Reference for mutual TLS and private key handling
I intend to implement an application on nrf9160, that makes use of mutual-tls to communicate with a peer.
To this end, I need to store a private key in a save place on the nrf9160 and create tls-sockets from it.
My understanding of the recommended approach is as follows:
  1. Comparing the developer.nordicsemi.com/.../README.html flash a provisioning image to initialize the HUK, hardware unique keys.
  2. Flash the production image, that has protected storage enabled.
    1. Generate cryptographic randomness
    2. Write it to protected storage
    3. The protected storage will encrypt it using the identity key `NRF_KMU_SLOT_IDENT`
    4. Then write it to internal trusted storage (optionally additionaly encrypted with NRF_KMU_SLOTMKEK if configured that way by selecting CONFIG_TFM_ITS_ENCRYPTED)
    5. Read it to NSPE-RAM from protected storage to create csr with mbedtls.
    6. Read it to NSPE-RAM from protected storage to hand it off to zephyrs tls_credentials_add-API.
From devzone.nordicsemi.com/.../persistent-storage-of-keys-and-data-using-the-nrf-connect-sdk I understand, that the recommended approach would be to use the crypto api to generate a key with persistent live-time. This stores it in ITS, but would that not be unencrypted unless above config is set?
Am I understanding the recommended approach correctly?
Are there better alternative? For example:
  1. Can slots in the KMU be used to store the private key forgoing the need for protected storage altogether?
  2. Can the key be derrived from a HUK every time before use forgoing the need to store it anywhere persistently? If so which HUK shall be used?
  3. How many space is in the KMU? I understand 125 slots a 128 bits/slot?
  4. Is there an alternative to tls_credentials_add and mbedtls sockets, that allows to store the information persistently in some other way? Maybe developer.nordicsemi.com/.../sockets.html ?
Edit: please fix your forum. I had a much harder time making above text show properly then it should be.
