Custom Radio channel
"Hello, I'm using NCS v2.4.2 with an nRF52840DK and attempting to configure a custom radio channel with frequencies like 2403MHz and 2405MHz.
I followed the provided instructions;
https://github.com/Simula-UiB/mesh-node/blob/main/net_core/src/radio.c
the link would be on BLE-Mesh, but I tried BLE with my configuration, which is given below.
radio configurations:
 * @brief Start radio transmission
int radio_send(uint8_t *data, size_t length)
    int ret = 0;
    /* Fill radio transmission buffer */
    memcpy(rf_tx_buf + RF_BUFFER_PAYLOAD_OFFSET, data, length);
    /* Set length */
    rf_tx_buf[RF_BUFFER_LENGTH_OFFSET] = length + 1;
    LOG_HEXDUMP_DBG(rf_tx_buf, length + 1, "Data TX");
    /* Get radio state */
    nrf_radio_state_t state = nrf_radio_state_get(NRF_RADIO);
    switch (state)
    case NRF_RADIO_STATE_RX:
        /* Stop RX, trigger TXEN task from RXIDLE state */
        nrf_radio_task_trigger(NRF_RADIO, NRF_RADIO_TASK_STOP);
        trigger_tx();
    case NRF_RADIO_STATE_RXIDLE:
    case NRF_RADIO_STATE_DISABLED:
        /* Radio already in compatible state, trigger TXEN task */
        trigger_tx();
    case NRF_RADIO_STATE_TXIDLE:
        nrf_radio_packetptr_set(NRF_RADIO, rf_tx_buf);
        nrf_radio_task_trigger(NRF_RADIO, NRF_RADIO_TASK_START);
        /* Radio in incompatible state. Drop packet, for now */
        LOG_ERR("TX Failed, incompatible state. State: %d", state);
        ret = -EIO;
    LOG_DBG("Finished TX");
    return ret;
void trigger_tx()
    nrf_radio_task_trigger(NRF_RADIO, NRF_RADIO_TASK_TXEN);
 * @brief Initialize BLE radio
void init_radio()
    LOG_INF("Initializing radio");
    /* Set modulation and bitrate */
    nrf_radio_mode_set(NRF_RADIO, NRF_RADIO_MODE_BLE_1MBIT); // NRF_RADIO_MODE_BLE_2MBIT
    /* Enable fast ramp up, transmit center when idle */
    nrf_radio_modecnf0_set(NRF_RADIO, true, RADIO_MODECNF0_DTX_Center);
    /* Set channel */
    nrf_radio_frequency_set(NRF_RADIO, 2426); // 2442 Mhz
    /* Set radio transmission power */
    nrf_radio_txpower_set(NRF_RADIO, TX_POWER);
    /* Set packet config */
    nrf_radio_packet_conf_t pkt_conf = {
        .lflen = 8UL, // Length field length in bits
        .s0len = 0UL,
        .s1len = 0UL,
        .s1incl = false,
        .plen = NRF_RADIO_PREAMBLE_LENGTH_16BIT,
        .crcinc = false, // CRC included in length field
        .statlen = 0UL,
        .balen = 4UL,
        .big_endian = true,
        .maxlen = MAX_MESSAGE_SIZE, // Max payload length
        .whiteen = false            // Packet whitening
    nrf_radio_packet_configure(NRF_RADIO, &pkt_conf);
    /* Address */
    nrf_radio_base0_set(NRF_RADIO, 0xAAAAAAAAAA);
    nrf_radio_prefix0_set(NRF_RADIO, 0x42U);
    nrf_radio_txaddress_set(NRF_RADIO, 0x00U); // Transmit using logical address 0 (base0 and prefix0)
    // nrf_radio_rxaddresses_set(NRF_RADIO, 0x01U); // Enable RX of logical address 0
    /* CRC Config */
    nrf_radio_crc_configure(NRF_RADIO,
                            2, // 2 byte CRC
                            NRF_RADIO_CRC_ADDR_INCLUDE,
                            0x1021); // Polynomial: x16 + x12 + x5 + 1
    /* Shortcuts */
    nrf_radio_shorts_enable(NRF_RADIO, NRF_RADIO_SHORT_READY_START_MASK); // Ready -> Start shortcut
main
 * @brief Initialize power and clock peripherals
static void init_power_clock(void)
    nrfx_clock_init(NULL);
    nrfx_power_init(NULL);
    nrfx_clock_start(NRF_CLOCK_DOMAIN_HFCLK);
    nrfx_clock_start(NRF_CLOCK_DOMAIN_LFCLK);
    while (!(nrfx_clock_hfclk_is_running() &&
             nrfx_clock_lfclk_is_running()))
        /* Just waiting */
void main(void)
    init_power_clock();
    /* Radio init */
    init_radio();
    LOG_INF("Radio initialized");
    uint8_t msg = 0xAA;
    while (1)
        radio_send(&msg, 1);
        k_msleep(2000); // Allow logs time to flush
Despite the code running without issues, I'm not receiving any messages on nRF Sniffer when monitoring with Wireshark.
I also tried using the default channel index 38 (2426MHz), but I encountered the same issue of not receiving any messages.
Could you please review the configuration to identify any potential mistakes?"
