Flash area error while doing DFU using nRF Connect
Dear support team,
I am getting an error while performing DFU using nRF Connect.
[00:02:39.702,697] <inf> mcuboot_util: Swap type: none
[00:02:39.702,972] <err> mcumgr_img_grp: Failed to open flash area ID 1: -2
My SDK version is 2.4.2, I need to do DFU using BLE simultaneously, for that i tried to modify Example mcuboot_smp_ble_simultaneous , but without modifying anything, while performing DFU by compiling this code i am getting this error, Even after getting this error new imaged is flashed successfully after DFU. i don't know the reason. my complete serial log is attached bellow.
D: RDSR 40 QE 1 need 1: no-change
I: Starting bootloader
I: Swap type: none
I: Swap type: none
I: Bootloader chainload address offset: 0xc000
*** Booting Zephyr OS build 28a3fca7da5c ***
Change this to see it change.
[00:00:00.030,853] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.030,883] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.030,914] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.032,623] <inf> bt_hci_core: Identity: C5:DB:0C:FE:67:B3 (random)
[00:00:00.032,653] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.032,653] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
Bluetooth initialized
Advertising successfully started
[00:02:39.978,576] <inf> mcuboot_util: Swap type: none
I: Swap type: perm
I: Swap type: perm
I: Image upgrade secondary slot -> primary slot
I: Erasing the primary slot
I: Copying the secondary slot to the primary slot: 0x1af50 bytes
D: writing magic; fa_id=4 off=0xf3ff0 (0xffff0)
D: erasing secondary header
D: erasing secondary trailer
I: Copying the secondary slot to the primary slot: 0x2e8d4 bytes
D: writing magic; fa_id=1 off=0x3fff0 (0x3fff0)
I: Turned on network core
I: Turned off network core
ÿ*** Booting Zephyr OS build 28a3fca7da5c ***
Krishnachandran_Test....
[00:00:00.030,883] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.030,914] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.030,944] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.032,653] <inf> bt_hci_core: Identity: C5:DB:0C:FE:67:B3 (random)
[00:00:00.032,684] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.032,684] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
If any idea regarding this, please help. Thanks in advance.
  • I had a private post but was asked to continue the discussion here.
    We see the same behavior, the error prints both with "Test & Confirm" as well as "Confirm Only". The update is successful.
    We were suspicious that the DFU process tried to query the active net core slot. This was because a call to boot_read_bank_header() with the PM_mcuboot_primary_1_ID slot (slot 1 for our device) gives the same return code, but it seems to be unrelated.
    I looked for the source of the error message and it seems to be an unintended consequence of handling the state of the device.
    img_mgmt_state_write()   in img_mgmt_state.c
        - Seems like the function tries to fetch the current image state
        as a respons to the img_mgmt_state_write() smp command/function call
    img_mgmt_state_read()    in img_mgmt_state.c
        - Iterates through the first updatable_imgage_number*2 slots, so 4
        for our device
    img_mgmt_read_info()     in img_mgmt.c
    img_mgmt_erased_val()    in zephyr_img_mgmt.c
        - Prints the error message
    We are using nRF Connect SDK 2.4.1
    Best regards
    Kjell Arne
  • I am trying to reproduce this, with v2.4.2, the nRF5340DK and my Simultaneous DFU for app and net core of nRF5340 sample.
    I get the following log from the application core:
    I: Swap type: none
    I: Swap type: none
    *** Booting Zephyr OS build v3.3.99-ncs1-1 ***
    I: Swap type: perm
    I: Swap type: perm
    I: Copying the secondary slot to the primary slot: 0x152cc bytes
    I: Copying the secondary slot to the primary slot: 0x304ac bytes
    *** Booting nRF Connect SDK v2.5.0 ***
    BBB this to see it change.
    In which I can not see the error you see.
    That means something is different here. I think finding the difference might help us figure out what is happening.
    Can you see any differences?
    Do you see the same error with my sample?
    Do you use custom hardware?
  • Do you see the same error with my sample?
    Yes,  Could you please enable Log and try. ie. CONFIG_LOG=y in project config file.
    thanks
  • Hi Sigurd,
    I have not had a chance to run the sample yet, but have a comment. It seems the log in your post is from power on. The error message shows itself, at least in our case, when uploading a new image. Note that the DFU completes successfully, but we get some support cases and confusion from users.
    We see the same behavior with nRF Connect, nRF Connect Device Manager and mynewt-mcumgr-cli
    Thanks for the sample, it's always a good idea to eliminate what we can.
    Krish has got the difference. I just have not enabled logging in my application, so the mcumgr module does not complain visibly.
    Then I will see the same I suspect.
    I will do that next week and look into what this is.
    Note: Since DFU still works this is not my top priority, but I will do it.
