Unable to recover a nrf5340 MCU after first flash on a custom board using nrf5340 DK
Dear,
I was trying to flash a custom board using a nrf5340 module (Raytac MDBT53-1M) threw P20 connection of a nrf5340-DK like described in https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_nrf5340_dk%2FUG%2Fdk%2Fext_programming_support_P20.html.
I am able to read its memory before flashing anything using nrf Programmer. To reduce the possible power issue investigation, I shorted my DK SB47 and use P20 power for the custom board.
I flashed our firmware initially designed using the DK on that custom board, but when done, it is not possible to communicate with it anymore, and by the way not possible to recover it or erase its flash.
I attached the log of the command:
nrfjprog --recover --family nRF53 --log
[2024-Feb-07 11:05:26] [debug] --------------------------------------------------------------------------------
[2024-Feb-07 11:05:26] [debug] nrfjprog --recover --family nRF53 --log
[2024-Feb-07 11:05:26] [debug] nrfjprog version 10.23.0 external
[2024-Feb-07 11:05:26] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2024-Feb-07 11:05:26] [ info] Library loaded, loading member functions.
[2024-Feb-07 11:05:26] [ info] Member functions succesfully loaded.
[2024-Feb-07 11:05:26] [debug] [ Client] - open
[2024-Feb-07 11:05:26] [debug] [ Client] - start
[2024-Feb-07 11:05:26] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence a19ba77f-de80-4d65-936c-07d744b730a8.
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2024-Feb-07 11:05:26] [debug] [  JLink] - Logger sink registered in JLink logger
[2024-Feb-07 11:05:26] [debug] [  nRF53] - open
[2024-Feb-07 11:05:26] [debug] [  nRF53] - just_check_family
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - open_dll
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2024-Feb-07 11:05:26] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.88.10.
[2024-Feb-07 11:05:26] [trace] [ Client] - Command open executed for 5 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - config
[2024-Feb-07 11:05:26] [trace] [ Client] - Command config executed for 4 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - enum_emu_snr
[2024-Feb-07 11:05:26] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2024-Feb-07 11:05:26] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Set batch mode
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - dll_version
[2024-Feb-07 11:05:26] [ info] [SeggerBackend] - Segger dll version 7.88.j loaded.
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [  nRF53] - config
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - enum_emu_snr
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command config executed for 4 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [  nRF53] - enum_emu_con_info
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - is_connected_to_emu
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - enum_emu_con_info
[2024-Feb-07 11:05:26] [trace] [ Client] - Command enum_emu_con_info executed for 108 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - connect_to_emu_with_snr
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command enum_emu_con_info executed for 108 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [  nRF53] - connect_to_emu_with_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_get_num_emus
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Segger logging enabled.
[2024-Feb-07 11:05:26] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
[2024-Feb-07 11:05:26] [trace] [  JLink] - Hardware: V1.00
[2024-Feb-07 11:05:26] [trace] [  JLink] - S/N: 1050097424
[2024-Feb-07 11:05:26] [trace] [  JLink] - OEM: SEGGER
[2024-Feb-07 11:05:26] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2024-Feb-07 11:05:26] [trace] [  JLink] - Bootloader: 2021 May 18
[2024-Feb-07 11:05:26] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2024-Feb-07 11:05:26] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2024-Feb-07 11:05:26] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2024-Feb-07 11:05:26] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2024-Feb-07 11:05:26] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /opt/SEGGER/JLink/JLinkGUIServerExe
[2024-Feb-07 11:05:26] [trace] [  JLink] - Forking J-Link GUI Server: /opt/SEGGER/JLink/JLinkGUIServerExe
[2024-Feb-07 11:05:26] [trace] [ Client] - Command connect_to_emu_with_snr executed for 341 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - read_connected_emu_snr
[2024-Feb-07 11:05:26] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - recover
[2024-Feb-07 11:05:26] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.88j "
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 35.924ms returns "O.K."
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_HasError()
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_Lock()
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.003ms returns 0x01
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.002ms returns 0x00
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.005ms returns 0
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.406ms returns 0x00
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2024-Feb-07 11:05:26] [trace] [  JLink] - 128000000 Hz / n, n >= 64
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.008ms
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.063ms
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_GetSpeed()
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.002ms returns 2000
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_GetSN()
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.002ms returns 1050097424
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.004ms
[2024-Feb-07 11:05:26] [debug] [  nRF53] - read_device_family
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 341 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [  nRF53] - read_connected_emu_snr
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_IsOpen()
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - read_connected_emu_snr
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [  nRF53] - recover
[2024-Feb-07 11:05:26] [debug] [  nRF53] - just_recover
[2024-Feb-07 11:05:26] [debug] [  nRF53] - Just_is_eraseprotect_enabled
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - read_access_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_read_access_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - coresight_configure
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.097ms returns 0
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 101.610ms returns 0
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - read_debug_port_idr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - read_debug_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.662ms returns -1
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_abort_debug_action
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.636ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.606ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.655ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.644ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.597ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.520ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.534ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.543ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.483ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.442ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.445ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.456ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.446ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.437ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.439ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.447ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.478ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.454ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.503ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.484ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.524ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.457ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.498ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.433ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.432ms returns -1
[2024-Feb-07 11:05:26] [error] [ Client] - Encountered error -21: Command recover executed for 123 milliseconds with result -21
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.438ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.426ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.470ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.469ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.450ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.443ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.452ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.448ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.429ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.120ms
[2024-Feb-07 11:05:26] [error] [ Worker] - An unknown error.
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command recover executed for 123 milliseconds with result -21
[2024-Feb-07 11:05:26] [debug] [  nRF53] - close
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.010ms returns 0x01
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - close
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - disconnect_from_emu
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - is_connected_to_device
[2024-Feb-07 11:05:26] [trace] [  JLink] - JLINK_IsConnected()
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.006ms returns FALSE
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.459ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.430ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.519ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.449ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.499ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.428ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.491ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.526ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.431ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.528ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.451ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.504ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.500ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.436ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.424ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.423ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.487ms returns -1
[2024-Feb-07 11:05:26] [trace] [  JLink] - - 0.420ms returns -1
I also tried on another computer (and OS), but got exactly the same. Also tried another board, and got exactly same result: first capable to read flash, after programming => blocked.
Is there a way to force a factory reset of the nrf5340 when it is not communicating anymore? What could be the root of that issue?
Thanks a lot for your expertise!
Michael
    How is the schematic around this module? Do you include a 32k xtal and/or DCDC-components?
    If not, you will have to manually specify both the 32k source + disable DCDC.
    In your prj.conf:
    # disable DCDC
    CONFIG_BOARD_ENABLE_DCDC_APP=n
    CONFIG_BOARD_ENABLE_DCDC_NET=n
    CONFIG_BOARD_ENABLE_DCDC_HV=n
    # Use internal 32k RC oscillator
    If you enable BT, you need to create file/folder and set this in child_images/hci_rpmsg.conf:
    Could you first try to recover the net core, then the app core?
    nrfjprog --recover -f nrf53 --coprocessor cp_network
    Håkon
  • Hi Håkon,
    Yes, 32k is included, here is the schematic around module:
    We tried to follow manufacturer recommendations. You think I can restore/clear MCU?
    I also tried to recover network coprocessor, but facing almost the same:
    [2024-Feb-07 13:47:00] [debug] --------------------------------------------------------------------------------
    [2024-Feb-07 13:47:00] [debug] nrfjprog --recover -f nrf53 --coprocessor cp_network --log
    [2024-Feb-07 13:47:00] [debug] nrfjprog version 10.23.0 external
    [2024-Feb-07 13:47:00] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
    [2024-Feb-07 13:47:00] [ info] Library loaded, loading member functions.
    [2024-Feb-07 13:47:00] [ info] Member functions succesfully loaded.
    [2024-Feb-07 13:47:00] [debug] [ Client] - open
    [2024-Feb-07 13:47:00] [debug] [ Client] - start
    [2024-Feb-07 13:47:00] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 0209b003-e0dd-42b8-a211-d5eb9a6cd794.
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Feb-07 13:47:00] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Feb-07 13:47:00] [debug] [  nRF53] - open
    [2024-Feb-07 13:47:00] [debug] [  nRF53] - just_check_family
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - open_dll
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Feb-07 13:47:00] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.88.10.
    [2024-Feb-07 13:47:00] [trace] [ Client] - Command open executed for 3 milliseconds with result 0
    [2024-Feb-07 13:47:00] [debug] [ Client] - config
    [2024-Feb-07 13:47:00] [trace] [ Client] - Command config executed for 2 milliseconds with result 0
    [2024-Feb-07 13:47:00] [debug] [ Client] - enum_emu_snr
    [2024-Feb-07 13:47:00] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Feb-07 13:47:00] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - Set batch mode
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - dll_version
    [2024-Feb-07 13:47:00] [ info] [SeggerBackend] - Segger dll version 7.88.j loaded.
    [2024-Feb-07 13:47:00] [trace] [ Worker] - Command open executed for 2 milliseconds with result 0
    [2024-Feb-07 13:47:00] [debug] [  nRF53] - config
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - enum_emu_snr
    [2024-Feb-07 13:47:00] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
    [2024-Feb-07 13:47:00] [debug] [  nRF53] - enum_emu_con_info
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Feb-07 13:47:00] [trace] [ Client] - Command enum_emu_con_info executed for 109 milliseconds with result 0
    [2024-Feb-07 13:47:00] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Feb-07 13:47:00] [trace] [ Worker] - Command enum_emu_con_info executed for 109 milliseconds with result 0
    [2024-Feb-07 13:47:00] [debug] [  nRF53] - connect_to_emu_with_snr
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Feb-07 13:47:00] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Feb-07 13:47:01] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
    [2024-Feb-07 13:47:01] [trace] [  JLink] - Hardware: V1.00
    [2024-Feb-07 13:47:01] [trace] [  JLink] - S/N: 1050097424
    [2024-Feb-07 13:47:01] [trace] [  JLink] - OEM: SEGGER
    [2024-Feb-07 13:47:01] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2024-Feb-07 13:47:01] [trace] [  JLink] - Bootloader: 2021 May 18
    [2024-Feb-07 13:47:01] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Feb-07 13:47:01] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Feb-07 13:47:01] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /opt/SEGGER/JLink/JLinkGUIServerExe
    [2024-Feb-07 13:47:01] [trace] [  JLink] - Forking J-Link GUI Server: /opt/SEGGER/JLink/JLinkGUIServerExe
    [2024-Feb-07 13:47:01] [trace] [ Client] - Command connect_to_emu_with_snr executed for 342 milliseconds with result 0
    [2024-Feb-07 13:47:01] [debug] [ Client] - read_connected_emu_snr
    [2024-Feb-07 13:47:01] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Feb-07 13:47:01] [debug] [ Client] - enable_coprocessor
    [2024-Feb-07 13:47:01] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.88j "
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 32.617ms returns "O.K."
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_HasError()
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_Lock()
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.002ms returns 0x01
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.002ms returns 0x00
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.001ms returns 0x00
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.005ms returns 0
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.522ms returns 0x00
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Feb-07 13:47:01] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.009ms
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.101ms
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.003ms returns 2000
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_GetSN()
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.005ms returns 1050097424
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.006ms
    [2024-Feb-07 13:47:01] [debug] [  nRF53] - read_device_family
    [2024-Feb-07 13:47:01] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 342 milliseconds with result 0
    [2024-Feb-07 13:47:01] [debug] [  nRF53] - read_connected_emu_snr
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.003ms returns 0x01
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - read_connected_emu_snr
    [2024-Feb-07 13:47:01] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Feb-07 13:47:01] [debug] [  nRF53] - enable_coprocessor
    [2024-Feb-07 13:47:01] [debug] [  nRF53] - Just_enable_coprocessor
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - is_secure_debug_available
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - read_access_port_register
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - coresight_configure
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.081ms returns 0
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 101.503ms returns 0
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.619ms returns -1
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.535ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.563ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.528ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.536ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.483ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.469ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.450ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.441ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.447ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.459ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.501ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.468ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.437ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.442ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.454ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.500ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.434ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.448ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.431ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.453ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.452ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.435ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.451ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.456ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.446ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.439ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.433ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.458ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.491ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.436ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.432ms returns -1
    [2024-Feb-07 13:47:01] [warning] [  nRF53] - Ignore error while fetching secure transfer state. -102: An unknown error.
    [2024-Feb-07 13:47:01] [debug] [  nRF53] - Just_readback_status
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2024-Feb-07 13:47:01] [trace] [  JLink] - failed
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.518ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.517ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.429ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.497ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.476ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.576ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.558ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.593ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.578ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.530ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.523ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.522ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.479ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.512ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.539ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.464ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.472ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.496ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.490ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.475ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.470ms returns -1
    [2024-Feb-07 13:47:01] [error] [ Client] - Encountered error -102: Command enable_coprocessor executed for 144 milliseconds with result -102
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.474ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.457ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.466ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.125ms
    [2024-Feb-07 13:47:01] [error] [ Worker] - An unknown error.
    [2024-Feb-07 13:47:01] [trace] [ Worker] - Command enable_coprocessor executed for 144 milliseconds with result -102
    [2024-Feb-07 13:47:01] [debug] [  nRF53] - close
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.013ms returns 0x01
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - close
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Feb-07 13:47:01] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Feb-07 13:47:01] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.010ms returns FALSE
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.533ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.494ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.502ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.461ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.467ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.445ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.482ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.510ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.477ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.487ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.463ms returns -1
    [2024-Feb-07 13:47:01] [trace] [  JLink] - - 0.485ms returns -1
    Thank you!
    Michael
  • Hi Michael,
    Thanks for sharing the schematic.
    It shows that there is no DCDC components in-place. If your firmware is configured without explicitly disabling DCDC, it will boot up, set DCDCEN register(s), and reset itself due to a power-on-reset.
    The first recommendation is to update your nrf-command line tools installation to the newest:
    https://www.nordicsemi.com/Products/Development-tools/nrf-command-line-tools/download
    After that, you can try to run a recover loop script, to see if you are then able to recover the device:
     RE: nRF52832 not connected anymore after first trying to debug (Keil)
    Switch out the "-f nrf52" to "-f nrf53".
    You can also try to vary the SWD speed, via adding "-c 125" for instance. This will switch the SWD speed to 125 kHz.
    Håkon
  • Hi Håkon,
    I was not yet able to restore the previous boards with the recover loop script, but I confirm by disabling DCDC  the issue is solved and nrf53 is not constantly rebooting.
    I used these configs for that:
    Thank you!
    Michael
  • Thank you for documenting this. During my development process, I also encountered MCU startup issues caused by setting different power modes. Your documentation provided valuable insights that helped me resolve my problem. Regarding the MCU reset, I managed to reprogram the previously misconfigured board by shorting DCED to 3.3V using tweezers for reconfiguration. I'm adding this as a supplementary note here. Thank you again for your documentation!
