Bluetooth debug causing hard fault / kernel error / ARCH_EXCEPT
I recently flashed my nrf52840dk with the mesh light example and was trying to debug some application key issues I was facing. When I try to step through the code with a debugger, I get the following errors/panic/reset, am I doing something wrong? Is there something special you have to do to debug a bluetooth application?
[00:00:00.007,110] <inf> fs_nvs: nvs_mount: 8 Sectors of 4096 bytes
[00:00:00.007,110] <inf> fs_nvs: nvs_mount: alloc wra: 0, e10
[00:00:00.007,141] <inf> fs_nvs: nvs_mount: data wra: 0, 228
[00:00:00.007,415] <inf> bt_sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                            c5 93 ba a9 14 4d 8d 05  30 4e 9b 92 d7 71 1e e8 |.....M.. 0N...q..
                                            aa 02 50 3c                                      |..P<
[00:00:00.010,925] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.010,986] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
[00:00:00.011,016] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
[00:00:00.011,413] <inf> bt_hci_core: bt_init: No ID address. App must call [00:00:21.570,953] <err> mpsl_init: m_assert_handler: MPSL ASSERT: 108, 812
[00:00:21.570,983] <err> os: hard_fault: ***** HARD FAULT *****
[00:00:21.571,014] <err> os: hard_fault:   Fault escalation (see below)
[00:00:21.571,014] <err> os: hard_fault: ARCH_EXCEPT with reason 3
[00:00:21.571,044] <err> os: esf_dump: r0/a1:  0x00000003  r1/a2:  0x20003d58  r2/a3:  0x20003d58
[00:00:21.571,075] <err> os: esf_dump: r3/a4:  0x20006d70 r12/ip:  0x200043c8 r14/lr:  0x00040155
[00:00:21.571,075] <err> os: esf_dump:  xpsr:  0x41000011
[00:00:21.571,105] <err> os: esf_dump: Faulting instruction address (r15/pc): 0x0003be54
[00:00:21.571,136] <err> os: z_fatal_error: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:21.571,166] <err> os: z_fatal_error: Fault during interrupt handling
[00:00:21.571,228] <err> os: z_fatal_error: Current thread: 0x20003d58 (unknown)
[00:00:21.995,666] <err> fatal_error: k_sys_fatal_error_handler: Resetting system
*** Booting nRF Connect SDK v2.5.0 ***
Initializing...
[00:00:00.007,049] <inf> fs_nvs: nvs_mount: 8 Sectors of 4096 bytes
[00:00:00.007,080] <inf> fs_nvs: nvs_mount: alloc wra: 0, e00
[00:00:00.007,080] <inf> fs_nvs: nvs_mount: data wra: 0, 248
[00:00:00.007,354] <inf> bt_sdc_hci_driver: hci_driver_open: SoftDevice Controller build revision:
                                            aa 02 50 3c                                      |..P<
[00:00:00.010,894] <inf> bt_hci_core: hci_vs_init: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.010,925] <inf> bt_hci_core: hci_vs_init: HW Variant: nRF52x (0x0002)
[00:00:00.010,955] <inf> bt_hci_core: hci_vs_init: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
[00:00:00.011,383] <inf> bt_hci_core: bt_init: No ID address. App must call settings_load()
Bluetooth initialized
[00:00:00.281,555] <inf> bt_hci_core: bt_dev_show_info: Identity: FA:D3:46:9B:4F:AC (random)
[00:00:00.281,585] <inf> bt_hci_core: bt_dev_show_info: HCI: version 5.4 (0x0d) revision 0x1102, manufacturer 0x0059
[00:00:00.281,616] <inf> bt_hci_core: bt_dev_show_info: LMP: version 5.4 (0x0d) subver 0x1102
[00:00:00.291,229] <err> app: set_lightness: set_lightness: 0
[00:00:00.291,259] <err> app: set_lightness: set_lightness: 0
[00:00:00.291,290] <err> app: set_lightness: set_lightness: 0
[00:00:00.291,351] <err> app: set_lightness: set_lightness: 0
Mesh initialized
[00:00:05.720,245] <wrn> bt_l2cap: bt_l2cap_recv: Ignoring data for unknown channel ID 0x003a
