ld.bfd.exe: cannot find -lbt: No such file or directory
I cannot seem to solve this issue with my program build.   here are the details.
I'm using the Seeed XIAO nRF52840 microprocessor.
I'm using a Windows 11 laptop.
est build --build-dir c:/Users/raybo/blexiaotest/build c:/Users/raybo/blexiaotest --pristine --board xiao_ble --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=c:/Users/raybo/blexiaotest/prj.conf -DDTC_OVERLAY_FILE=c:/Users/raybo/blexiaotest/xiao_ble.overlay
-- Application: C:/Users/raybo/blexiaotest
-- CMake version: 3.20.5
-- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.5.1/zephyr/.cache
-- Zephyr version: 3.4.99 (C:/ncs/v2.5.1/zephyr)
-- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
-- Board: xiao_ble
-- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.5.1/zephyr/boards/arm/xiao_ble/xiao_ble.dts
-- Found devicetree overlay: c:/Users/raybo/blexiaotest/xiao_ble.overlay
-- Generated zephyr.dts: C:/Users/raybo/blexiaotest/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Users/raybo/blexiaotest/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Users/raybo/blexiaotest/build/zephyr/dts.cmake
warning: The choice symbol USB_CDC_ACM_LOG_LEVEL_OFF (defined at
subsys/logging/Kconfig.template.log_config:8) was selected (set =y), but no symbol ended up as the
choice selection. See
docs.zephyrproject.org/.../kconfig.html and/or look up
USB_CDC_ACM_LOG_LEVEL_OFF in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
Parsing C:/ncs/v2.5.1/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.5.1/zephyr/boards/arm/xiao_ble/xiao_ble_defconfig'
Merged configuration 'c:/Users/raybo/blexiaotest/prj.conf'
Configuration saved to 'C:/Users/raybo/blexiaotest/build/zephyr/.config'
Kconfig header saved to 'C:/Users/raybo/blexiaotest/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
CMake Warning at C:/ncs/v2.5.1/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
CONFIG_USB_DEVICE_VID has default value 0x2FE3.
This value is only for testing and MUST be configured for USB products.
CMake Warning at C:/ncs/v2.5.1/zephyr/subsys/usb/device/CMakeLists.txt:28 (message):
CONFIG_USB_DEVICE_PID has default value 0x100.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/raybo/blexiaotest/build
[2/187] Generating include/generated/version.h
-- Zephyr version: 3.4.99 (C:/ncs/v2.5.1/zephyr), build: v3.4.99-ncs1-1
[36/187] Building C object CMakeFiles/app.dir/src/main.c.obj
../src/main.c:22:29: warning: 'ad' defined but not used [-Wunused-const-variable=]
22 | static const struct bt_data ad[] = {
[182/187] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\Users\raybo\blexiaotest\build\zephyr && C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.exe -E true""
c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(main.c.obj): in function `my_read_temperature_function':
C:\Users\raybo\blexiaotest\build/../src/main.c:38: undefined reference to `bt_gatt_attr_read'
c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(main.c.obj):(.rodata.attr_custom_srv+0x4): undefined reference to `bt_gatt_attr_read_service'
c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(main.c.obj):(.rodata.attr_custom_srv+0x18): undefined reference to `bt_gatt_attr_read_chrc'
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\Users\raybo\blexiaotest\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Build [pristine]: blexiaotest/build (active)
Building blexiaotest
west build --build-dir c:/Users/raybo/blexiaotest/build c:/Users/raybo/blexiaotest --pristine --board xiao_ble --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=c:/Users/raybo/blexiaotest/prj.conf -DDTC_OVERLAY_FILE=c:/Users/raybo/blexiaotest/xiao_ble.overlay
-- Board: xiao_ble
helpful too.
-- Configuring done
-- Generating done
[39/187] Building C object CMakeFiles/app.dir/src/main.c.obj
c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: cannot find -lbt: No such file or directory
-- Board: xiao_ble
helpful too.
-- Configuring done
-- Generating done
Here is the main.c code.
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/uuid.h>
LOG_MODULE_REGISTER(ble_test);
// UUID custom service
#define BT_UUID_MY_CUSTOM_SERV_VAL BT_UUID_128_ENCODE(0x12297f0a, 0x0836, 0x46d5, 0xbfad, 0xf1dfdbb61964)
// 64, 19, B6, DB, DF, F1, AD, BF, D5, 46, 36, 08, 0A, 7F, 29, 12
#define BT_UUID_MY_CUSTOM_SERVICE BT_UUID_DECLARE_128(BT_UUID_MY_CUSTOM_SERV_VAL)
// UUID of my own TEMPERATURE Characteristic
#define BT_UUID_MY_TEMPERATURE_CHRC_VAL BT_UUID_128_ENCODE(0x12297f0a, 0x0836, 0x46d5, 0xbfad, 0xf1dfdbb61965)
#define BT_UUID_MY_TEMPERATURE_CHRC BT_UUID_DECLARE_128(BT_UUID_MY_TEMPERATURE_CHRC_VAL)
volatile bool ble_ready = false;
int32_t temperature = 241234;
    BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_MY_CUSTOM_SERV_VAL),
ssize_t my_read_temperature_function(struct bt_conn *conn,
                                     const struct bt_gatt_attr *attr, void *buf,
                                     uint16_t len, uint16_t offset);
BT_GATT_SERVICE_DEFINE(custom_srv,
                       BT_GATT_PRIMARY_SERVICE (BT_UUID_MY_CUSTOM_SERVICE),
                       BT_GATT_CHARACTERISTIC(BT_UUID_MY_TEMPERATURE_CHRC, BT_GATT_CHRC_READ, BT_GATT_PERM_READ, my_read_temperature_function, NULL, NULL));
                                     uint16_t len, uint16_t offset){
    return bt_gatt_attr_read(conn, attr, buf, len, offset, &temperature, sizeof(temperature));
void bt_ready(int err)
    if (err)
        LOG_ERR("bt enable return %d", err);
    LOG_INF("bt_ready!");
    ble_ready = true;
