_tx_pkts = UINT_MAX;
    	LOG_INF("Sending raw tx packets continuously");
    	return 0;
    static void increment_seq_control(void)
    	test_beacon_frame.seq_ctrl = (test_beacon_frame.seq_ctrl +
    				      IEEE80211_SEQ_NUMBER_INC) &
    				      IEEE80211_SEQ_CTRL_SEQ_NUM_MASK;
    	if (test_beacon_frame.seq_ctrl > IEEE80211_SEQ_CTRL_SEQ_NUM_MASK) {
    		test_beacon_frame.seq_ctrl = 0X0010;
    	struct sockaddr_ll sa;
    	struct raw_tx_pkt_header packet;
    	char *test_frame = NULL;
    	unsigned int buf_length, num_pkts, transmission_mode, num_failures = 0;
    	while(1)
    		for (int i = 0; i < num_pkts; i++) {
    			for(int j = 0; j < 3; ++j)
    				int sockfd, ret;
    				wifi_set_channel_cyclic();
    				ret = setup_raw_pkt_socket(&sockfd, &sa);
    				if (ret < 0) {
    					LOG_ERR("Setting socket for raw pkt transmission failed %d", errno);
    					return;
    				fill_raw_tx_pkt_hdr(&packet);
    				ret = get_pkt_transmit_count(&transmission_mode, &num_pkts);
    				if (ret < 0) {
    					LOG_ERR("get_pkt_transmit_count");
    					close(sockfd);
    					return;
    				test_frame = malloc(sizeof(struct raw_tx_pkt_header) + sizeof(test_beacon_frame));
    				if (!test_frame) {
    					LOG_ERR("Malloc failed for send buffer %d", errno);
    					return;
    				buf_length = sizeof(struct raw_tx_pkt_header) + sizeof(test_beacon_frame);
    				memcpy(test_frame, &packet, sizeof(struct raw_tx_pkt_header));
    				if (ret < 0) {
    					num_failures++;
    				close(sockfd);
    				free(test_frame);
    				//k_msleep(1000);
    			k_msleep(1000);
    	//LOG_INF("Sent %d packets with %d failures on socket", num_pkts, num_failures);
    	/* close the socket */
    	//close(sockfd);
    	//free(test_frame);
    	int mode;
    	mode = BIT(0);
    	/* This is to set mode to STATION */
    	wifi_set_mode(mode);
    	if (wifi_set_tx_injection_mode()) {
    		return -1;
    #ifdef CONFIG_RAW_TX_PKT_SAMPLE_CONNECTION_MODE
    	int status;
    	status = try_wifi_connect();
    	if (status < 0) {
    		return status;
    #else
    	//wifi_set_channel();
    	//wifi_set_channel_cyclic();
    	wifi_send_raw_tx_packets();
    	return 0;
    it also worked without opening / closing the socket. just switching channels.
