nrf5340 network core default peripherals from dk board devicetree
I feel like I have missed something obvious here, so sorry if I have not read the documentation carefully enough! I have two specific related questions at the very end, but there is quite a lot of preamble...
When building samples (both nrf and Zephyr) for the nrf5340-DK, I have noticed that the devicetree for the app core has the expected uart pins forwarded to the net core (for net core debug information), and the four buttons and leds on the DK are also declared as expected for app core use. All of this is happening in ncs/v2.5.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340_cpuapp_common.dts.
I am confused by the devicetree for the net core, I see the four uart pins as expected, but I also see the four dk buttons and four dk leds which I do not expect to see. These are declared in ncs/v2.5.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts.
I am surprised this does not cause a problem with zephyr trying to give two cores ownership of the same pins. I am also surprised that it does not throw an error during building.
Documentation here states that "In nRF53 family of SoCs, GPIO pins must be explicitly forwarded by the application core to the network core if the latter should drive them."
When debugging the app core for the 'peripheral_lbs' sample, it appears the uart tx/rx pins that are supposed to be forwarded to the net core are still assigned to the app core.
And the net core debug session also shows the uart tx/rx pins have not been forwarded (and neither have any of the dk button/leds).
Questions:
1) Can you clarify why I cannot see the net core uart pins correctly set up in the registers when debugging?
2) Why does the net core default devicetree file (ncs/v2.5.1/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts) include the dk buttons and leds?
Many thanks,
Rich
