Mesh back and forth seems to break connection
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in the app level, where the sensor discovers the network IP of the host in pairing host. All the devices have the same PANID and network key.
Recently we have seen a scenario where some sensors seemingly stopped communication with the paired host. By looking at the RSSI graphs, we thought is this caused by a sensor constantly swinging back and forth between two hosts (one host acting as a router). We dont have access to the CLI interface of the hosts as this is a remote site. We see the Sensor RSSI reported back. This is its RSSI with the router/leader immediately connected to at the time.
Any ideas?
Cheers,
Kaushalya
  • Hello Kaushalya,
    kaushalyasat said:
    Normally when it powers up it connects to the network and change it's state to a router/leader. But this time it stayed on as a child!
    As you can see in the Openthread documentation, the network will strive to keep the number of routers below 15, if it is feasible. This is in order to be able to expand the network in any direction (physically) when needed. Therefore, if there are no devices that need to attach to your new device, and you already have a large amount of routers, there is no need to promote that device to a router.
    kaushalyasat said:
    I guess a FTD will remain a child as long as no child connects to it, am I correct?
    Yes, as long as there is a decent coverage of routers in the area of the new child.
    kaushalyasat said:
    I can see that in 'coap_send_request (...)' function, it is hard coded to be non-ack type (COAP_TYPE_NON_CON). I dont know if there is a way to request with confirmation using any API.
    Suppose I clone this 'coap_send_request (...)' and modify it to send ACK packet, then I would need to pass a call back with it to know the ack is successful or not?
    If there are too few routers in the network, it will promote some of them to routers, so that the network is ready to accept new child nodes.
    kaushalyasat said:
    This is possible. Our understanding is even it takes time to renegotiate new paths, it should be ok as we are sending temperature info in every 30 sec. Even if the rerout takes couple of minutes, it should be ok. But the issue is once the sensor's (SED)  data is lost, it remains so for days.
    Child supervision will not prevent nodes from dropping out of the network. It will just make it easier to detect whether it has happened or not.
    I am surprised that it doesn't take into account whether you provide a callback function or not, and that you could specify whether the coap_send_request() should be acked or not. But you are right, you can clone this function, and tell it to use COAP_TYPE_CON. Then you can also provide a coap_reply_t reply_cb, which will trigger when the callback occurs. I believe the node will automatically retransmit messages that are not acked, but you can use this while debugging.
    I agree that it shouldn't happen. If the connection to the parent is lost (because it is powered off), then the child should try to reconnect to the network through some other node.
    kaushalyasat said:
    After a while it 'auto-healed' by itself and my provisioning packets are now received by the SED.
    I would say that this is the expected behavior (from all other than the router that suddenly disconnected), don't you agree?
    You don't happen to have any logs from the router that suddenly greyed out?
    Edvin
  • Hi Edvin,
    Sorry I forgot to attach the pcap log.
    5633.May-30-prov success and fail.pcapng
    From what we have seen, its not the node dropping off. The nodes (SEDs) are sending their data out to the associated parent. I think the issue is the parent gets into some error state all of a sudden and stops sending these packets any further.
    What puzzles me is how long it took for the problematic router to be healed. Also this 'healing' happened when I connect to the console, so dont know if that had any effect. As this is a rare event, very difficult to deep diagnose.
    This is what I saw from the log while I was connecting to router 0x9400.
    uart:~$ ot rloc16
    9400
    Done
    uart:~$ [01:02:20.614,807] <inf> [I] ChildSupervsn-: sec sinse ast sup 3
    [01:02:20.614,898] <inf> [I] ChildSupervsn-: sec sinse ast sup 26
    [01:02:20.615,020] <inf> [I] ChildSupervsn-: sec sinse ast sup 12
    [01:02:21.614,929] <inf> [I] ChildSupervsn-: sec sinse ast sup 4
    [01:02:21.615,020] <inf> [I] ChildSupervsn-: sec sinse ast sup 27
    [01:02:21.615,142] <inf> [I] ChildSupervsn-: sec sinse ast sup 13
    uart:~$ [01:02:22.614,013] <inf> [I] ChildSupervsn-: sec sinse ast sup 5
    [01:02:22.614,135] <inf> [I] ChildSupervsn-: sec sinse ast sup 28
    [01:02:22.614,227] <inf> [I] ChildSupervsn-: sec sinse ast sup 14
    [01:02:23.036,102] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:104, chksum:3b0a, ecn:no, from:b20fec7a52d53c7b, sec:no, prio:net, rss:-36.0
    [01:02:23.036,346] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:b00f:ec7a:52d5:3c7b]:19788
    [01:02:23.036,621] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    uart:~$ [01:02:23.037,536] <inf> [I] Mle-----------: Receive Advertisement (fe80:0:0:0:b00f:ec7a:52d5:3c7b,0xa000)
    [01:02:23.618,133] <inf> [I] ChildSupervsn-: sec sinse ast sup 6
    [01:02:23.618,255] <inf> [I] ChildSupervsn-: sec sinse ast sup 29
    [01:02:23.618,347] <inf> [I] ChildSupervsn-: sec sinse ast sup 15
    uart:~$ [01:02:24.182,678] <inf> coap_server: No temp data
    [01:02:24.367,675] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:104, chksum:43c7, ecn:no, from:fa6c34f384a1c343, sec:no, prio:net, rss:-55.0
    [01:02:24.367,980] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:f86c:34f3:84a1:c343]:19788
    [01:02:24.368,255] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    [01:02:24.369,171] <inf> [I] Mle-----------: Receive Advertisement (fe80:0:0:0:f86c:34f3:84a1:c343,0xc000)
    [01:02:24.619,262] <inf> [I] Mle-----------: Child timeout expired
    uart:~$ [01:02:24.619,506] <inf> [I] ChildSupervsn-: sec sinse ast sup 7
    [01:02:24.619,781] <inf> [I] ChildSupervsn-: Sending supervision message to child 0x9423
    [01:02:24.619,903] <inf> [I] ChildSupervsn-: sec sinse ast sup 16
    [01:02:24.737,060] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:104, chksum:bc85, ecn:no, from:8a6694118ee9ea9a, sec:no, prio:net, rss:-28.0
    [01:02:24.737,304] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:8866:9411:8ee9:ea9a]:19788
    uart:~$ [01:02:24.737,579] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    [01:02:24.738,555] <inf> [I] Mle-----------: Receive Advertisement (fe80:0:0:0:8866:9411:8ee9:ea9a,0xd400)
    [01:02:24.761,047] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:67, chksum:79f8, ecn:no, from:0x3000, sec:yes, prio:net, rss:-69.0
    [01:02:24.761,505] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:3000]:61631
    [01:02:24.761,749] <inf> [I] MeshForwarder-:     dst:[fdde:ad00:beef:0:0:ff:fe00:9400]:61631
    [01:▒鲊ƪ▒▒▒<inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:3000]:61631
    [01:02:24.884,674] <â–’[01:02:30.194,885] <inf> coap_server: No temp data
    [01:02:30.616,546] <inf> [I] ChildSupervsn-: sec sinse ast sup 13
    [01:02:30.616,668] <inf> [I] ChildSupervsn-: sec sinse ast sup 6
    [01:02:30.616,790] <inf> [I] ChildSupervsn-: sec sinse ast sup 22
    uart:~$ [01:02:31.618,682] <inf> [I] ChildSupervsn-: sec sinse ast sup 14
    [01:02:31.618,835] <inf> [I] ChildSupervsn-: sec sinse ast sup 7
    [01:02:31.618,927] <inf> [I] ChildSupervsn-: sec sinse ast sup 23
    [01:02:32.256,805] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:83, chksum:700a, ecn:no, from:02e3e52c9bcab9d9, sec:yes, prio:net, rss:-61.0
    [01:02:32.257,049] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:e3:e52c:9bca:b9d9]:19788
    uart:~$ [01:02:32.257,324] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    [01:02:32.614,807] <inf> [I] ChildSupervsn-: sec sinse ast sup 15
    [01:02:32.614,898] <inf> [I] ChildSupervsn-: sec sinse ast sup 8
    [01:02:32.615,020] <inf> [I] ChildSupervsn-: sec sinse ast sup 24
    uart:~$ [01:02:33.614,959] <inf> [I] ChildSupervsn-: sec sinse ast sup 16
    [01:02:33.615,081] <inf> [I] ChildSupervsn-: sec sinse ast sup 9
    [01:02:33.615,173] <inf> [I] ChildSupervsn-: sec sinse ast sup 25
    [01:02:34.616,088] <inf> [I] ChildSupervsn-: sec sinse ast sup 17
    [01:02:34.616,180] <inf> [I] ChildSupervsn-: sec sinse ast sup 10
    [01:02:34.616,302] <inf> [I] ChildSupervsn-: sec sinse ast sup 26
    uart:~$ ot [01:02:35.619,232] <inf> [I] ChildSupervsn-: sec sinse ast sup 18
    [01:02:35.619,354] <inf> [I] ChildSupervsn-: sec sinse ast sup 11
    [01:02:35.619,445] <inf> [I] ChildSupervsn-: sec sinse ast sup 27
    [01:02:35.914,001] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:104, chksum:e695, ecn:no, from:768ec5ba1e5e09c6, sec:no, prio:net, rss:-56.0
    [01:02:35.914,245] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:748e:c5ba:1e5e:9c6]:19788
    [01:02:35.914,489] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    uart:~$ ot [01:02:35.915,466] <inf> [I] Mle-----------: Receive Advertisement (fe80:0:0:0:748e:c5ba:1e5e:9c6,0xc800)
    uart:~$ ot [01:02:36.206,848] <inf> coap_server: No temp data
    [01:02:36.621,368] <inf> [I] ChildSupervsn-: sec sinse ast sup 19
    uart:~$ ot [01:02:36.621,520] <inf> [I] ChildSupervsn-: sec sinse ast sup 12
    [01:02:36.621,612] <inf> [I] ChildSupervsn-: sec sinse ast sup 28
    uart:~$ ot chil[01:02:37.620,513] <inf> [I] ChildSupervsn-: sec sinse ast sup 20
    [01:02:37.620,635] <inf> [I] ChildSupervsn-: sec sinse ast sup 13
    [01:02:37.620,727] <inf> [I] ChildSupervsn-: sec sinse ast sup 29
    [01:02:38.503,753] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:95, chksum:f385, ecn:no, from:0x941a, sec:yes, prio:normal, rss:-47.0
    [01:02:38.504,028] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:fbd0:8244:b15b:7c56]:37410
    uart:~$ ot chil[01:02:38.504,302] <inf> [I] MeshForwarder-:     dst:[fdde:ad00:beef:0:ba0d:8101:b6b1:47f9]:5683
    uart:~$ ot chil[01:02:38.510,009] <inf> [I] MeshForwarder-: Sent IPv6 UDP msg, len:95, chksum:f385, ecn:no, to:0xc800, sec:yes, prio:normal
    uart:~$ ot chil[01:02:38.510,284] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:fbd0:8244:b15b:7c56]:37410
    [01:02:38.510,528] <inf> [I] MeshForwarder-:     dst:[fdde:ad00:beef:0:ba0d:8101:b6b1:47f9]:5683
    uart:~$ ot chil[01:02:38.567,596] <inf> [I] DataPollHandlr: Rx data poll, src:0x941a, qed_msgs:0, rss:-46, ack-fp:0
    uart:~$ ot chil[01:02:38.617,645] <inf> [I] ChildSupervsn-: sec sinse ast sup 21
    uart:~$ ot chil[01:02:38.617,767] <inf> [I] ChildSupervsn-: sec sinse ast sup 14
    [01:02:38.617,980] <inf> [I] ChildSupervsn-: Sending supervision message to child 0x941b
    uart:~$ ot chil[01:02:38.756,408] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:67, chksum:dabb, ecn:no, from:0x3000, sec:yes, prio:net, rss:-73.0
    uart:~$ ot chil[01:02:38.756,652] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:3000]:61631
    uart:~$ ot child[01:02:38.756,927] <inf> [I] MeshForwarder-:     dst:[fdde:ad00:beef:0:0:ff:fe00:9400]:61631
    uart:~$ ot child[01:02:38.757,354] <inf> [I] NetDiag-------: Received DiagGetRequest from fdde:ad00:beef:0:0:ff:fe00:3000
    uart:~$ ot child[01:02:38.764,831] <inf> [I] MeshForwarder-: Sent IPv6 UDP msg, len:116, chksum:f6d0, ecn:no, to:0x3000, sec:yes, prio:normal
    uart:~$ ot child[01:02:38.765,136] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:9400]:61631
    uart:~$ ot child[01:02:38.765,411] <inf> [I] MeshForwarder-:     dst:[fdde:ad00:beef:0:0:ff:fe00:3000]:61631
    uart:~$ ot child[01:02:38.814,727] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:104, chksum:9670, ecn:no, from:c2e03dbce20f9792, sec:no, prio:net, rss:-21.0
    uart:~$ ot child[01:02:38.815,032] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:c0e0:3dbc:e20f:9792]:19788
    uart:~$ ot child[01:02:38.815,277] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    [01:02:38.816,192] <inf> [I] Mle-----------: Receive Advertisement (fe80:0:0:0:c0e0:3dbc:e20f:9792,0x9800)
    uart:~$ ot child[01:02:38.961,761] <inf> [I] DataPollHandlr: Rx data poll, src:0x941b, qed_msgs:1, rss:-65, ack-fp:1
    uart:~$ ot child [01:02:39.616,790] <inf> [I] ChildSupervsn-: sec sinse ast sup 22
    [01:02:39.616,912] <inf> [I] ChildSupervsn-: sec sinse ast sup 15
    [01:02:39.617,004] <inf> [I] ChildSupervsn-: sec sinse ast sup 1
    [01:02:40.620,971] <inf> [I] ChildSupervsn-: sec sinse ast sup 23
    [01:02:40.621,093] <inf> [I] ChildSupervsn-: sec sinse ast sup 16
    [01:02:40.621,185] <inf> [I] ChildSupervsn-: sec sinse ast sup 2
    uart:~$ ot child tab[01:02:41.107,147] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:104, chksum:ec14, ecn:no, from:ca14168e1d0ab00d, sec:no, prio:net, rss:-69.0
    [01:02:41.107,513] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:c814:168e:1d0a:b00d]:19788
    [01:02:41.107,971] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    --- 1 messages dropped ---
    uart:~$ ot child tab[01:02:41.108,978] <inf> [I] Mle-----------: Receive Advertisement (fe80:0:0:0:c814:168e:1d0a:b00d,0x1c00)
    uart:~$ ot child tab[01:02:41.623,107] <inf> [I] ChildSupervsn-: sec sinse ast sup 24
    uart:~$ ot child tab[01:02:41.623,199] <inf> [I] ChildSupervsn-: sec sinse ast sup 17
    uart:~$ ot child tab[01:02:41.623,321] <inf> [I] ChildSupervsn-: sec sinse ast sup 3
    uart:~$ ot child tab[01:02:42.218,536] <inf> coap_server: No temp data
    uart:~$ ot child table[01:02:42.579,925] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:104, chksum:15a7, ecn:no, from:62521c7deb161193, sec:no, prio:net, rss:-29.0
    [01:02:42.580,200] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:6052:1c7d:eb16:1193]:19788
    [01:02:42.580,474] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    [01:02:42.581,634] <inf> [I] Mle-----------: Receive Advertisement (fe80:0:0:0:6052:1c7d:eb16:1193,0x2c00)
    uart:~$ ot child table[01:02:42.627,227] <inf> [I] ChildSupervsn-: sec sinse ast sup 25
    [01:02:42.627,349] <inf> [I] ChildSupervsn-: sec sinse ast sup 18
    uart:~$ ot child table[01:02:42.627,441] <inf> [I] ChildSupervsn-: sec sinse ast sup 4
    [01:02:43.629,608] <inf> [I] ChildSupervsn-: sec sinse ast sup 26
    uart:~$ ot child table[01:02:43.629,730] <inf> [I] ChildSupervsn-: sec sinse ast sup 19
    uart:~$ ot child table[01:02:43.629,821] <inf> [I] ChildSupervsn-: sec sinse ast sup 5
    | ID  | RLOC16 | Timeout    | Age        | LQ In | C_VN |R|D|N|Ver|CSL|QMsgCnt| Extended MAC     |
    |  26 | 0x941a |        240 |          5 |     3 |  225 |0|0|0|  4| 0 |     0 | 2646710567a57593 |
    |  35 | 0x9423 |        240 |         19 |     3 |  225 |0|0|0|  4| 0 |     0 | 76bcc914f4f0de22 |
    |  27 | 0x941b |        240 |          5 |     3 |  225 |0|0|0|  4| 0 |     0 | 664d9a2a076dabbd |
    Done
    uart:~$ [01:02:44.629,699] <inf> [I] ChildSupervsn-: sec sinse ast sup 27
    [01:02:44.629,821] <inf> [I] ChildSupervsn-: sec sinse ast sup 20
    [01:02:44.629,943] <inf> [I] ChildSupervsn-: sec sinse ast sup 6
    [01:02:45.630,828] <inf> [I] ChildSupervsn-: sec sinse ast sup 28
    [01:02:45.630,920] <inf> [I] ChildSupervsn-: sec sinse ast sup 21
    [01:02:45.631,042] <inf> [I] ChildSupervsn-: sec sinse ast sup 7
    uart:~$ [01:02:46.630,004] <inf> [I] ChildSupervsn-: sec sinse ast sup 29
    [01:02:46.630,126] <inf> [I] ChildSupervsn-: sec sinse ast sup 22
    [01:02:46.630,218] <inf> [I] ChildSupervsn-: sec sinse ast sup 8
    [01:02:47.631,225] <inf> [I] ChildSupervsn-: Sending supervision message to child 0x941a
    [01:02:47.631,317] <inf> [I] ChildSupervsn-: sec sinse ast sup 23
    [01:02:47.631,408] <inf> [I] ChildSupervsn-: sec sinse ast sup 9
    uart:~$ [01:02:48.229,797] <inf> coap_server: No temp data
    [01:02:48.571,228] <inf> [I] DataPollHandlr: Rx data poll, src:0x941a, qed_msgs:1, rss:-46, ack-fp:1
    [01:02:48.633,331] <inf> [I] ChildSupervsn-: sec sinse ast sup 1
    [01:02:48.633,453] <inf> [I] ChildSupervsn-: sec sinse ast sup 24
    [01:02:48.633,544] <inf> [I] ChildSupervsn-: sec sinse ast sup 10
    [01:02:49.060,882] <inf> [I] Mle-----------: Send Announce on channel 18
    [01:02:49.067,108] <inf> [I] MeshForwarder-: Sent IPv6 UDP msg, len:83, chksum:81d4, ecn:no, to:0xffff, sec:yes, prio:net
    uart:~$ [01:02:49.067,413] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:28aa:8ef9:4725:83eb]:19788
    [01:02:49.067,657] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    uart:~$ [01:02:49.636,566] <inf> [I] ChildSupervsn-: sec sinse ast sup 2
    [01:02:49.636,688] <inf> [I] ChildSupervsn-: sec sinse ast sup 25
    [01:02:49.636,779] <inf> [I] ChildSupervsn-: sec sinse ast sup 11
    [01:02:49.995,086] <inf> [I] MeshForwarder-: Received IPv6 UDP msg, len:104, chksum:1ae2, ecn:no, from:8a6694118ee9ea9a, sec:no, prio:net, rss:-29.0
    [01:02:49.995,330] <inf> [I] MeshForwarder-:     src:[fe80:0:0:0:8866:9411:8ee9:ea9a]:19788
    uart:~$ [01:02:49.995,574] <inf> [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    [01:02:49.996,551] <inf> [I] Mle-----------: Receive Advertisement (fe80:0:0:0:8866:9411:8ee9:ea9a,0xd400)
    [01:02:50.639,709] <inf> [I] ChildSupervsn-: sec sinse ast sup 3
    [01:02:50.639,801] <inf> [I] ChildSupervsn-: sec sinse ast sup 26
    [01:02:50.639,923] <inf> [I] ChildSupervsn-: sec sinse ast sup 12
    uart:~$ [01:02:51.643,859] <inf> [I] ChildSupervsn-: sec sinse ast sup 4
    [01:02:51.644,012] <inf> [I] ChildSupervsn-: sec sinse ast sup 27
    [01:02:51.644,104] <inf> [I] ChildSupervsn-: sec sinse ast sup 13
    [01:02:52.190,673] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0x7400, sec:yes, prio:normal, rss:-18.0
    --- 10 messages dropped ---
    [01:02:52.233,032] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:7400]
    --- 29 messages dropped ---
    [01:02:52.262,115] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:7400]
    --- 39 messages dropped ---
    uart:~$ --- 10 messages dropped ---
    [01:02:52.279,785] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0xc000, sec:yes, prio:normal, rss:-44.0
    [01:02:52.280,029] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:7400]
    [01:02:52.280,273] <inf> [I] MeshForwarder-:     dst:[ff03:0:0:0:0:0:0:2]
    [01:02:52.282,165] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0x2c00, sec:yes, prio:normal, rss:-28.0
    uart:~$ [01:02:52.282,440] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:7400]
    [01:02:52.282,684] <inf> [I] MeshForwarder-:     dst:[ff03:0:0:0:0:0:0:2]
    [01:02:52.286,926] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0xb000, sec:yes, prio:normal, rss:-52.0
    [01:02:52.287,200] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:7400]
    [01:02:52.287,445] <inf> [I] MeshForwarder-:     dst:[ff03:0:0:0:0:0:0:2]
    uart:~$ [01:02:52.289,855] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0x1c00, sec:yes, prio:normal, rss:-68.0
    [01:02:52.290,100] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:7400]
    [01:02:52.290,496] <inf> [I] MeshForwarder-:     dst:[ff03:0:0:0:0:0:0:2]
    [01:02:52.292,724] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0xa000, sec:yes, prio:normal, rss:-35.0
    [01:02:52.292,999] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:7400]
    uart:~$ [01:02:52.293,273] <inf> [I] MeshForwarder-:     dst:[ff03:0:0:0:0:0:0:2]
    [01:02:52.296,020] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0x0800, sec:yes, prio:normal, rss:-67.0
    [01:02:52.296,264] <inf> [I] MeshForwarder-:     src:[fdde:ad00:beef:0:0:ff:fe00:7400]
    [01:02:52.296,539] <inf> [I] MeshForwarder-:     dst:[ff03:0:0:0:0:0:0:2]
    [01:02:52.302,520] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0xc800, sec:yes, prio:normal, rss:-54.0
    [01:02:52.302,520] <inf> [I] MeshForwarder-: Received IPv6 HopOpts msg, len:86, chksum:0000, ecn:no, from:0xc800, sec:yeK▒ɥ▒▒r▒ɵ▒▒▒ rss:-54.0
    uart:~$â–’â–’â–’â–’â–’â–’mâ–’8Duartâ–’ [01:02:52.302â–’â–’] â–’â–’l:â–’â–’  â–’â–’â–’â–’
    Also, is there a way to detach from a parent and start a renegotiate to connect to a different router? I tried 'ot detach', 'ot thread stop' and 'ot  thread start' from the SED. But I think since the SED is still in the child table of the first parent, all that happens is that I get a new RLOC. I guess if I wait 240 sec timeout, and try thread stop/start, I might get connected to a new router. What do you think?
    Cheers,
    Kaushalya
    But the supervision messages are only between the child and it's parent, so this message is not routed to any other routers than the parent itself. Right?
    How long did it take?
    So this is the log from the router. When did it crash? (timestamp?)
    I would assume it does. But I guess the main issue here is that this is not happening at all times, right?
  • Hi Edvin,
    Sorry about my delay, I was not well past couple of days and only now back in work.
    No the message is send to another router. The parent is just routing it through.
    I think we have identified a potential pitfall in openthread networks. That is partitioning. We think our failure mechanism can be explained by that.
    Think of two routers and a set of sensors (SEDs). If both routers are in the same partition, then no issues. But for whatever reason one router lost its connection to the other, then there will be two network partitions. The problem happens when the Sensors can still reach both routers. If a sensor that is sensing data the router1 suddenly lost its connection and connected to router2, the data path will be broken, but the Sensor will happily stay in the current connection until another MLE session decide to connect back to router1. The issue is for the MLE protocol, every router in range is a potential parent, but this may not work for application data.
    It looks like we cant constrain the MLE process to limit the parent search to its own partition. We can implement a two way handshake from application level and initiate another MLE session from the Sensor, but there is no guarantee that it may not choose a parent from a different partition.
    Sorry Edvin, as this happened when we were not at office, we dont know exactly at what time this happened. So it may be very diff to extract it from the log.
    Cheers,
    Kaushalya
  • Hello Kaushalya,
    Interesting. If the parents split into two different networks, then there will exist two different networks with the same credentials, not able to communicate with one another. And it is not possible to connect the two networks using a SED device.
    The solution is "simple". You need to make sure that if you struggle with that the two partitions of the network can't reach one another, you need to add another router that can reach both the network partitions (so that they are no longer separate partitions).
    I believe this is where we started this conversation. I remember asking for state changes to see if a router became leader (which it will if part of the network splits out in it's own partition).
    Is it an option to add another router making sure the network doesn't split into two partitions?
    Edvin
