peripheral_hids_keyboard only works with some hosts
Hi there,
I'm running the peripheral_hids_keyboard sample of the nRF Connect SDK 2.5.1 on my nRF52840-DK. After pushing button 4, advertising starts as expected, but I can only connect with some of my phones/tablets.
I can connect with:
- OnePlus 9 Pro phone running Android 13
- Huawei P20 Pro running Android 10
I can't connect with:
- MacBook Air running macOS Ventura 13.6.3 - After pressing the Connect button, a progress indicator shortly appears and then disappears.
- Huawei MediaPad M5 lite 10 tablet running Android 8.0.0 - Upon trying to pair, I get the "Pairing failed. Incorrect pairing key or the device you want to pair with is configured incorrectly" message.
- NPad-Pro tablet running Android 12 - "Pairing..." momentarily appears, then disappears.
The sample doesn't show up in the Bluetooth devices list:
- ThinkPad T520 running Windows 20 Pro 22H2
Can you reproduce such discrepancies across various hosts, and can you make them connect?
  • Thanks for your further instructions, Hung!
    I've made another capture based on the instructions. Is it useful this time?
    mac.pcapng
  • Hi Mlac,
    Thanks for the trace. I can see that the nRF52840 rejected the pairing with "Unspecific reason".
    I'm checking internally to see why this happens.
    I assume you were testing with unmodified peripheral_hids_keyboard sample ? ( with CONFIG_NFC_OOB_PAIRING=n ?)
    Could you send us the trace when it can connect and pair with other device not the MAC so we can compare ?
    Could you try testing with the peripheral_hids_mouse and check if you have the same problem (and give us the trace)
  • Hi again,
    Please also add CONFIG_BT_SMP_LOG_LEVEL_DBG=y to the code and send us the log if it actually show any extra information on why it reject the pairing request.
  • Hi Hung,
    I haven't had CONFIG_NFC_OOB_PAIRING enabled, and I've enabled CONFIG_BT_SMP_LOG_LEVEL_DBG for the following tests as requested:
    keyboard-mac.pcapng
    Advertisin successfully started
    Advertising continued
    D: conn 0x20001cb0 handle 0
    D: chan 0x2000205c cid 0x0006
    Connected 10:B5:88:72:9A:E6 (public)
    W: Ignoring data for unknown channel ID 0x003a
    D: Received SMP code 0x01 len 6
    D: req: io_capability 0x04, oob_flag 0x00, auth_req 0x2D, max_key_size 0x10, init_key_dist 0x0B, resp_key_dist 0x0B
    D: Unable to get keys for 10:B5:88:72:9A:E6 (public)
    Disconnected from 10:B5:88:72:9A:E6 (public) (reason 19)
    keyboard-phone.pcapng
    Advertising successfully started
    D:
    D: prnd 14912dac28b97ae452a0005dd6afb4e5
    Connected AC:D6:18:1B:3D:B5 (public)
    W: Unhandled ATT code 0x1d
    D: req: io_capability 0x04, oob_flag 0x00, auth_req 0x2D, max_key_size 0x10, init_key_dist 0x0F, resp_key_dist 0x0F
    D: rsp: io_capability 0x01, oob_flag 0x00, auth_req 0x0D, max_key_size 0x10, init_key_dist 0x02, resp_key_dist 0x00
    D: Received SMP code 0x0c len 64
    D:
    D: 0x2000904c
    D: Received SMP code 0x04 len 16
    D:
    Passkey for AC:D6:18:1B:3D:B5 (public): 180785
    Press Button 1 to confirm, Button 2 to reject.
    D: Received SMP code 0x0d len 16
    D:
    D:
    Numeric Match, conn 0x20001cb0
    D: chan 0x2000205c conn 0x20001cb0 handle 0 encrypt 0x01 hci status 0x00
    Security changed: AC:D6:18:1B:3D:B5 (public) level 4
    D: Received SMP code 0x08 len 16
    D:
    D: Received SMP code 0x09 len 7
    D: identity AC:D6:18:1B:3D:B5 (public)
    D: got status 0x0
    Pairing completed: AC:D6:18:1B:3D:B5 (public), bonded: 1
    mouse-mac.pcapng
    D: conn 0x20001d08 handle 0
    D: chan 0x200020b4 cid 0x0006
    Direct advertising to EC:8C:9A:A8:4E:57 (public) started
    Disconnected from 10:B5:88:72:9A:E6 (public) (reason 8)
    Directed advertising failed to start
    Direct advertising to EC:8C:9A:A8:4E:57 (public) timed out
    Direct advertising to AC:D6:18:1B:3D:B5 (public) started
    Direct advertising to AC:D6:18:1B:3D:B5 (public) timed out
    Regular advertising started
    mouse-phone.pcapng
    Direct advertising to E8C:9A:A8:4lic) started
    D: prnd c9ee4a30a30d95e5df0128728d51e951
    D: rsp: io_capability 0x01, oob_flag 0x00, auth_req 0x0D, max_key_size 0x10, init_key_dist 0x02, resp_key_dist 0x02
    D:
    D: 0x20008b05
    D:
    Passkey for AC:D6:18:1B:3D:B5 (public): 713638
    Press Button  to confirm, Button 2ct.
    Numeric Match, conn 0x20001d08
    D:
    D:
    D: chan 0x200020b4 conn 0x20001d08 handle 0 encrypt 0x01 hci status 0x00
    D:
    D: got status 0x0
    button_changed(): left
    The phone connection attempts were successful, and the Mac connection attempts were unsuccessful.
  • Hi Mlac,
    Regarding the trace between mouse and MAC, it doesn't seem they do pairing. Could you please test again and make sure the sniffer follows the mouse ?
    The log say "Unable to get keys for", it either returned by bt_keys_get_addr()  or bt_keys_get_type(). In both case it's related to that an old key can not be retracted or it can not create a new slot for the key.
    Have you made sure you erased the whole flash before testing ? I am under the impression that it reached the maximum number of device can be paired.
    Another option is to enable CONFIG_BT_KEYS_OVERWRITE_OLDEST so that it will overwrite the old key.
    If that doesn't help, could you add a breakpoint in the code where "Unable to get keys" is printed out in smp.c (there are 10 locations). We need to know which exact function causing the issue.
