Matter DNS-SD advertisement without BLE
I am testing the Matter sample for a Door Lock over Wi-Fi. I could test it successfully applying a commissioning through BLE and sending commands for locking/unlocking operations through the CHIP tool and the Wi-Fi network. I used these commands:
# For Commissioning through BLE
$ ./chip-tool pairing ble-wifi <node_id> <ssid> <password> <pin_code> <discriminator>
# To unlock the door with an automatic lock after timeout, using a timed invoke Matter interaction
./chip-tool doorlock unlock-with-timeout <timeout> <node_id> <endpoint_id> --timedInteractionTimeoutMs <timeout_invoke>
But, in my project development, I need to follow these steps:
  1. Connect the device to the Wi-Fi network.
  2. Commission the device through DNS-SD using one of the following commands from the CHIP tool:
$ ./chip-tool pairing onnetwork <node_id> <pin_code>
$ ./chip-tool pairing code <node_id> <qrcode_payload-or-manual_code>
$ ./chip-tool pairing onnetwork-long <node_id> <pin_code> <discriminator>
All CHIP tool commands are here.
How can I modify the Door Lock example to disable the BLE and configure the DNS-SD advertisement, so that I can commission the device that was previously connected to the Wi-Fi network?
Thank you for all the help you could provide for this issue.
Best Regards,
Holman
Parents Reply
    A colleague of mine actually did something similar. He told me:
    Recently I made a similar example for a Matter Bridge that connected to Wi-Fi by Wi-Fi provisioning service, and connected to their own cloud. After connecting to Wi-Fi, the device is on the network and can be commissioned by DNS-SD advertisement without BLE.
    Below is my example:
    https://github.com/lats1980/fw-nrfconnect-nrf/commit/3a93cfa594257722c6a28dca76a57408cccb88f7
    The example works with Apple Home, but I did not test with chip-tool.
    Ask them to refer to the changes in
    samples\matter\common\src\board.cpp
    samples\matter\common\src\board.h
    Especially, the API below opens a commissioning window with DNSSD:
    chip::Server::GetInstance().GetCommissioningWindowManager().OpenBasicCommissioningWindow(chip::System::Clock::Seconds16(CHIP_DEVICE_CONFIG_DISCOVERY_TIMEOUT_SECS), chip::CommissioningWindowAdvertisement:kDnssdOnly).
    Have a look, and see if this is something you can use as a starting point.
    Edvin
