Mesh back and forth seems to break connection
We have one customer having two CoAP hosts and some CoAP clients in the form of wireless sensors. The sensors are paired to a single host. The pairing is actually in the app level, where the sensor discovers the network IP of the host in pairing host. All the devices have the same PANID and network key.
Recently we have seen a scenario where some sensors seemingly stopped communication with the paired host. By looking at the RSSI graphs, we thought is this caused by a sensor constantly swinging back and forth between two hosts (one host acting as a router). We dont have access to the CLI interface of the hosts as this is a remote site. We see the Sensor RSSI reported back. This is its RSSI with the router/leader immediately connected to at the time.
Any ideas?
Cheers,
Kaushalya
  • Hello Kaushalya,
    So in theory, if we take out the child sensors, and the two routers send messages back and forth, we could see the same behavior? Do you agree?
    Do you have a state changed callback in your parent's application?
    If you look at e.g. the ncs\nrf\samples\openthread\coap_server sample, in coap_server.c, you can see the on_thread_state_changed() callback.
    Does that trigger when the nodes fall out?
    BR,
    Edvin
  • Hi Edvin,
    What you mean is like shutdown the child sensor? But if we remove child sensor, we loose the data packet origination. So after that the parent and next routers wouldn't get any data packets anyway. So the behavior is not same isn't it, though the end result is the same? Moreover, in this instant, the child sensor is successfully sending the packets.
    Yes we have, as our application is derived of the same example. This is what we have.
    static void on_thread_state_changed(uint32_t flags, void *context)
    	struct openthread_context *ot_context = context;
    	if (flags & OT_CHANGED_THREAD_ROLE) {
    		switch (otThreadGetDeviceRole(ot_context->instance)) {
    		case OT_DEVICE_ROLE_CHILD:
    		case OT_DEVICE_ROLE_ROUTER:
    		case OT_DEVICE_ROLE_LEADER:
    			dk_set_led_on(OT_CONNECTION_LED);
    		case OT_DEVICE_ROLE_DISABLED:
    		case OT_DEVICE_ROLE_DETACHED:
    			dk_set_led_off(OT_CONNECTION_LED);
    			deactivate_provisionig();
    We don't do anything special here. Also in the production hosts, we dont populate this LED.
    I am afraid we don't know. As we only see this issue once it happened. What you suggest is role change from 'router' to 'disabled' kind of? I will check the role of the host once I detect this again. I will populate the LED mentioned above  as well.
    I am trying to understand what the MLE does in the following scenario.
    1. sensor  -> parent router -> destination router - good
    2. sensor -> parent router  -x- destination router - bad
    Q1. If both routers support child supervision, does the supervision packet originate from the destination router or the parent router?
    Q2. Sensor wouldn't know scenario 2 has happened?
    Q3. I guess when scenario 2 happens parent router would try to find another path via MLE? In our case we have about 10 routers all over the lab. One or two may be power cycled or shut down but not all and they are never moved from one place to the other. Also when I shutdown all the other routers, the sensors all connected back to the destination router. That proves there was at least one path to the parent router. (These sensors were about 10-50cm away from the parent router)
    Cheers,
    Kaushalya
    Cheers,
    Kaushalya
    Of course, but I am saying that if you were to generate dummy data at the parent and send it to the destination, in theory we could see the same, because the packets are lost between the parent router and the destination router. I am just thinking of possible ways to easier reproduce the issue.
    Is it possible to add some logging here, to see if there is a state change? It doesn't necessarily change to detached, so printing the actual state change can be helpful, if this is the case.
    I don't understand this question. And I don't understand how child supervision is relevant if the packet is lost between two nodes that are not children.
    Q2: Depends. Is it a message that is supposed to be acknowledged or not? It wouldn't know that the scenario 2 happened, but it can detect a missing acknowledgement. The routers should be able to detect it, though. Because all messages should be acknowledged in the 802.15.4 layer.
    Q3: Could it be that the packet path between the source and destination was through a router that was suddenly powered off? I am not 100% sure of the details, but openthread is not known for being very fast at determining that nodes are gone, and enabling new routes.
    Edvin
  • Hi Edvin,
    Something interesting I saw couple of days ago with a FTD on my desk. Normally when it powers up it connects to the network and change it's state to a router/leader. But this time it stayed on as a child! Now if a router, who is actively routing packets to another router suddenly change state to a child, I guess we can explain the behavior we are discussing here.
    I guess a FTD will remain a child as long as no child connects to it, am I correct? But on the other hand I have seen many instances where a router's child table is empty, but it remains as a router. What conditions determine this transition from child-router and vice versa?
    Sorry, what I was trying to get at is, we implemented child supervision to prevent a SED disconnection from a destination router, but may be not a solution here.
    I can see that in 'coap_send_request (...)' function, it is hard coded to be non-ack type (COAP_TYPE_NON_CON). I dont know if there is a way to request with confirmation using any API.
    Suppose I clone this 'coap_send_request (...)' and modify it to send ACK packet, then I would need to pass a call back with it to know the ack is successful or not?
    This is possible. Our understanding is even it takes time to renegotiate new paths, it should be ok as we are sending temperature info in every 30 sec. Even if the rerout takes couple of minutes, it should be ok. But the issue is once the sensor's (SED)  data is lost, it remains so for days.
    Cheers,
    Kaushalya
  • Hi Edvin,
    Dont know if this is relevant for this issue, but today I saw a parent router going into some error state. I was provisioning and un-provisioning an SED from a FTD for a new fw feature and all of a sudden I noticed the prov reply send by the FTD does not reach the SED. When I look into wireshark log, I could see the parent router not sending the reply back. Also when I had a look at TTM, it showed this parent router grayed out and ext address field was empty. After a while it 'auto-healed' by itself and my provisioning packets are now received by the SED. I wonder if this could be the error state the router ends up when we cant get SED data.
    What do you think?
    Following is a pcap of when the provisioning was working and stopped. Provisioning router is 0xb000, provisioning SED is 0x9423 and the parent router 0x9400
    May-30-prov success and fail.pcapng
    I have also created a separate thread to show the TTM findings. An OpenThread router shown as grayed out in TTM
    Cheers,
    Kaushalya
