Memory optimization in TF-M enabled applications
We have a project where we are using TF-M application along with DFU and we observe a memory overflow in the TF-M partition when we try to reduce the TF-M partition size.
Attached the memory report.
What is b0 partition and EMPTY_X partitions are used?  How to reduce these partitions size?
We see TF-M is consuming around 270KB and how to reduce this partition at least to its half.
We basically need the TF-M partition to be minimal to make room for application in non-secure partition.
memory-map.xlsx
  • Hi Sigurd,
    We try to get as much as memory for non-secure application while TF-M is taking 93% of allocated memory.
    Attached our pm-static file, can you please look into this and help us in removing EMPTY_0 and EMPTY_1 partitions.
    b0:
      address: 0x0
      end_address: 0x8000
      placement:
        after:
        - start
      region: flash_primary
    b0_container:
      address: 0x0
      end_address: 0x8000
      orig_span: &id002
      - b0
      span: *id002
    s0:
      address: 0x8000
      end_address: 0x14200
      orig_span: &id006
      - s0_pad
      - mcuboot
      span: *id006
    s0_pad:
      address: 0x8000
      end_address: 0x8200
      placement:
        after:
        - b0_container
        align:
          start: 0x4000
      share_size:
      - mcuboot_pad
    s0_image:
      address: 0x8200
      orig_span: &id007
      - mcuboot
      span: *id007
    mcuboot:
      address: 0x8200
      placement:
        before:
        - mcuboot_primary
      sharers: 0x1
    EMPTY_0:
      address: 0x14200
      end_address: 0x18000
      placement:
        before:
        - s1_pad
    s1:
      address: 0x18000
      end_address: 0x24200
      orig_span: &id008
      - s1_pad
      - s1_image
      span: *id008
    s1_pad:
      address: 0x18000
      end_address: 0x18200
      placement:
        after:
        - s0
        align:
          start: 0x4000
      share_size:
      - mcuboot_pad
    s1_image:
      address: 0x18200
      placement:
        after:
        - s1_pad
        - s0
      share_size:
      - mcuboot
    EMPTY_1:
      address: 0x24200
      end_address: 0x28000
      placement:
        before:
        - mcuboot_pad
    mcuboot_primary:
      address: 0x28000
      end_address: 0x94000
      orig_span: &id003
      - app
      - tfm
      - mcuboot_pad
      sharers: 0x1
      span: *id003
    mcuboot_pad:
      address: 0x28000
      end_address: 0x28200
      placement:
        align:
          start: 0x4000
        before:
        - mcuboot_primary_app
      sharers: 0x2
    mcuboot_primary_app:
      address: 0x28200
      orig_span: &id004
      - app
      - tfm
      span: *id004
    app_image:
      address: 0x28200
      orig_span: &id001
      - tfm
      - app
      span: *id001
    tfm_secure:
      address: 0x28000
      end_address: 0x54000
      orig_span: &id012
      - mcuboot_pad
      - tfm
      span: *id012
    tfm:
      address: 0x28200
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x54000
      orig_span: &id011
      - app
      span: *id011
    app:
      address: 0x54000
    mcuboot_secondary:
      address: 0x94000
      end_address: 0x100000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x4000
        align_next: 0x4000
      share_size:
      - mcuboot_primary
    mcuboot_sram:
      address: 0x20000000
      end_address: 0x20020000
      orig_span: &id005
      - tfm_sram
      region: sram_primary
      span: *id005
    sram_secure:
      address: 0x20000000
      orig_span: &id010
      - tfm_sram
      span: *id010
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    sram_nonsecure:
      address: 0x20020000
      end_address: 0x20080000
      orig_span: &id009
      - sram_primary
      - rpmsg_nrf53_sram
      span: *id009
    sram_primary:
      address: 0x20020000
      end_address: 0x20070000
    rpmsg_nrf53_sram:
      address: 0x20070000
      placement:
        before:
        - end
    Let me explain our problem,
    We need crypto operations (SHA HMAC and AES CBC) for authentication and encryption.
    We also have DFU enabled, and the main reason why we are facing memory issue is we have wolfSSL lib enabled in our project.
    After many reductions in code size and disabling unwanted feature, we are now facing 28KB overflow issue in NS application from wolfSSL enabled.
    So, if we can completely remove the 2 EMPTY partitions, this will solve our memory overflow problem permanently.
    Please look into this as this is more like blocking for further integrations.
  • I spend a bit too long looking into why NSIB and MCUboot had to be each own SPU regions, before I realized why.
    First I thought that they just had to be in Secure regions.
    However, they are both write-protected by the SPU as well.
    And both MCUboot and NSIB write-protects their own memory.
    This write-protection is why we need to align NSIB and MCUboot.
    And that is what spawns the EMPTY partitions.
    NSIB  is 0x8000 already, so that should fit inside 0x4000x2.
    However, for MCUboot, I think the best you can do is to make it fit as best possible inside 0x4000 multiples.
    Does this make sense with what you see?
  • Does this make sense with what you see?
    Yes, it makes sense now.
    I really appreciate your support. Thank you so much.
    Can you please help with below concerns,
    1. I am thinking, anyway the MCUBoot and NSIB partition are not 100% utilizing the allocated memory. Is it possible to fit the _pad partition inside the respective partition. Like, inside MCUBoot we place MCUBoot_pad partition also and align the complete partition to SPU size 0x4000?
    2. Or try to reduce MCUBoot application size?
    3. Disable any PSA features to reduce TFM application size.
    We are really very concerned on memory consumption. Please let us know if there is any other possible way to get memory for NS application.
    The same PM_STATIC is what we are currently using.
    We are also trying to get support from WolfSSL to reduce their library size as much as possible.
  • Eyo, I think I found something.
    Vefore we attend to your questions from the last comment, see the following:
    The tfm_psa_template gets a very similar partitioning to what you have, right.
    I then realize that the gap you have is to align this between 0x14200 to 0x18000.
    The gap is in other words because of the 0x200 pad, which you point out.
    Instead of putting the pad inside mcuboot, we can just decrease mcuboot by 0x200.
    If I configure CONFIG_PM_PARTITION_SIZE_MCUBOOT=0xbe00 inside the MCUboot child image configuration for this sample, I get the following, beautiful partitioning:
    I ran the sample and it did work as expected. Try this on your side as well.
  • Hi Sigurd,
    Thank you for the great response.
    I try to resize the MCUBoot partition as you mentioned, and I see unknown symbol error.
    Anyway, I am modifying my pm_static file instead. Let me test and get back to you.
    This is good to know it is possible to remove EMPTY slots.
    Thank you so much.
