invalid escape sequence \s
Greetings all. I am troubleshooting an issue on my BLE sniffer setup. While I don't 'think' this is causing my actual current failure (Wireshark not detecting COM6) I wanted to verify, if possible, that my 'fix' isn't causing more issues or just flat out wrong.
While testing the .\nrf_sniffer_ble.bat --extcap-interfaces command, I received the following error:
C:\Users\Project Help Desk\AppData\Roaming\Wireshark\extcap\nrf_sniffer_ble.py:187: SyntaxWarning: invalid escape sequence '\s'
"{validation=^\s*((37|38|39)\s*,\s*){0,2}(37|38|39){1}\s*$}{required=true}" % CTRL_ARG_ADVHOP)
C:\Users\Project Help Desk\AppData\Roaming\Wireshark\extcap\nrf_sniffer_ble.py:716: SyntaxWarning: invalid escape sequence '\s'
m = re.search("^\s*rssi\s*(>=?)\s*(-?[0-9]+)\s*$", capture_filter, re.IGNORECASE)
I checked the python code, and made the following changes:
Line 187 Installed:         "{validation=^\s*((37|38|39)\s*,\s*){0,2}(37|38|39){1}\s*$}{required=true}" % CTRL_ARG_ADVHOP)
Line 187 My Edit:          "{validation=^\\s*((37|38|39)\\s*,\\s*){0,2}(37|38|39){1}\\s*$}{required=true}" % CTRL_ARG_ADVHOP)
Line 716 Installed:         m = re.search("^\s*rssi\s*(>=?)\s*(-?[0-9]+)\s*$", capture_filter, re.IGNORECASE)
Line 716 My Edit:         m = re.search("^\\s*rssi\\s*(>=?)\\s*(-?[0-9]+)\\s*$", capture_filter, re.IGNORECASE)
So as you can see, I basically just added an additional \ to the 8 instances of \s*
Because I am troubleshooting an issue with my COM port, and because line 187 is part of get_interfaces(), it has me suspecting that my fix is just wrong. I am fairly new to Python.
My Setup:
Hardware:
Lenovo W541 Laptop
nRF52840DK with NFC Antenna installed and factory supplied USB cable from Mouser.com
Software:
Windows 10 Pro 64: 19045.3930 - Freshly installed for this project and fully updated.
Wireshark: Version 4.2.2 (v4.2.2-0-g404592842786)
nRF Connect For Desktop 4.3.0: Used for launching Programmer
Programmer 4.2.0: Used to flash firmware
Firmware File: sniffer_nrf52840dk_nrf52840_4.1.1.hex
Sniffing Program: nrf_sniffer_for_bluetooth_le_4.1.1 ------- This where I found the nrf_sniffer_ble.py file that is giving me syntax errors. ---------
Python: Python 3.12.1
Any ideas are appreciated.
  • Making the above changes, resolved my Syntax Errors, and now I just get the Wireshark COM Error. The COM error was present before and after my changes. But my changes resolved the syntax error. I am mainly verifying that my fix is valid and not causing issues before I continue to troubleshoot my original error.
    Could you try to downgrade python to v3.11.x?
    We have not yet updated the ble sniffer for v3.12.x compatibility.
    Håkon
  • That did resolve the issue of syntax errors. On a side note, my original changes also resolved my errors and I was able to connect to my com port and pull traces without issue.
    Thanks for reporting this back to us. I'll report this back internally!
    Håkon
  • You can edit the .py file in the folder, search for \s and add a r just before the double quotes. For example, one of the lines was
    And I turned it to:
        m = re.search(r"^\s*rssi\s*(>=?)\s*(-?[0-9]+)\s*$", capture_filter, re.IGNORECASE)
    Notice the r between the open parenthesis and the double quotes.
    I had to edit two such lines. It works now.
