Questions about SDFU implentation and security
Hello and thanks for reading,
We are developing for the NRF5340 and one of the features we are very excited about is the OTA firmware updates via the SDFU.
I have followed the instructions here :  Add DFU support to your application and things seem to be working in that the correct services appear when I then look using the NRF app.
I have not yet been able to fully test DFU, because every time I try the app crashes to the homescreen. This is unfortunate; it looks to me like a problem with the mobile app, hopefully it gets fixed soon.
In the meantime, I have two questions about SDFU.
Firstly, does the bootloader perform a full chip erase when new firmware is loaded? Like if I use the DFU to upload a new firmware that is substantially smaller in size, is there a bunch of old code in flash waiting to be stolen?
Secondly, is there any way to tell the NRF to only accept firmware images that are signed or otherwise authenticated? I assume there must be, could you provide me a link to a guide or example or something of how to implement that?
Thank you very much!
    I am trying to reproduce it with the Visual Studio. Could you provide the details on how you encrypt?
    -Amanda H.
  • Hello, and thanks for your constant support.
    When I get it to work I manually invoke imgtool.py from windows command prompt with the command
    C:\ncs\v2.5.0\bootloader\mcuboot>python scripts/imgtool.py sign --key C:/Users/Isaac/Documents/peripheral_hids_mouse/enc-ec256-priv.pem --header-size 0x200 --align 4 --version 0.0.0+0 --pad-header --encrypt C:/Users/Isaac/Documents/peripheral_hids_mouse/enc-ec256-priv.pem --slot-size 0x74000 C:/Users/Isaac/Documents/peripheral_hids_mouse/build/zephyr/app_to_sign.bin C:/Users/Isaac/Documents/peripheral_hids_mouse/build/zephyr/app_update.bin"
    Not sure if this is what you ask for VS Code or not.
    You could add the following configs to child_image/mcuboot/prj.conf to encrypt the image
    CONFIG_BOOT_ENCRYPT_IMAGE=y
    CONFIG_BOOT_ENCRYPTION_KEY_FILE="enc-ec256-priv.pem"
    -Amanda H.
    Thank you for all your support. Per your suggestion, I added the two Configs. This has resulted in some strange behaviour from the build in visual studio. Please take a look at the error message below, I have bolded the relevant portion, and then underlined the paths to the key files:
    FAILED: zephyr/app_update.bin
    cmd.exe /C "cd /D C:\Users\Isaac\Documents\peripheral_hids_mouse\build\modules\mcuboot && C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-objcopy.exe --input-target=ihex --output-target=binary --gap-fill=0xff C:/Users/Isaac/Documents/peripheral_hids_mouse/build/zephyr/mcuboot_primary_app.hex C:/Users/Isaac/Documents/peripheral_hids_mouse/build/zephyr/app_to_sign.bin && C:\ncs\toolchains\c57af46cb7\opt\bin\python.exe C:/ncs/v2.5.0/bootloader/mcuboot/scripts/imgtool.py sign --key C:/ncs/v2.5.0/bootloader/mcuboot/mcubootenc-ec256-priv.pem --header-size 0x200 --align 4 --version 0.0.0+0 --pad-header --encrypt mcubootenc-ec256-priv.pem --slot-size 0x74000 C:/Users/Isaac/Documents/peripheral_hids_mouse/build/zephyr/app_to_sign.bin C:/Users/Isaac/Documents/peripheral_hids_mouse/build/zephyr/app_update.bin"
    As you can see, the path to the key file is wrong, and has somehow set itself to the location of the default key files that come with NRF SDK.
    Where did it get this path from, and how do I correct it?
    Earlier in the build it correctly located the key files:
    MCUBoot bootloader key file: C:/Users/Isaac/Documents/peripheral_hids_mouse/child_image/mcuboot/enc-ec256-priv.pem
    MCUBoot bootloader encryption key file: C:/Users/Isaac/Documents/peripheral_hids_mouse/child_image/mcuboot/enc-ec256-priv.pem
    EDIT: It seems to have worked, let me do a little more testing but somehow doing a second clean build seems to have worked.
  • Everything seems to now be working; I can successfully do an update with the correct key, and it rejects attempts to update with an incorrect key.
    Thank you so much for all your help.
    I have one last little question: right now in the mcuboot proj.config file I have
    CONFIG_BOOT_SIGNATURE_KEY_FILE="enc-ec256-priv.pem"
    Could I instead define it in cmakelists.txt, that way I can make it easier to swap between the dev key and the release key? Something like:
    set(CONFIG_BOOT_SIGNATURE_KEY_FILE \"${CMAKE_CURRENT_SOURCE_DIR}/child_image/mcuboot/enc-ec256-priv.pem\")
