I use nrf51422 dk, device: s310 2.0.1 Then i want to download "bootloader" from example floder by keil 4 but it can't work and show up "JLinkARM.dll not found. please reinstall latest JLinkARM.dll "
i should i solve it?
Did you try this? "please reinstall latest JLinkARM.dll " Download here
Download this from SEGGER and install it. This contains the JLinkARM.dll that keil and other tools require for flashing/debugging devices when using a SEGGER debugger.
www.segger.com/jlink-software.html
When you install it, it should see that you have keil installed and give you an option to update the JLinkARM.dll that keil uses. Make sure you select this option so the newly installed software is used by keil (and any other IDEs that it detects installed on your computer).
thx guys i solved it
on that which file i want to download for nRF51 DK kit.
Because i got the error JlinkARM.dll is not correctly installed. please run the nRF Tools installer to install the newest version.
This works. Thanks mate. You guys are amazon.
