Strange Logging Behaviour when using bt_enable(NULL)
I am trying to run the peripheral_uart example on a custom nrf52833 board and the RTT logs get interrupted with corrupted output unless a long sleep is placed after bt_enable(NULL).
This is the corrupted output:
SEGGER J-Link V7.94a - Real time terminal output
SEGGER J-Link (unknown) V1.0, SN=801036780
Process: JLink.exe
[00:00:00.013,977] <inf> fs_nvs: 6 Sectors of 4096 bytes
[00:00:00.014,038] <inf> fs_nvs: alloc wra: 0, fd0
[00:00:00.014,068] <inf> fs_nvs: data wra: 0, 1c
[00:00:00.014,312] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            c5 93 ba a9 14 4d 8d 05  30 4e 9b 92 d7 71 1e e8 |.....M.. 0N...q..
                                            aa 02 50 3c                                      |..P<
[00:00:00.019,592] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.019,683] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.019,714] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
[00:00:00.020,629] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:00.020,660] <inf> peripheral_uart: Bluetooth initialized
[00:00:00.021,667] <inf> bt_hci_core: Identi0m
[0m
[00:00:38.922,607] <inf> peripheral_uart: Connected 6A:68:37:DD:F5:1A (random)
The only place I could find a similar error was in this post where the identity line was also interrupted with a "0m[0m" however the post didn't focus on this error.
After doing some searching I found this post  where they found adding a 1ms sleep changed the logging behaviour however I required a much longer sleep than 1ms to get the intended behaviour in my case.
When I add a 10000msec sleep after calling bt_enable(NULL) I get the intended logging behaviour:
	err = bt_enable(NULL);
	k_sleep(K_MSEC(10000));
	if (err) {
		error();
Process: JLink.exe
[00:00:00.013,702] <inf> fs_nvs: 6 Sectors of 4096 bytes
[00:00:00.013,732] <inf> fs_nvs: alloc wra: 0, fd0
[00:00:00.013,732] <inf> fs_nvs: data wra: 0, 1c
[00:00:00.014,038] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                            aa 02 50 3c                                      |..P<
[00:00:00.019,195] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.019,226] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
[00:00:00.019,317] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
[00:00:00.020,172] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:10.020,477] <inf> peripheral_uart: Bluetooth initialized
[00:00:10.021,575] <inf> bt_hci_core: Identity: F8:53:36:C3:DB:07 (random)
[00:00:10.021,636] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x1102, manufacturer 0x0059
[00:00:10.021,697] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x1102
[00:00:26.143,707] <inf> peripheral_uart: Connected 6A:68:37:DD:F5:1A (random)
Any idea what is causing this and any idea to fix it without using such a long sleep.
    The logger module, by default (CONFIG_LOG_MODE_DEFERRED=y), stores log messages in a buffer and processes them when the program enters the dedicated logger thread. Therefore, when you have a long-running thread, such as 'main', there's a possibility that the log buffer might become full before the logger thread gets a chance to run. By using k_sleep(), you enable the logger thread to run before the initialization taking place in the main thread is complete.
    Kconfig settings you can experiement with:
     - CONFIG_LOG_MODE_IMMEDIATE=y - process logs immediatly
    CONFIG_LOG_BUFFER_SIZE - increase default buffer size when using deffered mode.
    Vidar
    Thank you for the reply, this explanation made sense to me however neither proposed Kconfig settings had the intended behaviour.
    Increasing the buffer size to 4096 or 8192 did not seem to affect the output and I got the same corrupted log from earlier:
    [00:00:00.019,470] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
    [00:00:00.020,385] <inf> bt_hci_core: No ID address. App must call settings_load()
    [00:00:00.020,416] <inf> peripheral_uart: Bluetooth initialized
    [00:00:00.021,423] <inf> bt_hci_core: Identi0m
    [0m
    Using the immediate log mode did change the output however this is still not the correct output:
    [00:00:00.024,932] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
    [00:00:00.026,641] <inf> bt_hci_core: No ID address. App must call settings_load()
    [00:00:00.027,221] <inf> peripheral_uart: Bluetooth initialized
    [00:00:00.028,717] <inf> bt_hci_core: Identity: F8:53:36:C
    I still only see the intended output when adding the sleep:
    [00:00:00.016,906] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
    [00:00:00.017,791] <inf> bt_hci_core: No ID address. App must call settings_load()
    [00:00:10.018,035] <inf> peripheral_uart: Bluetooth initialized
    [00:00:10.019,134] <inf> bt_hci_core: Identity: F8:53:36:C3:DB:07 (random)
    [00:00:10.019,165] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x1102, manufacturer 0x0059
    [00:00:10.019,256] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x1102
    One thing I did notice is in the output "Bluetooth initialized" is always printed before the identity line, however I believe the identity line is printed inside the bt_enable(NULL) which is called before the LOG_INF("Bluetooth initialized") line, not sure why this is the case.
  • I'm surprised you experience the same with CONFIG_LOG_MODE_IMMEDIATE=y. Can you please try to view the logs with Jlink RTTViewer and see if you get the same results?
    The identity is printed when you call settings_load() after bt_enable().
    My apologies for the delayed reply it was a long weekend for Australia Day.
    The output in RTT viewer output and Vscode output appear to be the same heres the output in RTT viewer:
    00> [00:00:00.014,495] <inf> fs_nvs: 6 Sectors of 4096 bytes
    00> [00:00:00.014,984] <inf> fs_nvs: alloc wra: 0, fd0
    00> [00:00:00.015,411] <inf> fs_nvs: data wra: 0, 1c
    00> [00:00:00.016,082] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
    00>                                             c5 93 ba a9 14 4d 8d 05  30 4e 9b 92 d7 71 1e e8 |.....M.. 0N...q..
    00>                                             aa 02 50 3c                                      |..P<
    00> [00:00:00.024,291] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    00> [00:00:00.024,902] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    00> [00:00:00.025,482] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
    00> [00:00:00.027,130] <inf> bt_hci_core: No ID address. App must call settings_load()
    00> [00:00:00.027,740] <inf> peripheral_uart: Bluetooth initialized
    00> [00:00:00.029,266] <inf> bt_hci_core: Identity: F8:53:36:C
    No worries. Unfortunately, I don’t have a good explanation for the behavior you’re observing. I do experience dropped logs sometimes when the default log buffer is too small, but I don’t recall encountering this issue with 'immediate' logging. If you can share a minimal version of your project here, or through a private support ticket, I will try to reproduce the issue on my end.
