MCUboot sign image: possible wrong slot size
I encountered the problem trying a Matter OTA-update and and asking myself why the bootloader wouldn't apply the image:
I am using the partition manager and defining the mcuboot_pad and mcuboot_primary_app partition both in the mcuboot_primary partition. MCUboot uses the mcuboot_primary_app partition value as definition of the maximum allowed partition size. However, both the sign function in nrf/modules/mcuboot/CMakeLists.txt as well as Zephyr use mcuboot_primary as available size for the image.
This leads to the problem that for an app, which exceeds the size of mcuboot_primary_app but is smaller than mcuboot_primary thebuild works fine, signing works as expected, but after the update file is send MCUboot does not apply the image.
I suggest setting
SLOT_SIZE $<TARGET_PROPERTY:partition_manager,PM_MCUBOOT_PRIMARY_APP_SIZE>
instead of
SLOT_SIZE $<TARGET_PROPERTY:partition_manager,PM_MCUBOOT_PRIMARY_SIZE>
Sadly, I haven't figured out where the app size in Zephyr is set, this may also need to be updated.
    Thanks for the report.
    I have reported this to our developers, and will keep you updated on the progress.
    Sigurd Hellesvik
  • Our developers do not think the line you change is a good fix for this.
    Instead, we have another internal ticket on MCUboot and partitioning that we suspect is the cause of this.
    MCUboot uses the last part of the secondary slot(I think it is there) to swap images. This means that if the application is too large there may be issues with swapping.
    Hopefully when we fix that, this issue will also be solved by the same fix.
  • Afaik MCUboot uses a special "scratch" partition or does in place swapping, if I am correct? Or might it be the mcuboot pad partition, which would also make sense (which is located before the primary app).
    PM_MCUBOOT_PRIMARY_APP_SIZE is smaller than PM_MCUBOOT_PRIMARY_SIZE, since it doesn't include the mcuboot pad partition. I basically ran into the problem that my app was too large (by means of PM_MCUBOOT_PRIMARY_APP_SIZE) but fitted into PM_MCUBOOT_PRIMARY_SIZE, so the OTA overwrote my factory data (located after the app partition).
    Afaik zephyr/scripts/imgtool.py is checking the size, so with the smaller size it will create an error during build.
    MCUboot uses a technique named "move" by default. See https://www.youtube.com/watch?v=TNvUHJ_NSo8. The pad is for metadata.
    The extra sector used for move is not defined in our partitioning scheme as of yet.
  • I stand corrected, thanks for the link Slight smile
    Nonetheless, if both pad & app partiton are used to determine the maximum image size, MCUboot will refuse to update. So this may not actually be a problem with the swapping at all, but "just" a wrong size as MCUboot checks afaik against MCUBOOT_PRIMARY_APP_SIZE.
1 2 3
