Use NFC pin (GPIO 0.9, 0.10, 0.12) as other purpose such as RTC input
configuration information
- use nRF5_SDK_17.1.0_ddde560
- use gcc
- use custom board #1, #2
- use nrf52811 soc
Previously I developed custom board #1 and I reduced the power consumption and it show that in adv mode: 6.8 uA, systemOff mode: 2uA.
And I developed custom board #2. I added new feature that is RTC input for providing time information.
I used NFC pins(GPIO 0.9, 0.10, 0.12) for connecting RTC for GPIO input.
In terms of HW configuration, everything is same between board #1 and #2 but only one difference is RTC input via NFC pin.
For power consumption testing, I did not attach RTC HW parts on the PCB board #2.
after measuring the power consumption for board #2, the result is in adv mode: 350uA, systemOff mode: 60uA
In software level, I added below code in Makefile
CFLAGS += -DCONFIG_NFCT_PINS_AS_GPIOS
and I added below code for disabling GPIO port.
#define RTC_SCK 9
#define RTC_IO 10
#define RTC_CE 12
nrf_gpio_cfg_output(RTC_SCK);nrf_gpio_pin_set(RTC_SCK);
nrf_gpio_cfg_output(RTC_IO);nrf_gpio_pin_set(RTC_IO);
nrf_gpio_cfg_output(RTC_CE);nrf_gpio_pin_set(RTC_CE);
I tried to search in DevZone for resolving issue, I found below suggestions.
A> add CONFIG_NFCT_PINS_AS_GPIOS in Makefile
B> "#define CONFIG_NFCT_PINS_AS_GPIOS" in system_nrf52.h.
C> HW modification
Pin 11 and pin 12 are by default configured to use the NFC antenna, but
if pin 11 and pin 12 are needed as  normal GPIOs, R25 and R26 must be NC
and R27 and R28 must be shorted by 0R.
D> NRF_UICR-> NFCPINS = 0xFFFFFFFE;" in main.c.
I applied A. B is not needed(already A used).
I can't figure out how to apply C.
when I'm trying to add 'NRF_UICR-> NFCPINS = 0xFFFFFFFE' to main.c, I got compile error  'NRF_UICR_Type' has no member named 'NFCPINS'.
How can I remove unnecessary power consumption?
