Problem encoding and advertising the BT_UUID_NUS_VAL
Hi. I am working on a project trying to encode the BT_UUID_NUS_VAL into advertising packets without success.
In am using the unicast_server.c file as a reference. There there is the following :
static uint8_t unicast_server_adv_data[] = {
	BT_UUID_16_ENCODE(BT_UUID_ASCS_VAL),
	BT_AUDIO_UNICAST_ANNOUNCEMENT_TARGETED,
	BT_BYTES_LIST_LE16(AVAILABLE_SINK_CONTEXT),
	BT_BYTES_LIST_LE16(AVAILABLE_SOURCE_CONTEXT),
	0x00, /* Metadata length */
This advertises fine as expected. However, instead of advertising BT_UUID_ASCS_VAL which has a simple value of 0x1853, I would like to advertise BT_UUID_NUS_VAL. The problem is that this has a large value of 6e400001-b5a3-f393-e0a9-e50e24dcca9e.
I tried the following without success :
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
How could I go about possibly solving this? Thank you in advance.
  • Hi
    I don't think you should use the unicast file (related to LE audio), to do standard BLE advertising. I'd strongly suggest checking out how advertising the Nordic UART service is done in the peripheral_uart sample, that does just this already. I'd also recommend the Nordic DevAcademy and the Bluetooth Low Energy fundamentals course that explains how to do BLE advertising in detail.
    Simon
  •    Thanks for your reply.
    The peripheral_uart sample uses bt_le_adv_start() to start the advertising. I can't use this in my case due to previous issues.
    I must initialize advertising with bt_mgmt_adv_start() and eventually bt_le_ext_adv_start() gets called. I must use a structure similar to that of unicast_server_adv_data
    So is there no way to advertise the BT_UUID_NUS_VAL this way you mean? Only using the legacy bt_le_adv_start() .
    I've taken the BLE fundamentals course already. Thanks.
  • Hi
    What issues exactly did you have with bt_le_adv_start()? You need to make sure that the mgmt_adv_start() has room for 128 bits for the UUID. What errors are you running into exactly when trying to use bt_mgmt_adv_start() to advertise with the NUS UUID?
    Simon
  •  Hi
    When I try to create the advertising data as follows, for mgmt_adv_start() :
    I get all sorts of issues :
    warning: braces around scalar initializer
      504 |         BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_NUS_VAL),
    ../../../src/audio/streamctrl_broadcast_sink.c:504:9: note: (near initialization for 'adv_data[0]')
    In file included from C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/conn.h:23,
                     from C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/hci.h:16,
                     from C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/buf.h:24,
                     from C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/audio/audio.h:22,
                     from ../../../src/bluetooth/le_audio.h:10,
                     from ../../../src/bluetooth/bt_stream/broadcast/broadcast_sink.h:10,
                     from ../../../src/audio/streamctrl_broadcast_sink.c:13:
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:451:17: error: field name not in record or union initializer
      451 |                 .type = (_type), \
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:466:9: note: in expansion of macro 'BT_DATA'
      466 |         BT_DATA(_type, ((uint8_t []) { _bytes }), \
    ../../../src/audio/streamctrl_broadcast_sink.c:504:9: note: in expansion of macro 'BT_DATA_BYTES'
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:451:17: note: (near initialization for 'adv_data[0]')
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:452:17: error: field name not in record or union initializer
      452 |                 .data_len = (_data_len), \
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:452:17: note: (near initialization for 'adv_data[0]')
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:452:29: warning: excess elements in scalar initializer
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:452:29: note: (near initialization for 'adv_data[0]')
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:453:17: error: field name not in record or union initializer
      453 |                 .data = (const uint8_t *)(_data), \
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:453:17: note: (near initialization for 'adv_data[0]')
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:453:25: warning: excess elements in scalar initializer
    C:/ncs/v2.5.1/zephyr/include/zephyr/bluetooth/bluetooth.h:453:25: note: (near initialization for 'adv_data[0]')
  • Hi
    It seems what you're trying to input in the .type field of your BT_DATA is not recorded or in the union initializer. This should be the type of advertising data field of your application that isn't set correctly it seems. How have you set the advertising type and UUID type in your project?
    Simon
