aws_iot example without network offloading
I would like to know how to build the aws_iot example without network offloading to the modem. I need to make AWS connections through both the nRF9160’s LTE-M connection as well as through an Ethernet ENC424J600 controller (PHYTEC link board ETH or equivalent), only one of these two interfaces will be enabled at a time.
As I understand it, if I want to use more than one interface in my app, I have to disable sockets offloading (CONFIG_NET_SOCKETS_OFFLOAD=n), but doing that prevents enabling LTE connectivity (CONFIG_LTE_CONNECTIVITY=y). Hence my issues of having everything somehow use MbedTLS and being transparent to the AWS IoT library.
I have spent weeks trying to make the examples work independently and together (aws_iot, aws_iot_mqtt (which I cannot get to compile for the nRF9160DK because of build errors with TF-M), https_client and others) and cannot get anywhere close to where I need… I can make the dns_resolve work over Ethernet for example, by disabling the sockets offloading so that getaddrinfo() properly calls dns_get_addr_info() and such but putting everything together is a nightmare because of configuration incompatibilities with nRF Modem’s libraries…
I hope someone has any idea to help me here, thanks!
  • I’ve been experimenting a bit more with this sample and using only Ethernet as a first step, I’m now having errors when doing the TLS handshake. I attach the project (my Ethernet configuration is in the “prj-ethernet.overlay.conf" file), here is the log I’m getting with MbedTLS debug enabled:
    *** Booting nRF Connect SDK v2.5.0 ***
    [00:00:00.394,714] <inf> aws_iot_sample: The AWS IoT sample started, version: v1.0.0
    [00:00:00.394,744] <inf> aws_iot_sample: Bringing network interface up and connecting to the network
    [00:00:00.394,805] <inf> aws_iot_sample: Start on enc424j600@0: index=1
    [00:00:02.086,578] <inf> ethdrv: Link up
    [00:00:02.087,188] <inf> ethdrv: 100Mbps
    [00:00:02.087,219] <inf> ethdrv: full duplex
    [00:00:02.102,508] <dbg> net_ctx: net_context_bind: (rx_q[0]): Context 0x20003204 binding to UDP 0.0.0.0:42223 iface 1 (0x20001018)
    [00:00:02.107,940] <inf> net_dhcpv4: Received: 192.168.6.79
    [00:00:02.108,123] <inf> aws_iot_sample: DHCP Successful!
    [00:00:02.108,184] <inf> aws_iot_sample: IPv4 address: 192.168.6.79
    [00:00:02.108,215] <inf> aws_iot_sample: Lease time: 82800 seconds
    [00:00:02.108,276] <inf> aws_iot_sample: Subnet: 255.255.255.0
    [00:00:02.108,337] <inf> aws_iot_sample: Router: 192.168.6.1
    [00:00:02.108,581] <inf> aws_iot_sample: Network connectivity established
    [00:00:07.108,703] <inf> aws_iot_sample: Connecting to AWS IoT
    [00:00:07.108,795] <inf> aws_iot_sample: Next connection retry in 30 seconds
    [00:00:07.108,856] <inf> aws_iot_sample: AWS_IOT_EVT_CONNECTING
    [00:00:07.147,033] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:07.147,094] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:07.147,155] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:07.147,186] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): getaddrinfo entries overflow
    [00:00:07.147,247] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -103
    [00:00:07.147,583] <dbg> net_sock_tls: tls_alloc: (aws_connection_poll_thread): Allocated TLS context, 0x200019d8
    [00:00:07.148,101] <dbg> net_sock: zsock_socket_internal: (aws_connection_poll_thread): socket: ctx=0x200032a8, fd=1
    [00:00:07.148,162] <dbg> net_mqtt_sock_tls: mqtt_client_tls_connect: (aws_connection_poll_thread): Created socket 0
    [00:00:07.148,559] <dbg> net_ctx: net_context_bind: (aws_connection_poll_thread): Context 0x200032a8 binding to TCP 0.0.0.0:36687 iface 1 (0x20001018)
    [00:00:07.313,568] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9222: got signature scheme [401] rsa_pkcs1_sha256
    --- 24 messages dropped ---
    [00:00:07.313,659] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9230: sent signature scheme [401] rsa_pkcs1_sha256
    [00:00:07.313,781] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0276: client hello, adding max_fragment_length extension
    [00:00:07.313,873] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0671: client hello, total extension length: 17
    [00:00:07.313,995] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0673: dumping 'client hello extensions' (17 bytes)
    [00:00:07.314,270] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0673: 0000:  00 11 00 0d 00 08 00 06 06 01 05 01 04 01 00 01  ................
    [00:00:07.314,453] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0673: 0010:  00                                               .
    [00:00:07.314,697] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2634: => write handshake message
    [00:00:07.314,788] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2801: => write record
    [00:00:07.314,910] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2889: output record: msgtype = 22, version = [3:3], msglen = 72
    [00:00:07.315,032] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: dumping 'output record sent to network' (77 bytes)
    [00:00:07.315,277] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0000:  16 03 03 00 48 01 00 00 44 03 03 a2 8a dc e8 5b  ....H...D......[
    [00:00:07.315,582] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0010:  e3 bf 7c 0b b1 4d 84 93 c4 45 7a fa 5e 6e 59 d8  ..|..M...Ez.^nY.
    [00:00:07.315,856] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0020:  5d 0d 6c a3 e4 59 08 aa 50 4e 35 00 00 0a 00 3d  ].l..Y..PN5....=
    [00:00:07.316,131] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0030:  00 35 00 3c 00 2f 00 ff 01 00 00 11 00 0d 00 08  .5.<./..........
    [00:00:07.316,375] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0040:  00 06 06 01 05 01 04 01 00 01 00 01 02           .............
    [00:00:07.316,436] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2945: <= write record
    [00:00:07.316,528] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2762: <= write handshake message
    [00:00:07.316,619] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0996: <= write client hello
    [00:00:07.316,711] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:07.316,802] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2202: message length: 77, out_left: 77
    [00:00:07.610,504] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2209: ssl->f_send() returned 77 (-0xffffffb3)
    [00:00:07.610,717] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2237: <= flush output
    [00:00:07.611,785] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:00:07.611,511] <err> ethdrv: Unknown Interrupt, EIR: 0x0788
    [00:00:07.611,877] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1231: => parse server hello
    [00:00:07.611,938] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4010: => read record
    [00:00:07.611,999] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:07.612,091] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 0, nb_want: 5
    [00:00:07.612,182] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 0, nb_want: 5
    [00:00:07.612,274] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3816: <= handshake
    [00:00:07.629,638] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x200032a8, pkt=0x2000fbbc, st=0, user_data=0
    [00:00:07.632,263] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x200032a8, pkt=0x2000fc00, st=0, user_data=0
    [00:00:07.754,272] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1739: <= parse server hello
    --- 44 messages dropped ---
    [00:00:07.754,364] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:07.754,425] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2196: <= flush output
    [00:00:07.754,547] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:07.754,608] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7340: => parse certificate
    [00:00:07.754,699] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4010: => read record
    [00:00:07.754,791] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:07.754,882] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 0, nb_want: 5
    [00:00:07.755,004] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 0, nb_want: 5
    [00:00:07.755,126] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2152: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:00:07.755,187] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2172: <= fetch input
    [00:00:07.755,310] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: dumping 'input record header' (5 bytes)
    [00:00:07.755,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: 0000:  16 03 03 13 8d                                   .....
    [00:00:07.755,676] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3741: input record: msgtype = 22, version = [0x303], msglen = 5005
    [00:00:07.755,737] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:07.755,828] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1980: requesting more data than fits
    [00:00:07.755,950] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4788: mbedtls_ssl_fetch_input() returned -28928 (-0x7100)
    [00:00:07.756,072] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4043: ssl_get_next_record() returned -28928 (-0x7100)
    [00:00:07.756,164] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7363: mbedtls_ssl_read_record() returned -28928 (-0x7100)
    [00:00:07.756,256] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3816: <= handshake
    [00:00:07.756,286] <err> net_sock_tls: TLS handshake error: -7100
    [00:00:07.757,049] <dbg> net_sock: z_impl_zsock_close: (aws_connection_poll_thread): close: ctx=0x200019d8, fd=0
    [00:00:07.757,110] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5961: => write close notify
    [00:00:07.757,202] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5974: <= write close notify
    [00:00:07.758,361] <dbg> net_sock: z_impl_zsock_close: (aws_connection_poll_thread): close: ctx=0x200032a8, fd=1
    [00:00:07.758,453] <dbg> net_sock: zsock_flush_queue: (aws_connection_poll_thread): discarding pkt 0x2000fbbc
    [00:00:07.758,544] <dbg> net_sock: zsock_flush_queue: (aws_connection_poll_thread): discarding pkt 0x2000fc00
    mqtt_connect: Software caused connection abort
    [00:00:08.078,460] <err> aws_iot: mqtt_connect, error: -113
    [00:00:08.078,521] <err> aws_iot: AWS broker connect failed -113
    [00:00:08.079,223] <err> ethdrv: Unknown Interrupt, EIR: 0x0788
    [00:00:08.083,648] <inf> aws_iot_sample: AWS_IOT_EVT_CONNECTING
    [00:00:10.076,141] <dbg> net_ctx: net_context_unref: (tcp_work): Context 0x200032a8 released
    Increasing MBEDTLS_SSL_MAX_CONTENT_LEN to 6000 (from the default MTU size 1500) gives this:
    [00:00:00.388,793] <inf> aws_iot_sample: The AWS IoT sample started, version: v1.0.0
    [00:00:00.388,824] <inf> aws_iot_sample: Bringing network interface up and connecting to the network
    [00:00:00.388,885] <inf> aws_iot_sample: Start on enc424j600@0: index=1
    [00:00:02.079,650] <inf> ethdrv: Link up
    [00:00:02.080,291] <inf> ethdrv: 100Mbps
    [00:00:02.080,322] <inf> ethdrv: full duplex
    [00:00:02.095,336] <dbg> net_ctx: net_context_bind: (rx_q[0]): Context 0x20003a34 binding to UDP 0.0.0.0:52490 iface 1 (0x20001048)
    [00:00:02.100,311] <inf> net_dhcpv4: Received: 192.168.6.79
    [00:00:02.100,494] <inf> aws_iot_sample: DHCP Successful!
    [00:00:02.100,555] <inf> aws_iot_sample: IPv4 address: 192.168.6.79
    [00:00:02.100,585] <inf> aws_iot_sample: Lease time: 82800 seconds
    [00:00:02.100,616] <inf> aws_iot_sample: Subnet: 255.255.255.0
    [00:00:02.100,677] <inf> aws_iot_sample: Router: 192.168.6.1
    [00:00:02.100,952] <inf> aws_iot_sample: Network connectivity established
    [00:00:07.101,043] <inf> aws_iot_sample: Connecting to AWS IoT
    [00:00:07.101,135] <inf> aws_iot_sample: Next connection retry in 30 seconds
    [00:00:07.101,196] <inf> aws_iot_sample: AWS_IOT_EVT_CONNECTING
    [00:00:07.125,732] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:07.125,793] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:07.125,854] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -100
    [00:00:07.125,885] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): getaddrinfo entries overflow
    [00:00:07.125,946] <dbg> net_sock_addr: dns_resolve_cb: (rx_q[0]): dns status: -103
    [00:00:07.126,251] <dbg> net_sock_tls: tls_alloc: (aws_connection_poll_thread): Allocated TLS context, 0x20002208
    [00:00:07.126,739] <dbg> net_sock: zsock_socket_internal: (aws_connection_poll_thread): socket: ctx=0x20003ad8, fd=1
    [00:00:07.126,831] <dbg> net_mqtt_sock_tls: mqtt_client_tls_connect: (aws_connection_poll_thread): Created socket 0
    [00:00:07.127,197] <dbg> net_ctx: net_context_bind: (aws_connection_poll_thread): Context 0x20003ad8 binding to TCP 0.0.0.0:53820 iface 1 (0x20001048)
    [00:00:07.285,034] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:1221: The SSL configuration is tls12 only.
    [00:00:07.286,621] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3805: => handshake
    [00:00:07.286,682] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:07.286,773] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2196: <= flush output
    [00:00:07.286,865] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_HELLO_REQUEST
    [00:00:07.286,926] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:07.286,987] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2196: <= flush output
    [00:00:07.287,109] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_CLIENT_HELLO
    [00:00:07.287,170] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0927: => write client hello
    [00:00:07.287,475] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0485: dumping 'client hello, random bytes' (32 bytes)
    [00:00:07.287,750] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0485: 0000:  a4 b6 a5 2a aa 1c 25 c1 43 01 72 a6 e2 46 98 6d  ...*..%.C.r..F.m
    [00:00:07.288,024] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0485: 0010:  10 5f 8c 67 ad 6d 3b 21 2b 5c 9e a3 13 68 35 a5  ._.g.m;!+\...h5.
    [00:00:07.288,116] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0510: dumping 'session id' (0 bytes)
    [00:00:07.288,238] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0367: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:00:07.288,360] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0367: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:00:07.288,482] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0367: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:00:07.288,574] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0367: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:00:07.288,665] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0386: adding EMPTY_RENEGOTIATION_INFO_SCSV
    [00:00:07.288,757] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0395: client hello, got 5 cipher suites
    [00:00:07.288,848] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9202: adding signature_algorithms extension
    [00:00:07.288,940] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9222: got signature scheme [601] rsa_pkcs1_sha512
    [00:00:07.289,031] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9230: sent signature scheme [601] rsa_pkcs1_sha512
    [00:00:07.289,154] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9222: got signature scheme [501] rsa_pkcs1_sha384
    [00:00:07.289,245] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9230: sent signature scheme [501] rsa_pkcs1_sha384
    [00:00:07.289,337] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9222: got signature scheme [401] rsa_pkcs1_sha256
    [00:00:07.289,459] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9230: sent signature scheme [401] rsa_pkcs1_sha256
    [00:00:07.289,550] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0276: client hello, adding max_fragment_length extension
    [00:00:07.289,642] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0671: client hello, total extension length: 17
    [00:00:07.289,733] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0673: dumping 'client hello extensions' (17 bytes)
    [00:00:07.290,008] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0673: 0000:  00 11 00 0d 00 08 00 06 06 01 05 01 04 01 00 01  ................
    [00:00:07.290,191] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0673: 0010:  00                                               .
    [00:00:07.290,405] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2634: => write handshake message
    [00:00:07.290,466] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2801: => write record
    [00:00:07.290,588] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2889: output record: msgtype = 22, version = [3:3], msglen = 72
    [00:00:07.290,710] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: dumping 'output record sent to network' (77 bytes)
    [00:00:07.290,954] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0000:  16 03 03 00 48 01 00 00 44 03 03 a4 b6 a5 2a aa  ....H...D.....*.
    [00:00:07.291,229] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0010:  1c 25 c1 43 01 72 a6 e2 46 98 6d 10 5f 8c 67 ad  .%.C.r..F.m._.g.
    [00:00:07.291,473] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0020:  6d 3b 21 2b 5c 9e a3 13 68 35 a5 00 00 0a 00 3d  m;!+\...h5.....=
    [00:00:07.291,748] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0030:  00 35 00 3c 00 2f 00 ff 01 00 00 11 00 0d 00 08  .5.<./..........
    [00:00:07.291,992] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0040:  00 06 06 01 05 01 04 01 00 01 00 01 04           .............
    [00:00:07.292,053] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2945: <= write record
    [00:00:07.292,144] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2762: <= write handshake message
    [00:00:07.292,205] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0996: <= write client hello
    [00:00:07.292,266] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:07.292,358] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2202: message length: 77, out_left: 77
    [00:00:07.890,808] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2209: ssl->f_send() returned 77 (-0xffffffb3)
    [00:00:07.891,693] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2237: <= flush output
    [00:00:07.891,784] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:00:07.891,845] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1231: => parse server hello
    [00:00:07.891,937] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4010: => read record
    [00:00:07.891,998] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:07.892,089] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 0, nb_want: 5
    [00:00:07.892,181] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 0, nb_want: 5
    [00:00:07.893,188] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3816: <= handshake
    [00:00:07.901,519] <err> ethdrv: Unknown Interrupt, EIR: 0x0788
    [00:00:07.907,196] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x2000ffec, st=0, user_data=0
    [00:00:07.907,592] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x20010030, st=0, user_data=0
    [00:00:08.036,804] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3805: => handshake
    [00:00:08.036,895] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:08.036,956] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2196: <= flush output
    [00:00:08.037,048] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:00:08.037,139] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1231: => parse server hello
    [00:00:08.037,200] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4010: => read record
    [00:00:08.037,261] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:08.037,353] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 0, nb_want: 5
    [00:00:08.037,475] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 0, nb_want: 5
    [00:00:08.037,597] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2152: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:00:08.037,689] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2172: <= fetch input
    [00:00:08.037,780] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: dumping 'input record header' (5 bytes)
    [00:00:08.037,994] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: 0000:  16 03 03 00 51                                   ....Q
    [00:00:08.038,116] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3741: input record: msgtype = 22, version = [0x303], msglen = 81
    [00:00:08.038,177] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:08.038,269] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 5, nb_want: 86
    [00:00:08.231,903] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: dumping 'input record from network' (86 bytes)
    --- 4 messages dropped ---
    [00:00:08.232,666] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0020:  41 4f 4a 8c 24 cb 63 a1 88 f6 b5 20 01 98 c8 f0  AOJ.$.c.... ....
    --- 1 messages dropped ---
    [00:00:08.233,734] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0030:  e8 6b f6 06 ab 9a 8c 12 e6 65 2b c3 f9 14 e9 24  .k.......e+....$
    [00:00:08.234,008] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0040:  88 1e 6e 54 a2 12 c0 b7 82 ef a1 90 00 3c 00 00  ..nT.........<..
    [00:00:08.234,222] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0050:  05 ff 01 00 01 00                                ......
    [00:00:08.234,375] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3096: handshake message: msglen = 81, type = 2, hslen = 81
    [00:00:08.234,924] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4084: <= read record
    [00:00:08.235,687] <err> ethdrv: Unknown Interrupt, EIR: 0x0788
    [00:00:08.235,992] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1314: dumping 'server hello, version' (2 bytes)
    [00:00:08.236,175] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1314: 0000:  03 03                                            ..
    [00:00:08.236,267] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1333: server hello, current time: 1916759440
    [00:00:08.236,389] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1343: dumping 'server hello, random bytes' (32 bytes)
    [00:00:08.236,633] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1343: 0000:  72 3f 6d 90 fa 25 20 8d ea db a0 71 b9 b7 6a 53  r?m..% ....q..jS
    [00:00:08.236,907] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1343: 0010:  3c d3 a1 5f 9d 41 4f 4a 8c 24 cb 63 a1 88 f6 b5  <.._.AOJ.$.c....
    [00:00:08.236,999] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1415: server hello, session id len.: 32
    [00:00:08.237,091] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1416: dumping 'server hello, session id' (32 bytes)
    [00:00:08.237,365] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1416: 0000:  01 98 c8 f0 e8 6b f6 06 ab 9a 8c 12 e6 65 2b c3  .....k.......e+.
    [00:00:08.237,609] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1416: 0010:  f9 14 e9 24 88 1e 6e 54 a2 12 c0 b7 82 ef a1 90  ...$..nT........
    [00:00:08.237,701] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1443: no session has been resumed
    [00:00:08.237,792] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1446: server hello, chosen ciphersuite: 003c
    [00:00:08.237,884] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1447: server hello, compress alg.: 0
    [00:00:08.237,976] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1486: server hello, chosen ciphersuite: TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:00:08.238,067] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1509: server hello, total extension length: 5
    [00:00:08.238,159] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1531: found renegotiation extension
    [00:00:08.238,220] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1739: <= parse server hello
    [00:00:08.238,311] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:08.238,372] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2196: <= flush output
    [00:00:08.238,464] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:08.238,555] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7340: => parse certificate
    [00:00:08.238,616] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4010: => read record
    [00:00:08.238,677] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:08.238,769] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 0, nb_want: 5
    [00:00:08.238,891] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 0, nb_want: 5
    [00:00:08.239,013] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2152: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:00:08.239,074] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2172: <= fetch input
    [00:00:08.239,166] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: dumping 'input record header' (5 bytes)
    [00:00:08.239,379] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: 0000:  16 03 03 13 8d                                   .....
    [00:00:08.239,501] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3741: input record: msgtype = 22, version = [0x303], msglen = 5005
    [00:00:08.239,562] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:08.239,654] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 5, nb_want: 5010
    [00:00:08.239,898] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 5, nb_want: 5010
    [00:00:08.239,990] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2152: ssl->f_recv(_timeout)() returned 677 (-0xfffffd5b)
    [00:00:08.240,112] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 682, nb_want: 5010
    [00:00:08.240,203] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3816: <= handshake
    [00:00:08.247,253] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x20010030, st=0, user_data=0
    [00:00:08.261,962] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x2000ffa8, st=0, user_data=0
    [00:00:08.618,041] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x2000ff64, st=0, user_data=0
    [00:00:08.869,598] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3805: => handshake
    [00:00:08.869,689] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:08.869,750] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2196: <= flush output
    [00:00:08.869,873] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:08.869,934] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7340: => parse certificate
    [00:00:08.869,995] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4010: => read record
    [00:00:08.870,086] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:08.870,147] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 682, nb_want: 5
    [00:00:08.870,239] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2172: <= fetch input
    [00:00:08.870,330] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: dumping 'input record header' (5 bytes)
    [00:00:08.870,574] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: 0000:  16 03 03 13 8d                                   .....
    [00:00:08.870,666] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3741: input record: msgtype = 22, version = [0x303], msglen = 5005
    [00:00:08.870,758] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:08.870,849] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 682, nb_want: 5010
    [00:00:08.896,423] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x2000ffa8, st=0, user_data=0
    [00:00:08.896,789] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x2000ff64, st=0, user_data=0
    [00:00:09.066,528] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 682, nb_want: 5010
    [00:00:09.066,680] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2152: ssl->f_recv(_timeout)() returned 1365 (-0xfffffaab)
    [00:00:09.069,274] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 2047, nb_want: 5010
    [00:00:09.069,366] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2152: ssl->f_recv(_timeout)() returned 1363 (-0xfffffaad)
    [00:00:09.069,488] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2149: in_left: 3410, nb_want: 5010
    [00:00:09.069,580] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3816: <= handshake
    [00:00:09.087,371] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x2000ff64, st=0, user_data=0
    [00:00:09.087,768] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x20003ad8, pkt=0x2000ffa8, st=0, user_data=0
    [00:00:09.087,890] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3805: => handshake
    [00:00:09.087,951] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:09.088,043] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2196: <= flush output
    [00:00:09.088,134] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3724: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:09.088,226] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7340: => parse certificate
    [00:00:09.088,287] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4010: => read record
    [00:00:09.088,348] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:09.088,439] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 3410, nb_want: 5
    [00:00:09.088,500] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2172: <= fetch input
    [00:00:09.088,623] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: dumping 'input record header' (5 bytes)
    [00:00:09.088,836] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3739: 0000:  16 03 03 13 8d                                   .....
    [00:00:09.088,928] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3741: input record: msgtype = 22, version = [0x303], msglen = 5005
    [00:00:09.089,019] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1970: => fetch input
    [00:00:09.089,111] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2124: in_left: 3410, nb_want: 5010
    [00:00:09.430,358] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0e50:  80 89 6c cf 28 03 18 83 47 79 a3 10 7e 30 5b ac  ..l.(...Gy..~0[.
    --- 253 messages dropped ---
    [00:00:09.430,633] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0e60:  3b b0 60 e0 77 d4 08 a6 e1 1d 7c 5e c0 bb f9 9a  ;.`.w.....|^....
    [00:00:09.430,908] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0e70:  7b 22 9d a7 00 09 7e ac 46 17 83 dc 9c 26 57 99  {"....~.F....&W.
    [00:00:09.431,182] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0e80:  30 39 62 96 8f ed da de aa c5 cc 1b 3e ca 43 68  09b.........>.Ch
    [00:00:09.431,457] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0e90:  6c 57 16 bc d5 0e 20 2e fe ff c2 6a 5d 2e a0 4a  lW.... ....j]..J
    [00:00:09.431,732] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0ea0:  6d 14 58 87 94 e6 39 31 5f 7c 73 cb 90 88 6a 84  m.X...91_|s...j.
    [00:00:09.431,976] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0eb0:  11 96 27 a6 ed d9 81 46 a6 7e a3 72 00 0a 52 3e  ..'....F.~.r..R>
    [00:00:09.432,250] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0ec0:  83 88 07 63 77 89 69 17 0f 39 85 d2 ab 08 45 4d  ...cw.i..9....EM
    [00:00:09.432,525] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0ed0:  d0 51 3a fd 5d 5d 37 64 4c 7e 30 b2 55 24 42 9d  .Q:.]]7dL~0.U$B.
    [00:00:09.432,800] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0ee0:  36 b0 5d 9c 17 81 61 f1 ca f9 10 02 24 ab eb 0d  6.]...a.....$...
    [00:00:09.433,074] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0ef0:  74 91 8d 7b 45 29 50 39 88 b2 a6 89 35 25 1e 14  t..{E)P9....5%..
    [00:00:09.433,349] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f00:  6a 47 23 31 2f 5c 9a fa ad 9a 0e 62 51 a4 2a a9  jG#1/\.....bQ.*.
    [00:00:09.433,624] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f10:  c4 f9 34 9d 21 18 00 04 79 30 82 04 75 30 82 03  ..4.!...y0..u0..
    [00:00:09.433,898] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f20:  5d a0 03 02 01 02 02 09 00 a7 0e 4a 4c 34 82 b7  ]..........JL4..
    [00:00:09.434,143] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f30:  7f 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05 00  .0...*.H........
    [00:00:09.434,417] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f40:  30 68 31 0b 30 09 06 03 55 04 06 13 02 55 53 31  0h1.0...U....US1
    [00:00:09.434,692] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f50:  25 30 23 06 03 55 04 0a 13 1c 53 74 61 72 66 69  %0#..U....Starfi
    [00:00:09.434,967] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f60:  65 6c 64 20 54 65 63 68 6e 6f 6c 6f 67 69 65 73  eld Technologies
    [00:00:09.435,241] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f70:  2c 20 49 6e 63 2e 31 32 30 30 06 03 55 04 0b 13  , Inc.1200..U...
    [00:00:09.435,516] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f80:  29 53 74 61 72 66 69 65 6c 64 20 43 6c 61 73 73  )Starfield Class
    [00:00:09.435,791] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0f90:  20 32 20 43 65 72 74 69 66 69 63 61 74 69 6f 6e   2 Certification
    [00:00:09.436,065] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0fa0:  20 41 75 74 68 6f 72 69 74 79 30 1e 17 0d 30 39   Authority0...09
    [00:00:09.436,309] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0fb0:  30 39 30 32 30 30 30 30 30 30 5a 17 0d 33 34 30  0902000000Z..340
    [00:00:09.436,584] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0fc0:  36 32 38 31 37 33 39 31 36 5a 30 81 98 31 0b 30  628173916Z0..1.0
    [00:00:09.436,859] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0fd0:  09 06 03 55 04 06 13 02 55 53 31 10 30 0e 06 03  ...U....US1.0...
    [00:00:09.437,133] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0fe0:  55 04 08 13 07 41 72 69 7a 6f 6e 61 31 13 30 11  U....Arizona1.0.
    [00:00:09.437,408] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3851: 0ff0:  06 03 55 04 07 13 0a 53 63 6f 74 74 73 64 61 6c  ..U....Scottsdal
    [00:00:09.437,530] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3096: handshake message: msglen = 5005, type = 11, hslen = 5005
    [00:00:09.446,960] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4084: <= read record
    [00:00:09.448,242] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5039: => send alert message
    [00:00:09.448,364] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5040: send alert level=2 message=80
    [00:00:09.448,425] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2801: => write record
    [00:00:09.448,547] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2889: output record: msgtype = 21, version = [3:3], msglen = 2
    [00:00:09.448,669] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: dumping 'output record sent to network' (7 bytes)
    [00:00:09.448,883] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2894: 0000:  15 03 03 00 02 02 50                             ......P
    [00:00:09.448,974] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2185: => flush output
    [00:00:09.449,066] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2202: message length: 7, out_left: 7
    [00:00:10.042,846] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2209: ssl->f_send() returned 7 (-0xfffffff9)
    [00:00:10.042,938] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2237: <= flush output
    [00:00:10.042,999] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2945: <= write record
    [00:00:10.043,975] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5052: <= send alert message
    [00:00:10.044,097] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7001:  mbedtls_x509_crt_parse_der() returned -10368 (-0x2880)
    [00:00:10.045,379] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:3816: <= handshake
    [00:00:10.045,410] <err> net_sock_tls: TLS handshake error: -2880
    [00:00:10.047,729] <dbg> net_sock: z_impl_zsock_close: (aws_connection_poll_thread): close: ctx=0x20002208, fd=0
    [00:00:10.047,790] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5961: => write close notify
    [00:00:10.047,882] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5974: <= write close notify
    [00:00:10.049,957] <err> ethdrv: Unknown Interrupt, EIR: 0x0788
    [00:00:10.051,513] <dbg> net_sock: z_impl_zsock_close: (aws_connection_poll_thread): close: ctx=0x20003ad8, fd=1
    [00:00:10.051,574] <dbg> net_sock: zsock_flush_queue: (aws_connection_poll_thread): discarding pkt 0x2000ffa8
    [00:00:10.051,696] <err> aws_iot: mqtt_connect, error: -113
    [00:00:10.051,727] <err> aws_iot: AWS broker connect failed -113
    [00:00:10.058,166] <inf> aws_iot_sample: AWS_IOT_EVT_CONNECTING
    [00:00:12.038,177] <dbg> net_ctx: net_context_unref: (tcp_work): Context 0x20003ad8 released
    [00:00:16.938,385] <err> ethdrv: Unknown Interrupt, EIR: 0x0788
    Is there an issue with my certs? They use the same format as in the https_client example for example, it works fine there. It seems I can’t enable CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT because it required MBEDTLS_BUILTIN and a bunch of other stuff that again, conflicts with each other.
     aws-sample.zip
  • Hey,
    it looks like there are some DNS resolve issues;
    Maybe it's not related to your problem, but you should check if CONFIG_NET_IPV6 is enabled in the config.
  • We have the exact same challenges as you, couldn’t justify to maintain a fork but here we are anyway, scared by any SDK update we do as we have to patch things manually again every time. If we were to do it again, we would probably have put another MCU to handle the Ethernet part indeed. We have had great success with STM32 and Ethernet controllers in the past, but it adds another completely different development environment and other problems along the way (even more for secure communications with AWS, I’m sure).
    If you have some time to try this out with the nRF9160 devkit and some Ethernet controller dev kits like we did, maybe it’s a good way to try things out and see if it’s a good fit for your application. I don’t know if things have changed since my issues…
  • We have just received our first prototype boards as our hardware team has been working in parallel to my -fumbling about in Zephyr (first time using it), as we have shifted away from using an ESP32 and FreeRTOS... This quite frustrating given our original design had a seperate MCU for ethernet interfacing, but we moved away from that following a meeting with the Nordic staff which suggested it is possible (at  least from a hardware stance) to use both interfaces on a single MCU. To be fair, they are correc in that the nRF9151 has sufficient peripherals for all of our usecases, I just did not anticipate an issue such as this.
    I have submitted my own DevZone ticket regarding this issue, as well my colleagues are looking online for expert support so that we may resolve this issue without a Zephyr fork (if that's even possible).
    You will be among the first to hear from me if I can resolve this issue and/or if things have changed since this post was originally made.
    In the meantime, best of luck!
  • Hardware can definitely do it, but network stacks are very complex and the software development required can be huge and complicated… This should really be tried out as much as possible because it’s harder or impossible to change platform later on, and generally the documentation doesn’t truly shows how easy or hard it is to implement.
    Please do keep me updated, that would be very interesting indeed!
    Best of luck!
  • Very cool! Thank you for the update  , I guess we designed our project a bit early! :-)
