MPSL ASSERT: 106, 501
I am currently working on a project using the nRF Distance Measurement sample in conjunction with Openthread.
However, I am encountering an issue when nodes are positioned more than 10 meters apart. The following assert is triggered:
[00:03:40.057,037] <err> mpsl_init: m_assert_handler: MPSL ASSERT: 106, 501
[00:03:40.163,757] <err> os: hard_fault: ***** HARD FAULT *****
[00:03:40.291,748] <err> os: hard_fault:   Fault escalation (see below)
[00:03:40.397,857] <err> os: hard_fault: ARCH_EXCEPT with reason 3
[00:03:40.504,791] <err> os: esf_dump: r0/a1:  0x00000003  r1/a2:  0x20017d5c  r2/a3:  0x000002c0
[00:03:40.697,296] <err> os: esf_dump: r3/a4:  0x00070d7d r12/ip:  0x00000000 r14/lr:  0x000706e5
[00:03:40.825,286] <err> os: esf_dump:  xpsr:  0x41000018
[00:03:40.932,189] <err> os: esf_dump: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
[00:03:41.059,814] <err> os: esf_dump: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
[00:03:41.167,083] <err> os: esf_dump: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
[00:03:41.317,108] <err> os: esf_dump: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0xffffffff  s[15]:  0xffffffff
[00:03:41.467,102] <err> os: esf_dump: fpscr:  0x00000000
The nodes are nRF52840 DK version 1.0.0 hardware.
I am using nRF Connect SDK version 2.5.2 with the following project configuration:
CONFIG_DEBUG=y
CONFIG_LOG=y
CONFIG_LOG_MODE_DEFERRED=y
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=0
CONFIG_I2C=y
CONFIG_GPIO=y
CONFIG_NRFX_PWM0=y
CONFIG_NRFX_PWM1=y
CONFIG_DK_LIBRARY=y
CONFIG_OPENTHREAD_COAP=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_POLL_MAX=4
CONFIG_OPENTHREAD_NETWORKKEY="XXXX"
CONFIG_OPENTHREAD_PANID=XXXX
CONFIG_OPENTHREAD_XPANID="XXXX"
CONFIG_OPENTHREAD_NETWORK_NAME="XXXX"
CONFIG_OPENTHREAD_JOINER=y
CONFIG_OPENTHREAD_JOINER_AUTOSTART=y
CONFIG_OPENTHREAD_JOINER_PSKD="XXXX"
CONFIG_NET_L2_OPENTHREAD=y
CONFIG_NETWORKING=y
CONFIG_MBEDTLS_SHA1_C=n
CONFIG_FPU=y
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_NAME_CNT=1
CONFIG_BT_SCAN_MANUFACTURER_DATA_CNT=1
CONFIG_BT_SCAN_WITH_IDENTITY=y
CONFIG_BT_ID_MAX=1
CONFIG_BT_EXT_ADV=y
CONFIG_BT_DEVICE_NAME="XXXX"
CONFIG_BT_DDFS=y
CONFIG_DM_MODULE=y
CONFIG_NEWLIB_LIBC=y
CONFIG_MPSL=y
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=1
CONFIG_DM_MODULE_LOG_LEVEL_DBG=n
CONFIG_DM_GPIO_DEBUG=y
CONFIG_DM_HIGH_PRECISION_CALC=y
Could you provide insights into what might be causing this issue?
