Dear,
I was trying to flash a custom board using a nrf5340 module (Raytac MDBT53-1M) threw P20 connection of a nrf5340-DK like described in https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_nrf5340_dk%2FUG%2Fdk%2Fext_programming_support_P20.html.
I am able to read its memory before flashing anything using nrf Programmer. To reduce the possible power issue investigation, I shorted my DK SB47 and use P20 power for the custom board.
I flashed our firmware initially designed using the DK on that custom board, but when done, it is not possible to communicate with it anymore, and by the way not possible to recover it or erase its flash.
I attached the log of the command:
nrfjprog --recover --family nRF53 --log
[2024-Feb-07 11:05:26] [debug] --------------------------------------------------------------------------------
[2024-Feb-07 11:05:26] [debug] nrfjprog --recover --family nRF53 --log
[2024-Feb-07 11:05:26] [debug] nrfjprog version 10.23.0 external
[2024-Feb-07 11:05:26] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2024-Feb-07 11:05:26] [ info] Library loaded, loading member functions.
[2024-Feb-07 11:05:26] [ info] Member functions succesfully loaded.
[2024-Feb-07 11:05:26] [debug] [ Client] - open
[2024-Feb-07 11:05:26] [debug] [ Client] - start
[2024-Feb-07 11:05:26] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence a19ba77f-de80-4d65-936c-07d744b730a8.
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2024-Feb-07 11:05:26] [debug] [ JLink] - Logger sink registered in JLink logger
[2024-Feb-07 11:05:26] [debug] [ nRF53] - open
[2024-Feb-07 11:05:26] [debug] [ nRF53] - just_check_family
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - open_dll
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2024-Feb-07 11:05:26] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.88.10.
[2024-Feb-07 11:05:26] [trace] [ Client] - Command open executed for 5 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - config
[2024-Feb-07 11:05:26] [trace] [ Client] - Command config executed for 4 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - enum_emu_snr
[2024-Feb-07 11:05:26] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2024-Feb-07 11:05:26] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Set batch mode
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - dll_version
[2024-Feb-07 11:05:26] [ info] [SeggerBackend] - Segger dll version 7.88.j loaded.
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ nRF53] - config
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - enum_emu_snr
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command config executed for 4 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ nRF53] - enum_emu_con_info
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - is_connected_to_emu
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - enum_emu_con_info
[2024-Feb-07 11:05:26] [trace] [ Client] - Command enum_emu_con_info executed for 108 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - connect_to_emu_with_snr
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command enum_emu_con_info executed for 108 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ nRF53] - connect_to_emu_with_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_get_num_emus
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Segger logging enabled.
[2024-Feb-07 11:05:26] [trace] [ JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
[2024-Feb-07 11:05:26] [trace] [ JLink] - Hardware: V1.00
[2024-Feb-07 11:05:26] [trace] [ JLink] - S/N: 1050097424
[2024-Feb-07 11:05:26] [trace] [ JLink] - OEM: SEGGER
[2024-Feb-07 11:05:26] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2024-Feb-07 11:05:26] [trace] [ JLink] - Bootloader: 2021 May 18
[2024-Feb-07 11:05:26] [trace] [ JLink] - USB speed mode: Full speed (12 MBit/s)
[2024-Feb-07 11:05:26] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2024-Feb-07 11:05:26] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2024-Feb-07 11:05:26] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2024-Feb-07 11:05:26] [trace] [ JLink] - Looking for J-Link GUI Server exe at: /opt/SEGGER/JLink/JLinkGUIServerExe
[2024-Feb-07 11:05:26] [trace] [ JLink] - Forking J-Link GUI Server: /opt/SEGGER/JLink/JLinkGUIServerExe
[2024-Feb-07 11:05:26] [trace] [ Client] - Command connect_to_emu_with_snr executed for 341 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - read_connected_emu_snr
[2024-Feb-07 11:05:26] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ Client] - recover
[2024-Feb-07 11:05:26] [trace] [ JLink] - J-Link GUI Server info: "J-Link GUI server V7.88j "
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 35.924ms returns "O.K."
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_HasError()
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_Lock()
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.003ms returns 0x01
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.002ms returns 0x00
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.005ms returns 0
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.406ms returns 0x00
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_GetSpeedInfo()
[2024-Feb-07 11:05:26] [trace] [ JLink] - 128000000 Hz / n, n >= 64
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.008ms
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.063ms
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_GetSpeed()
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.002ms returns 2000
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_GetSN()
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.002ms returns 1050097424
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.004ms
[2024-Feb-07 11:05:26] [debug] [ nRF53] - read_device_family
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 341 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ nRF53] - read_connected_emu_snr
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_IsOpen()
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - read_connected_emu_snr
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2024-Feb-07 11:05:26] [debug] [ nRF53] - recover
[2024-Feb-07 11:05:26] [debug] [ nRF53] - just_recover
[2024-Feb-07 11:05:26] [debug] [ nRF53] - Just_is_eraseprotect_enabled
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - read_access_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_read_access_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - coresight_configure
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.097ms returns 0
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 101.610ms returns 0
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - read_debug_port_idr
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - read_debug_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.662ms returns -1
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_abort_debug_action
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.636ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.606ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.655ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.644ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.597ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.520ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.534ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.543ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.483ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.442ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.445ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.456ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.446ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.437ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.439ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.447ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.478ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.454ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.503ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.484ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.524ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.457ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.498ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.433ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.432ms returns -1
[2024-Feb-07 11:05:26] [error] [ Client] - Encountered error -21: Command recover executed for 123 milliseconds with result -21
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.438ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.426ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.470ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.469ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.450ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.443ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.452ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.448ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.429ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.120ms
[2024-Feb-07 11:05:26] [error] [ Worker] - An unknown error.
[2024-Feb-07 11:05:26] [trace] [ Worker] - Command recover executed for 123 milliseconds with result -21
[2024-Feb-07 11:05:26] [debug] [ nRF53] - close
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.010ms returns 0x01
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - close
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - disconnect_from_emu
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - is_connected_to_device
[2024-Feb-07 11:05:26] [trace] [ JLink] - JLINK_IsConnected()
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.006ms returns FALSE
[2024-Feb-07 11:05:26] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.459ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.430ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.519ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.449ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.499ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.428ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.491ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.526ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.431ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.528ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.451ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.504ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.500ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.436ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.424ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.423ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.487ms returns -1
[2024-Feb-07 11:05:26] [trace] [ JLink] - - 0.420ms returns -1
I also tried on another computer (and OS), but got exactly the same. Also tried another board, and got exactly same result: first capable to read flash, after programming => blocked.
Is there a way to force a factory reset of the nrf5340 when it is not communicating anymore? What could be the root of that issue?
Thanks a lot for your expertise!
Michael
