Matter lamp example fails build with CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP
I'm trying to test direct XIP in DFU over BT in Matter lamp example on nRF52840 DK using SDK v 2.5.1
In order to test direct XIP I created a project using the sample and added using the same added CONFIG_CHIP_DFU_OVER_BT_SMP=y and CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y to prj.conf in order to enable DFU over BT. That worked quite well.
Then I tried to test direct XIP and, following Build configuration additions for MCUboot in the direct-xip mode documentation, I added
CONFIG_BOOT_DIRECT_XIP=y to child_image\mcuboot\prj.conf and CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP=y to prj.conf. When I tried to build the project I got this error
-- Found partition manager static configuration: C:/nordic/myapps/light_bulb_1/configuration/nrf52840dk_nrf52840/pm_static_dfu.yml
-- Configuring done
CMake Error at C:/nrf_sdk/v2.5.1/modules/lib/matter/config/nrfconnect/chip-module/generate_factory_data.cmake:163 (add_custom_command):
Error evaluating generator expression:
$<TARGET_PROPERTY:partition_manager,PM_FACTORY_DATA_ADDRESS>
Does this example support Direct XIP at all?
