Flash area error while doing DFU using nRF Connect
Dear support team,
I am getting an error while performing DFU using nRF Connect.
[00:02:39.702,697] <inf> mcuboot_util: Swap type: none
[00:02:39.702,972] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
My SDK version is 2.4.2, I need to do DFU using BLE simultaneously, for that i tried to modify Example mcuboot_smp_ble_simultaneous , but without modifying anything, while performing DFU by compiling this code i am getting this error, Even after getting this error new imaged is flashed successfully after DFU. i don't know the reason. my complete serial log is attached bellow.
D: RDSR 40 QE 1 need 1: no-change
I: Starting bootloader
I: Swap type: none
I: Swap type: none
I: Bootloader chainload address offset: 0xc000
*** Booting Zephyr OS build 28a3fca7da5c ***
Change this to see it change.
[00:00:00.030,853] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.030,883] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.030,914] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.032,623] <inf> bt_hci_core: Identity: C5:DB:0C:FE:67:B3 (random)
[00:00:00.032,653] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.032,653] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
Bluetooth initialized
Advertising successfully started
[00:02:39.978,576] <inf> mcuboot_util: Swap type: none
I: Swap type: perm
I: Swap type: perm
I: Image upgrade secondary slot -> primary slot
I: Erasing the primary slot
I: Copying the secondary slot to the primary slot: 0x1af50 bytes
D: writing magic; fa_id=4 off=0xf3ff0 (0xffff0)
D: erasing secondary header
D: erasing secondary trailer
I: Copying the secondary slot to the primary slot: 0x2e8d4 bytes
D: writing magic; fa_id=1 off=0x3fff0 (0x3fff0)
I: Turned on network core
I: Turned off network core
ÿ*** Booting Zephyr OS build 28a3fca7da5c ***
Krishnachandran_Test....
[00:00:00.030,883] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.030,914] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.030,944] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.032,653] <inf> bt_hci_core: Identity: C5:DB:0C:FE:67:B3 (random)
[00:00:00.032,684] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.032,684] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
If any idea regarding this, please help. Thanks in advance.
  • Update ..1
    Our goal is to perform DFU_OTA using internal flash; we prefer not to utilize nrf5340dk. Additionally, we are employing a pm_static.yml as follows. However, after providing this configuration, we are encountering the same error
    app:
      address: 0x10200
      end_address: 0x66000
      region: flash_primary
    mcuboot:
      address: 0x0
      end_address: 0x10000
    mcuboot_pad:
      address: 0x10000
      end_address: 0x10200
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - mcuboot_pad
      - app
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      span: *id002
    mcuboot_secondary:
      address: 0x66000
      end_address: 0xBC000
    mcuboot_secondary_1:
      address: 0xBC000
      end_address: 0xFC000
    otp:
      address: 0xff8100
      end_address: 0xff83fc
      region: otp
    pcd_sram:
      address: 0x20000000
      end_address: 0x20002000
      region: sram_primary
    ram_flash:
      address: 0x40000
      end_address: 0x40000
      region: ram_flash
    rpmsg_nrf53_sram:
      address: 0x20070000
      end_address: 0x20080000
      placement:
        before:
        - end
    settings_storage:
      address: 0xFC000
      end_address: 0x100000
    sram_primary:
      address: 0x20002000
      end_address: 0x20070000
    mcuboot_primary_1:
      address: 0x0
      device: flash_ctrl
      region: ram_flash
  • When you DFU the dfu_application.zip from the mobile app, which mode do you choose?
    This means that you see the same error both with and without pm_static.yml, right?
    Why exactly do you want to add pm_static.yml now? I usually recommend not using static partitioning when developing, but waiting to when you are soon ready to release, then test with static partitioning. Static partitioning is after all  mostly used to make sure that partitioning does not change.
    Have you started configuring to use internal flash yet?
    Do you see the same error for both internal and external flash configurations?
    Hi Geir, thanks for saying you have seen the same. Did you create a devzone ticket when you saw the issue?
    Which SDK version did you see the issue for?
    Geir Strand said:
    We do believe that this is because mcumgr is trying to read the net core flash, which is not available from the app core.
    MCUmgr does not know that the slot is in net core flash. Instead, it thinks that the slot is in RAM.  However, it not impossible that might lead to  similar behavior.
    We are using "Test and Confirm" mode.
    Yes, right.
    Our aim is to perform DFU without using External flash, hence we tried both ie, with and without pm_static.yml
    Actually No.(Custom board we are not using external flash), we didn't  find specific example or configuration to use internal flash. , we tried to remove bellow mentioned code from overlay file. that time we are getting compilation error.  If there is an example tailored for internal flash, we would be grateful for your assistance in sharing it with us.
        chosen {
            nordic,pm-ext-flash = &mx25r64;
    I suspect that the error you get are related to the operations done by this.
    Do you see the same error if you use "Confirm only"? Since Simultaneous multi-image DFU does not support reverting, it is no need to use "test" either way.
        chosen {
    I suggest that you eliminate this error with external flash first, and then move on to internal flash.
    I know we have a custom sample (zip file) for internal flash FOTA for the nRF5340 somewhere, I just need to find it first. I think it should be in a public ticket somewhere.
    Thanks for the update.
    Tried both methods, and in both methods we are getting the same error.
