I'm trying to approach to the Zephyr UART Asynchronous API in SDK 2.5.1 and in the first time I'm testing only the receiving. My simplified code is
#define UART_BUF_SIZE 16
#define UART_RX_TIMEOUT_MS 100
static uint8_t uartDoubleBuffer[ 2 ][ UART_BUF_SIZE ];
static uint8_t *uartBufNext = uartDoubleBuffer[ 1 ];
void Connection_Initialize( void )
uart_callback_set( serialDev, Connection_Async_Callback, NULL );
uart_rx_enable( serialDev, uartDoubleBuffer[ 0 ], UART_BUF_SIZE, UART_RX_TIMEOUT_MS );
void Connection_Async_Callback( const struct device *dev, struct uart_event *evt, void *userData )
ARG_UNUSED( userData );
switch ( evt->type )
case UART_TX_DONE:
LOG_INF( "UART_TX_DONE" );
case UART_RX_RDY:
LOG_INF( "UART_RX_RDY - received %d bytes", evt->data.rx.len );
case UART_RX_BUF_REQUEST:
LOG_INF( "UART_RX_BUF_REQUEST" );
uart_rx_buf_rsp( serialDev, uartBufNext, UART_BUF_SIZE );
case UART_RX_BUF_RELEASED:
LOG_INF( "UART_RX_BUF_RELEASED" );
uartBufNext = evt->data.rx_buf.buf;
case UART_RX_DISABLED:
LOG_INF( "UART_RX_DISABLED" );
Now if I send to my custom board 7 bytes via uart the UART_RX_RDY event rerurns to me not all bytes but always fewer and it stops. In the following logs every row rappresent a sending of 7 bytes:
00> [00:00:14.206,573] <inf> usb_connection: UART_RX_RDY - received 1 bytes 00> [00:00:23.725,830] <inf> usb_connection: UART_RX_RDY - received 5 bytes 00> [00:00:25.374,267] <inf> usb_connection: UART_RX_RDY - received 10 bytes
In the following sendings I can get the lost bytes, but if I want to send only one packet it won't be received.
What am I doing wrong?
EDIT: I noticed that if I send a packet of 16 byte (the length of API's buffers) I get the right behaviour where UART_RX_RDY gives me the correct bytes number received
00> [00:00:01.740,661] <inf> usb_connection: UART_RX_RDY - received 16 bytes 00> [00:00:01.740,692] <inf> usb_connection: UART_RX_BUF_RELEASED 00> [00:00:01.740,692] <inf> usb_connection: UART_RX_BUF_REQUEST 00> [00:01:10.072,387] <inf> usb_connection: UART_RX_RDY - received 16 bytes 00> [00:01:10.072,418] <inf> usb_connection: UART_RX_BUF_RELEASED 00> [00:01:10.072,448] <inf> usb_connection: UART_RX_BUF_REQUEST 00> [00:01:11.766,571] <inf> usb_connection: UART_RX_RDY - received 16 bytes 00> [00:01:11.766,601] <inf> usb_connection: UART_RX_BUF_RELEASED 00> [00:01:11.766,632] <inf> usb_connection: UART_RX_BUF_REQUEST 00> [00:01:13.214,416] <inf> usb_connection: UART_RX_RDY - received 16 bytes 00> [00:01:13.214,447] <inf> usb_connection: UART_RX_BUF_RELEASED 00> [00:01:13.214,447] <inf> usb_connection: UART_RX_BUF_REQUEST
but if I send a packet less than the length of API's buffers UART_RX_RDY gives me a smaller number than the bytes sent. i.e. if I send 14 bytes, in the first sending I get
00> [00:00:07.343,170] <inf> usb_connection: UART_RX_RDY - received 13 bytes
and in the second sending I get
00> [00:00:10.390,441] <inf> usb_connection: UART_RX_RDY - received 3 bytes
00> [00:00:10.390,472] <inf> usb_connection: UART_RX_BUF_RELEASED
00> [00:00:10.390,502] <inf> usb_connection: UART_RX_BUF_REQUEST
00> [00:00:10.391,265] <inf> usb_connection: UART_RX_RDY - received 2 bytes
I tryed to remove the LOG macros and clear the code as much as possible but nothing changed.
