FATAL ERROR: command exited with status 33
Hello
I am started playing with nRF5340 DK some month ago and did simple things that worked as expected but now I get the following failure (occures at each trial)  that askes me to add --log to the command (currently I use only VSCode as IDE)
Please point me to the correct direction
See output below
Thanks a lot
Gerhard
* Task wird ausgeführt: nRF Connect: Flash: ncs-avr-spi-example/build (active)
Flashing build to 1050065280
west flash -d /Users/gerhard/Desktop/nd/ncs-avr-spi-example/build --skip-rebuild --dev-id 1050065280
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: /Users/gerhard/Desktop/nd/ncs-avr-spi-example/build/zephyr/zephyr.hex
ERROR: Unable to connect to a debugger.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program /Users/gerhard/Desktop/nd/ncs-avr-spi-example/build/zephyr/zephyr.hex --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 1050065280
* Der Terminalprozess wurde mit folgendem Exitcode beendet: 33.
