Hello Nordic support,
I work on receive data from the microphone mp34dt05-a . I have some question.
1- How to enable PDM in SDK_CONFIG.H .
2- For this project do I need enable easydma for convert PDM to PCM.if your answer is yes, then
how to enable this.
I write this code in "SDK.config.h"
// <e> PDM_ENABLED - nrf_drv_pdm - PDM peripheral driver - legacy layer //========================================================== #ifndef PDM_ENABLED #define PDM_ENABLED 1 #endif // <o> PDM_CONFIG_MODE - Mode // <0=> Stereo // <1=> Mono #ifndef PDM_CONFIG_MODE #define PDM_CONFIG_MODE 1 #endif // <o> PDM_CONFIG_EDGE - Edge // <0=> Left falling // <1=> Left rising #ifndef PDM_CONFIG_EDGE #define PDM_CONFIG_EDGE 0 #endif // <o> PDM_CONFIG_CLOCK_FREQ - Clock frequency // <134217728=> 1000k // <138412032=> 1032k (default) // <142606336=> 1067k #ifndef PDM_CONFIG_CLOCK_FREQ #define PDM_CONFIG_CLOCK_FREQ 138412032 #endif // <o> PDM_CONFIG_IRQ_PRIORITY - Interrupt priority // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 // <4=> 4 // <5=> 5 // <6=> 6 // <7=> 7 #ifndef PDM_CONFIG_IRQ_PRIORITY #define PDM_CONFIG_IRQ_PRIORITY 7 #endif // </e> // <e> NRFX_PDM_ENABLED - nrfx_pdm - PDM peripheral driver //========================================================== #ifndef NRFX_PDM_ENABLED #define NRFX_PDM_ENABLED 1 #endif // <o> NRFX_PDM_CONFIG_MODE - Mode // <0=> Stereo // <1=> Mono #ifndef NRFX_PDM_CONFIG_MODE #define NRFX_PDM_CONFIG_MODE 1 #endif // <o> NRFX_PDM_CONFIG_EDGE - Edge // <0=> Left falling // <1=> Left rising #ifndef NRFX_PDM_CONFIG_EDGE #define NRFX_PDM_CONFIG_EDGE 0 #endif // <o> NRFX_PDM_CONFIG_CLOCK_FREQ - Clock frequency // <134217728=> 1000k // <138412032=> 1032k (default) // <142606336=> 1067k #ifndef NRFX_PDM_CONFIG_CLOCK_FREQ #define NRFX_PDM_CONFIG_CLOCK_FREQ 138412032 #endif // <o> NRFX_PDM_CONFIG_IRQ_PRIORITY - Interrupt priority // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 // <4=> 4 // <5=> 5 // <6=> 6 // <7=> 7 #ifndef NRFX_PDM_CONFIG_IRQ_PRIORITY #define NRFX_PDM_CONFIG_IRQ_PRIORITY 7 #endif // <e> NRFX_PDM_CONFIG_LOG_ENABLED - Enables logging in the module. //========================================================== #ifndef NRFX_PDM_CONFIG_LOG_ENABLED #define NRFX_PDM_CONFIG_LOG_ENABLED 1 #endif // <o> NRFX_PDM_CONFIG_LOG_LEVEL - Default Severity level // <0=> Off // <1=> Error // <2=> Warning // <3=> Info // <4=> Debug #ifndef NRFX_PDM_CONFIG_LOG_LEVEL #define NRFX_PDM_CONFIG_LOG_LEVEL 3 #endif // <o> NRFX_PDM_CONFIG_INFO_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRFX_PDM_CONFIG_INFO_COLOR #define NRFX_PDM_CONFIG_INFO_COLOR 0 #endif // <o> NRFX_PDM_CONFIG_DEBUG_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef NRFX_PDM_CONFIG_DEBUG_COLOR #define NRFX_PDM_CONFIG_DEBUG_COLOR 0 #endif // </e> // </e> /* PDM */ // <e> NRFX_PDM_ENABLED - nrfx_pdm - PDM peripheral driver //========================================================== #ifndef NRFX_PDM_ENABLED #define NRFX_PDM_ENABLED 1 #define PDM_ENABLED 1 #endif #ifndef PDM_CONFIG_USE_EASY_DMA #define PDM_CONFIG_USE_EASY_DMA 1 #endif //#if (PDM_ENABLED == 1) //#define PDM_CONFIG_MODE NRF_PDM_MODE_MONO //#define PDM_CONFIG_EDGE NRF_PDM_EDGE_LEFTFALLING //#define PDM_CONFIG_CLOCK_FREQ NRF_PDM_FREQ_1032K //#define PDM_CONFIG_IRQ_PRIORITY APP_IRQ_PRIORITY_LOW //#endif // <e> PDM_CONFIG_LOG_ENABLED - Enables logging in the module. //========================================================== #ifndef PDM_CONFIG_LOG_ENABLED #define PDM_CONFIG_LOG_ENABLED 1 #endif // <o> PDM_CONFIG_LOG_LEVEL - Default Severity level // <0=> Off // <1=> Error // <2=> Warning // <3=> Info // <4=> Debug #ifndef PDM_CONFIG_LOG_LEVEL #define PDM_CONFIG_LOG_LEVEL 3 #endif // <o> PDM_CONFIG_INFO_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef PDM_CONFIG_INFO_COLOR #define PDM_CONFIG_INFO_COLOR 0 #endif // <o> PDM_CONFIG_DEBUG_COLOR - ANSI escape code prefix. // <0=> Default // <1=> Black // <2=> Red // <3=> Green // <4=> Yellow // <5=> Blue // <6=> Magenta // <7=> Cyan // <8=> White #ifndef PDM_CONFIG_DEBUG_COLOR #define PDM_CONFIG_DEBUG_COLOR 0 #endif // </e>
and this is my cod in main.c
#include <stdio.h>
#include "nrf_delay.h"
#include "app_error.h"
#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_pdm.h"
#include "nrf_pdm.h"
#define CONFIG_PDM_BUFFER_SIZE_SAMPLES 320
// <o> PDM Decimation Filter Gain <0x00-0x50>
// <i> For details on the PDM decimation filter, see the 'Decimation filter' section in the nRF52 Product Specification document.
#define CONFIG_PDM_GAIN 0x28
/**@brief Audio buffer handler. */
//typedef void (*drv_audio_buffer_handler_t)(nrfx_pdm_evt_t const *p_buffer, uint16_t samples);
static int16_t m_pdm_buff[2][CONFIG_PDM_BUFFER_SIZE_SAMPLES];
//static drv_audio_buffer_handler_t m_buffer_handler;
static void m_audio_buffer_handler(int16_t *p_buffer, uint16_t samples)
// Audio processing
static void drv_audio_pdm_event_handler(nrfx_pdm_evt_t const *p_buffer, uint16_t length)
if (p_buffer->buffer_requested) {
nrfx_pdm_buffer_set(m_pdm_buff, 3027);
if (p_buffer->buffer_released != 0) {
printf("Out: %4x @ 0x%x\r\n %4x @ 0x%x\r\n",
(uint16_t)m_pdm_buff[0], &m_pdm_buff[0],
(uint16_t)m_pdm_buff[1], &m_pdm_buff[1]);
//m_buffer_handler((int16_t *)p_buffer, length);
uint32_t drv_audio_init( )
nrf_drv_pdm_config_t pdm_cfg = NRF_DRV_PDM_DEFAULT_CONFIG(MIC_CLK,MIC_DOUT);
pdm_cfg.clock_freq=PDM_PDMCLKCTRL_FREQ_1333K;
return nrf_drv_pdm_init(&pdm_cfg, drv_audio_pdm_event_handler);
uint32_t err_code = NRF_SUCCESS;
err_code = NRF_LOG_INIT(NULL);
NRF_LOG_INFO("PDM example started.\n\t");
err_code =nrfx_pdm_enable_check();
// Initialize PDM and start receiving PDM data //
nrfx_pdm_buffer_set(&m_pdm_buff[0],CONFIG_PDM_BUFFER_SIZE_SAMPLES);
err_code = drv_audio_init();
err_code = nrf_drv_pdm_start();
for (int i = 0; i < 300; i++) {
int k = 5;
for (volatile int j = 0; j < 100; j++) {
k = !k;
printf("%4x is current value at %x\n", m_pdm_buff[0], &m_pdm_buff);
}the microphone PDM clock is 1.2Mhz to 3.25Mhz and I set this clock 1333Khz.
I can not receive data correct.
this figure has PDM clock.
and this figure is my data output.
and other figure.
can you help me to run the microphone.
