Reducing current draw XIAO BLE
Trying to reduce idle power consumption of a project that uses Seeed studio XIAO BLE nrf52840 module.
When idle, the seeduino draws  around 1.5mA. Power is supplied through the 3.3V pin
The same code running on the nrf52840 DK shows average current draw on the order of 10s of uA on my ammeter when measured through the current measurement header on the DK
To try and optimise the power draw, I created a simple blinky project. When running this, the idle draw is around 600uA for the seeeduino and 3-4 uA for the DK
Powering off the xiao ble using sys_poweroff() lowers the current to 2-3uA, So it seems like there is not leakage etc...
In the case of the blinky program, my guess for the lower power consumption compared to case 1 is because flash is disabled.
prj.conf for blinky:
CONFIG_GPIO=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_BOARD_ENABLE_DCDC=y
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
CONFIG_SERIAL=n
CONFIG_CONSOLE=n
CONFIG_UART_CONSOLE=n
im using mcuboot, child_image/mcuboot.conf is :
CONFIG_MULTITHREADING=y
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
CONFIG_LOG=n
CONFIG_CONSOLE=n
CONFIG_SERIAL=n
.config for xiao ble
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_MIPI_DSI is not set
# CONFIG_MODEM is not set
# CONFIG_SPI is not set
CONFIG_BOARD="xiao_ble"
CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=y
CONFIG_NUM_IRQS=48
CONFIG_SOC_SERIES="nrf52"
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_SOC="nRF52840_QIAA"
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
CONFIG_FLASH_SIZE=1024
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_CLOCK_CONTROL=y
# CONFIG_PINCTRL is not set
# CONFIG_WATCHDOG is not set
CONFIG_HEAP_MEM_POOL_SIZE=0
CONFIG_ROM_START_OFFSET=0
# CONFIG_RESET is not set
CONFIG_GPIO=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
# CONFIG_FPU is not set
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_MEMC is not set
# CONFIG_MBEDTLS is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_SERIAL is not set
CONFIG_MAIN_STACK_SIZE=1024
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_USE_DT_CODE_PARTITION=y
CONFIG_FLASH_LOAD_OFFSET=0x27000
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_IDLE_STACK_SIZE=320
CONFIG_PM_DEVICE=y
CONFIG_BUILD_OUTPUT_BIN=y
CONFIG_MP_MAX_NUM_CPUS=1
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV7M_ITM_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M4F_ENABLED=y
CONFIG_DT_HAS_ARM_CRYPTOCELL_310_ENABLED=y
CONFIG_DT_HAS_ARM_V7M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ACL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CCM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_ECB_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_MWU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_RNG_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SPI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWI_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF52_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_NORDIC_QSPI_NOR_ENABLED=y
CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
CONFIG_DT_HAS_SEEED_XIAO_GPIO_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# altilium-charge-product (/home/raider0ne/projects/antworks/altilium-charge-product)
# Drivers
# end of Drivers
# Libraries
# CONFIG_CUSTOM_LIB is not set
# end of Libraries
CONFIG_ZEPHYR_ALTILIUM_CHARGE_PRODUCT_MODULE=y
# end of altilium-charge-product (/home/raider0ne/projects/antworks/altilium-charge-product)
# nrf (/home/raider0ne/projects/antworks/nrf)
CONFIG_NUM_METAIRQ_PRIORITIES=0
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
# CONFIG_INIT_STACKS is not set
# Nordic nRF Connect
CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_GETOPT is not set
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# Subsystems
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# end of Bootloader
# Bluetooth Low Energy
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
CONFIG_FOTA_DL_TIMEOUT_MIN=15
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_FOTA_POLL is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_ALERT is not set
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# CONFIG_NRF_CLOUD_COAP is not set
# Send shadow info sections on initial connect (MQTT/CoAP)
# end of Send shadow info sections on initial connect (MQTT/CoAP)
# CONFIG_NRF_CLOUD_GATEWAY is not set
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
CONFIG_MPSL_LOW_PRIO_IRQN=25
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=256
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# NCS subsystem configurations
# CONFIG_PM_SINGLE_IMAGE is not set
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# CONFIG_ZIGBEE is not set
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# nRF Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# CONFIG_NRF_SECURITY is not set
# CONFIG_PSA_WANT_GENERATE_RANDOM is not set
# CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
# CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
# CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
# CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
# CONFIG_PSA_WANT_KEY_TYPE_AES is not set
# CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
# CONFIG_PSA_WANT_KEY_TYPE_DES is not set
# CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
# CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_ALG_CCM is not set
# CONFIG_PSA_WANT_ALG_GCM is not set
# CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
# CONFIG_PSA_WANT_ALG_CBC_MAC is not set
# CONFIG_PSA_WANT_ALG_CMAC is not set
# CONFIG_PSA_WANT_ALG_HMAC is not set
# CONFIG_PSA_WANT_ALG_SHA_1 is not set
# CONFIG_PSA_WANT_ALG_SHA_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_256 is not set
# CONFIG_PSA_WANT_ALG_SHA_384 is not set
# CONFIG_PSA_WANT_ALG_SHA_512 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SHA3_224 is not set
# CONFIG_PSA_WANT_ALG_SHA3_256 is not set
# CONFIG_PSA_WANT_ALG_SHA3_384 is not set
# CONFIG_PSA_WANT_ALG_SHA3_512 is not set
# CONFIG_PSA_WANT_ALG_SM3 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
# CONFIG_PSA_WANT_ALG_MD2 is not set
# CONFIG_PSA_WANT_ALG_MD4 is not set
# CONFIG_PSA_WANT_ALG_MD5 is not set
# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
# CONFIG_PSA_WANT_ALG_CFB is not set
# CONFIG_PSA_WANT_ALG_CTR is not set
# CONFIG_PSA_WANT_ALG_OFB is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
# CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
# CONFIG_PSA_WANT_ALG_ECDH is not set
# CONFIG_PSA_WANT_ALG_FFDH is not set
# CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
# CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
# CONFIG_PSA_WANT_ALG_TLS12_PRF is not set
# CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS is not set
# CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS is not set
# CONFIG_PSA_WANT_ALG_ECDSA is not set
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# CONFIG_PSA_WANT_ALG_JPAKE is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
# end of nRF Security
# Audio Module
# CONFIG_AUDIO_MODULE_TEST is not set
CONFIG_AUDIO_MODULE_NAME_SIZE=20
# end of Audio Module
# CONFIG_SECURE_STORAGE is not set
# end of Subsystems
# CONFIG_WPA_SUPP is not set
CONFIG_POSIX_MAX_FDS=4
# Libraries
# Binary libraries
# Log levels
# end of Log levels
# end of Binary libraries
# CONFIG_AT_MONITOR is not set
# CONFIG_DISABLE_FLASH_PATCH is not set
# CONFIG_LTE_LINK_CONTROL is not set
CONFIG_NRF_ACL_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
# CONFIG_DK_LIBRARY is not set
# CONFIG_AT_CMD_PARSER is not set
# CONFIG_MODEM_INFO is not set
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_SMS is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
# CONFIG_HW_UNIQUE_KEY_LOAD is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0x1000
# CONFIG_MODEM_JWT is not set
# CONFIG_LOCATION is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
CONFIG_HW_CC3XX=y
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (/home/raider0ne/projects/antworks/nrf)
# wfa-qt-control-app (/home/raider0ne/projects/antworks/modules/lib/wfa-qt-control-app)
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
CONFIG_ZEPHYR_WFA_QT_CONTROL_APP_MODULE=y
# end of wfa-qt-control-app (/home/raider0ne/projects/antworks/modules/lib/wfa-qt-control-app)
# mcuboot (/home/raider0ne/projects/antworks/bootloader/mcuboot)
# MCUboot
CONFIG_SIGN_IMAGES=y
# CONFIG_BOOT_BUILD_DIRECT_XIP_VARIANT is not set
# CONFIG_MCUBOOT_BUILD_STRATEGY_USE_HEX_FILE is not set
# CONFIG_MCUBOOT_BUILD_STRATEGY_SKIP_BUILD is not set
CONFIG_MCUBOOT_BUILD_STRATEGY_FROM_SOURCE=y
CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
CONFIG_MCUBOOT_USB_SUPPORT=y
# CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD is not set
# CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS is not set
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (/home/raider0ne/projects/antworks/bootloader/mcuboot)
# mbedtls (/home/raider0ne/projects/antworks/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# PSA RNG support
# end of PSA RNG support
# PSA key type support
# end of PSA key type support
# PSA AEAD support
# end of PSA AEAD support
# PSA MAC support
# end of PSA MAC support
# PSA Hash support
# end of PSA Hash support
# PSA Cipher support
# end of PSA Cipher support
# PSA Key agreement support
# end of PSA Key agreement support
# PSA Key derivation support
# end of PSA Key derivation support
# PSA Asymmetric support
# Elliptic Curve type support
# end of Elliptic Curve type support
# end of PSA Asymmetric support
# end of mbedtls (/home/raider0ne/projects/antworks/modules/crypto/mbedtls)
# trusted-firmware-m (/home/raider0ne/projects/antworks/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
# end of trusted-firmware-m (/home/raider0ne/projects/antworks/modules/tee/tf-m/trusted-firmware-m)
# cjson (/home/raider0ne/projects/antworks/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (/home/raider0ne/projects/antworks/modules/lib/cjson)
# azure-sdk-for-c (/home/raider0ne/projects/antworks/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (/home/raider0ne/projects/antworks/modules/lib/azure-sdk-for-c)
# cirrus-logic (/home/raider0ne/projects/antworks/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (/home/raider0ne/projects/antworks/modules/hal/cirrus-logic)
# openthread (/home/raider0ne/projects/antworks/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (/home/raider0ne/projects/antworks/modules/lib/openthread)
# memfault-firmware-sdk (/home/raider0ne/projects/antworks/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (/home/raider0ne/projects/antworks/modules/lib/memfault-firmware-sdk)
# canopennode (/home/raider0ne/projects/antworks/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (/home/raider0ne/projects/antworks/modules/lib/canopennode)
# chre (/home/raider0ne/projects/antworks/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (/home/raider0ne/projects/antworks/modules/lib/chre)
# lz4 (/home/raider0ne/projects/antworks/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (/home/raider0ne/projects/antworks/modules/lib/lz4)
# nanopb (/home/raider0ne/projects/antworks/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (/home/raider0ne/projects/antworks/modules/lib/nanopb)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (/home/raider0ne/projects/antworks/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (/home/raider0ne/projects/antworks/modules/lib/zscilib)
# cmsis (/home/raider0ne/projects/antworks/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# end of cmsis (/home/raider0ne/projects/antworks/modules/hal/cmsis)
# cmsis-dsp (/home/raider0ne/projects/antworks/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (/home/raider0ne/projects/antworks/modules/lib/cmsis-dsp)
# cmsis-nn (/home/raider0ne/projects/antworks/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (/home/raider0ne/projects/antworks/modules/lib/cmsis-nn)
# fatfs (/home/raider0ne/projects/antworks/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (/home/raider0ne/projects/antworks/modules/fs/fatfs)
# hal_nordic (/home/raider0ne/projects/antworks/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_RADIO_DRIVER is not set
# CONFIG_NRF_802154_SER_RADIO is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
# CONFIG_NRFX_I2S0 is not set
# CONFIG_NRFX_NFCT is not set
# CONFIG_NRFX_NVMC is not set
# CONFIG_NRFX_PDM is not set
CONFIG_NRFX_POWER=y
# CONFIG_NRFX_PPI is not set
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_QDEC0 is not set
# CONFIG_NRFX_QSPI is not set
# CONFIG_NRFX_RNG is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPI2 is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_WDT0 is not set
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of nrfx drivers
# end of hal_nordic (/home/raider0ne/projects/antworks/modules/hal/nordic)
CONFIG_ZEPHYR_ST_MODULE=y
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# liblc3 (/home/raider0ne/projects/antworks/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (/home/raider0ne/projects/antworks/modules/lib/liblc3)
# littlefs (/home/raider0ne/projects/antworks/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (/home/raider0ne/projects/antworks/modules/fs/littlefs)
# loramac-node (/home/raider0ne/projects/antworks/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (/home/raider0ne/projects/antworks/modules/lib/loramac-node)
# lvgl (/home/raider0ne/projects/antworks/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (/home/raider0ne/projects/antworks/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# picolibc (/home/raider0ne/projects/antworks/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (/home/raider0ne/projects/antworks/modules/lib/picolibc)
# segger (/home/raider0ne/projects/antworks/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
# CONFIG_USE_SEGGER_RTT is not set
# end of segger (/home/raider0ne/projects/antworks/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (/home/raider0ne/projects/antworks/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (/home/raider0ne/projects/antworks/modules/lib/uoscore-uedhoc)
# zcbor (/home/raider0ne/projects/antworks/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (/home/raider0ne/projects/antworks/modules/lib/zcbor)
# nrfxlib (/home/raider0ne/projects/antworks/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
# end of nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# CONFIG_MPSL is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_NRFXLIB_CRYPTO=y
CONFIG_HAS_HW_NRF_CC3XX=y
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
CONFIG_NRF_CC3XX_PLATFORM=y
CONFIG_CC3XX_MUTEX_LOCK=y
# CONFIG_CC3XX_ATOMIC_LOCK is not set
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_GZLL is not set
# CONFIG_NRF_DM is not set
# CONFIG_LC3_PLC_DISABLED is not set
CONFIG_LC3_ENC_CHAN_MAX=1
CONFIG_LC3_DEC_CHAN_MAX=1
# Encoder sample rates
CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Encoder sample rates
# Decoder sample rates
CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
# end of Decoder sample rates
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (/home/raider0ne/projects/antworks/nrfxlib)
# connectedhomeip (/home/raider0ne/projects/antworks/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (/home/raider0ne/projects/antworks/modules/lib/matter)
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
CONFIG_MCUBOOT_CMAKE_WEST_SIGN_PARAMS="--quiet"
CONFIG_MCUBOOT_SIGNATURE_KEY_FILE=""
CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="0.0.0+0"
CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
# CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
# CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
# On board MCUboot operation mode
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
# CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
# CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
# CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
# end of On board MCUboot operation mode
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=8192
CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=6
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD_REVISION=""
# CONFIG_NET_DRIVERS is not set
CONFIG_BOARD_XIAO_BLE=y
# Board Options
CONFIG_BOARD_ENABLE_DCDC_HV=y
# end of Board Options
# CONFIG_SOC_SERIES_APOLLO4X is not set
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
# CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MPS3 is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_MUSCA_S1 is not set
# CONFIG_SOC_SERIES_AST10X0 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4L is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_SAMC20 is not set
# CONFIG_SOC_SERIES_SAMC21 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAML21 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAMR34 is not set
# CONFIG_SOC_SERIES_SAMR35 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_PSOC63 is not set
# CONFIG_SOC_SERIES_GD32A50X is not set
# CONFIG_SOC_SERIES_GD32E10X is not set
# CONFIG_SOC_SERIES_GD32E50X is not set
# CONFIG_SOC_SERIES_GD32F3X0 is not set
# CONFIG_SOC_SERIES_GD32F403 is not set
# CONFIG_SOC_SERIES_GD32F4XX is not set
# CONFIG_SOC_SERIES_GD32L23X is not set
# CONFIG_SOC_SERIES_PSOC_60 is not set
# CONFIG_SOC_SERIES_PSOC_61 is not set
# CONFIG_SOC_SERIES_PSOC_62 is not set
# CONFIG_SOC_SERIES_PSOC_63 is not set
# CONFIG_SOC_SERIES_PSOC_64 is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_CYCLONE5 is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC172X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
CONFIG_SOC_SERIES_NRF52X=y
# CONFIG_SOC_SERIES_NRF53X is not set
# CONFIG_SOC_SERIES_NRF91X is not set
# CONFIG_SOC_SERIES_NPCX4 is not set
# CONFIG_SOC_SERIES_NPCX7 is not set
# CONFIG_SOC_SERIES_NPCX9 is not set
# CONFIG_SOC_SERIES_M46X is not set
# CONFIG_SOC_SERIES_M48X is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX8ML_M7 is not set
# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
# CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_IMX_RT5XX is not set
# CONFIG_SOC_SERIES_IMX_RT6XX is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC11U6X is not set
# CONFIG_SOC_SERIES_LPC51U68 is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_SERIES_S32K3XX is not set
# CONFIG_SOC_SERIES_S32ZE_R52 is not set
# CONFIG_SOC_EOS_S3 is not set
# CONFIG_SOC_SERIES_RA4M1 is not set
# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
# CONFIG_SOC_RENESAS_RZT2M is not set
# CONFIG_SOC_SERIES_DA1469X is not set
# CONFIG_SOC_SERIES_RP2XXX is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32GG12B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32PG1B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32BG22 is not set
# CONFIG_SOC_SERIES_EFR32BG27 is not set
# CONFIG_SOC_SERIES_EFR32FG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_EFR32MG21 is not set
# CONFIG_SOC_SERIES_EFR32MG24 is not set
# CONFIG_SOC_SERIES_STM32C0X is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H5X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32U5X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_SERIES_STM32WBAX is not set
# CONFIG_SOC_SERIES_STM32WLX is not set
# CONFIG_SOC_SERIES_AM62X_M4 is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
# CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_HAS_SWO=y
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_GPIO_INIT_PRIORITY=40
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_ACL=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIO1=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NFCT=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_QSPI=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
CONFIG_HAS_HW_NRF_RADIO_TX_PWR_HIGH=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI2=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TWI1=y
CONFIG_HAS_HW_NRF_USBD=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_SOC_NRF52840=y
# CONFIG_SOC_NRF52805_CAAA is not set
# CONFIG_SOC_NRF52810_QFAA is not set
# CONFIG_SOC_NRF52811_QFAA is not set
# CONFIG_SOC_NRF52820_QDAA is not set
# CONFIG_SOC_NRF52832_CIAA is not set
# CONFIG_SOC_NRF52832_QFAA is not set
# CONFIG_SOC_NRF52832_QFAB is not set
# CONFIG_SOC_NRF52833_QDAA is not set
# CONFIG_SOC_NRF52833_QIAA is not set
# CONFIG_SOC_NRF52840_QFAA is not set
CONFIG_SOC_NRF52840_QIAA=y
CONFIG_SOC_DCDC_NRF52X=y
CONFIG_SOC_DCDC_NRF52X_HV=y
# CONFIG_GPIO_AS_PINRESET is not set
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
# CONFIG_NFCT_PINS_AS_GPIOS is not set
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_TRACE_PORT is not set
# CONFIG_NRF_STORE_REBOOT_TYPE_GPREGRET is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
# ARM Options
CONFIG_ARCH="arm"
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_FAULT_DUMP=2
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
CONFIG_MPU_STACK_GUARD=y
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
CONFIG_LITTLE_ENDIAN=y
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
# CONFIG_SHARED_INTERRUPTS is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# Floating Point Options
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
# General Kernel Options
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_ISR_STACK_SIZE=2048
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
CONFIG_LIBC_ERRNO=y
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
CONFIG_BOOT_BANNER=y
CONFIG_BOOT_DELAY=0
CONFIG_THREAD_MONITOR=y
CONFIG_THREAD_NAME=y
CONFIG_THREAD_MAX_NAME_LEN=32
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# CONFIG_POLL is not set
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
CONFIG_EVENTS=y
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
CONFIG_XIP=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_THREAD_LOCAL_STORAGE=y
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_DEPS is not set
# end of Device Options
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
# CONFIG_ADC is not set
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# CONFIG_CACHE is not set
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
CONFIG_CLOCK_CONTROL_NPCX_SUPP_APB4=y
# CONFIG_CLOCK_CONTROL_NPCX_SUPP_FIU1 is not set
# CONFIG_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_COUNTER is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
# CONFIG_ENTROPY_GENERATOR is not set
# CONFIG_ESPI is not set
# CONFIG_FLASH is not set
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
CONFIG_HWINFO=y
CONFIG_HWINFO_NRF=y
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2C is not set
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
# CONFIG_INTC_ESP32 is not set
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_KSCAN is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
# CONFIG_MBOX is not set
# CONFIG_MDIO is not set
# CONFIG_MFD is not set
# Miscellaneous Drivers
# CONFIG_GROVE_LCD_RGB is not set
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
# CONFIG_PM_CPU_OPS is not set
# CONFIG_POWER_DOMAIN is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_REGULATOR is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
# CONFIG_SMBUS is not set
# CONFIG_SYSCON is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
CONFIG_USB_DEVICE_DRIVER=y
# CONFIG_USB_DC_HAS_HS_SUPPORT is not set
CONFIG_USB_DEVICE_REMOTE_WAKEUP=y
CONFIG_USB_NRFX=y
CONFIG_USB_NRFX_EVT_QUEUE_SIZE=32
CONFIG_USB_NRFX_WORK_QUEUE_STACK_SIZE=1024
CONFIG_USB_NRFX_ATTACHED_EVENT_DELAY=0
CONFIG_NRF_USBD_COMMON=y
CONFIG_NRF_USBD_ISO_IN_ZLP=y
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
# CONFIG_REQUIRES_FULL_LIBC is not set
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_MINIMAL_LIBC is not set
CONFIG_PICOLIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
CONFIG_COMMON_LIBC_MALLOC=y
CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
CONFIG_COMMON_LIBC_CALLOC=y
CONFIG_COMMON_LIBC_REALLOCARRAY=y
# CONFIG_PICOLIBC_USE_MODULE is not set
CONFIG_PICOLIBC_USE_TOOLCHAIN=y
CONFIG_PICOLIBC_HEAP_SIZE=-2
# CONFIG_PICOLIBC_IO_FLOAT is not set
CONFIG_PICOLIBC_IO_LONG_LONG=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# Deprecated
# CONFIG_CPLUSPLUS is not set
# CONFIG_LIB_CPLUSPLUS is not set
# end of Deprecated
# end of C++ Language Support
# CONFIG_CRC is not set
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# OS Support Library
# CONFIG_FDTABLE is not set
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
CONFIG_ONOFF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# CONFIG_WINSTREAM is not set
CONFIG_REBOOT=y
CONFIG_HAS_POWEROFF=y
# CONFIG_POWEROFF is not set
# CONFIG_UTF8 is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Heap and Memory Allocation
# end of OS Support Library
# CONFIG_POSIX_API is not set
# CONFIG_POSIX_CLOCK is not set
# CONFIG_EVENTFD is not set
# CONFIG_FNMATCH is not set
# CONFIG_POSIX_MQUEUE is not set
CONFIG_SEM_VALUE_MAX=32767
# CONFIG_POSIX_SIGNAL is not set
# CONFIG_TIMER is not set
CONFIG_MAX_TIMER_COUNT=5
CONFIG_TIMER_CREATE_WAIT=100
CONFIG_TIMER_DELAYTIMER_MAX=20
# CONFIG_POSIX_UNAME is not set
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_ACPI_HID_LEN_MAX=12
CONFIG_LIBGCC_RTLIB=y
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_NVS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# Logging
# CONFIG_LOG is not set
# CONFIG_LOG_OUTPUT is not set
# end of Logging
CONFIG_MEM_ATTR=y
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
# CONFIG_NET_BUF is not set
# CONFIG_NETWORKING is not set
# end of Networking
# Power Management
CONFIG_PM_DEVICE_POWER_DOMAIN=y
CONFIG_PM_DEVICE_RUNTIME_EXCLUSIVE=y
# end of Power Management
# Portability
# end of Portability
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
# CONFIG_SETTINGS is not set
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_VID=0x2FE3
CONFIG_USB_DEVICE_PID=0x0100
CONFIG_USB_DEVICE_MANUFACTURER="ZEPHYR"
CONFIG_USB_DEVICE_PRODUCT="USB-DEV"
CONFIG_USB_DEVICE_SN="0123456789ABCDEF"
# CONFIG_USB_COMPOSITE_DEVICE is not set
CONFIG_USB_MAX_NUM_TRANSFERS=4
CONFIG_USB_REQUEST_BUFFER_SIZE=128
CONFIG_USB_MAX_ALT_SETTING=8
CONFIG_USB_NUMOF_EP_WRITE_RETRIES=3
# CONFIG_USB_DEVICE_SOF is not set
# CONFIG_USB_DEVICE_BOS is not set
# CONFIG_USB_DEVICE_OS_DESC is not set
CONFIG_USB_SELF_POWERED=y
CONFIG_USB_MAX_POWER=50
# CONFIG_USB_WORKQUEUE is not set
# USB CDC ACM Class support
# end of USB CDC ACM Class support
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_DEVICE_BLUETOOTH is not set
# CONFIG_USB_DEVICE_BT_H4 is not set
# CONFIG_USB_DEVICE_LOOPBACK is not set
# USB Device Networking support
# CONFIG_USB_DEVICE_NETWORK_ECM is not set
# CONFIG_USB_DEVICE_NETWORK_EEM is not set
# CONFIG_USB_DEVICE_NETWORK_RNDIS is not set
# end of USB Device Networking support
# CONFIG_USB_DEVICE_HID is not set
# CONFIG_USB_DEVICE_AUDIO is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
CONFIG_FLASH_LOAD_SIZE=0xc5000
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
CONFIG_SRAM_OFFSET=0
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_COMPILER_FREESTANDING is not set
# CONFIG_SIZE_OPTIMIZATIONS is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
CONFIG_DEBUG_OPTIMIZATIONS=y
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
CONFIG_BUILD_OUTPUT_UF2=y
CONFIG_BUILD_OUTPUT_UF2_FAMILY_ID="0xada52840"
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
CONFIG_BUILD_OUTPUT_META=y
# CONFIG_BUILD_OUTPUT_META_STATE_PROPAGATE is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_WARN_DEPRECATED=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
    Thanks for providing a full .config for both app and mcuboot. This helps quite a lot to reproduce the issue.
    The problem is related to the QSPI enabled in the xiao_ble board. Could you try to explicitly disable it in child_images/mcuboot.conf?
    CONFIG_NORDIC_QSPI_NOR=n
    I see 3.2 uA when this is disabled in mcuboot.
    Håkon
  • Thank you Håkon for the quick response!!
    As you mentioned, I've disabled QSPI NOR in mcuboot.conf. This resulted in the idle current going down to 150uA! Significant improvement, but still not quite there yet.....
    Tried doing the same in the main project, but did not result in any change in the current draw.
    The main application has FLASH enabled as we need it for DFU etc...
    I tried suspending flash when not needed as per this doc:  Guide to reducing power but this did not show any significant change.
    Is there any additional info you need from my end to diagnose the issue?
    prj.conf for the actual application that I am trying to fix. 1.5mA is the idle current draw when this is running
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
    CONFIG_SENSOR=y
    CONFIG_GPIO=y
    CONFIG_LOG=n
    CONFIG_CBPRINTF_FP_SUPPORT=y
    CONFIG_LOG_MAX_LEVEL=4
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_PM_DEVICE=y
    CONFIG_SERIAL=n
    CONFIG_CONSOLE=n
    CONFIG_REBOOT=y
    CONFIG_MAIN_STACK_SIZE=2048
    CONFIG_INIT_STACKS=y
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="Altilium Charge"
    CONFIG_BT_SMP=y
    CONFIG_BT_SIGNING=y
    CONFIG_BT_KEYS_OVERWRITE_OLDEST=y
    # CONFIG_BT_SETTINGS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_NVS=y
    # CONFIG_SETTINGS=y
    CONFIG_NET_BUF=y
    CONFIG_ZCBOR=y
    CONFIG_CRC=y
    CONFIG_MCUMGR=y
    CONFIG_STREAM_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_STATS=y
    CONFIG_STATS_NAMES=y
    CONFIG_MCUMGR_GRP_OS_TASKSTAT=y
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUMGR_GRP_IMG=y
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_GRP_STAT=y
    CONFIG_BT_L2CAP_TX_MTU=498
    CONFIG_BT_BUF_ACL_RX_SIZE=502
    CONFIG_BT_BUF_ACL_TX_SIZE=502
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    CONFIG_MCUMGR_TRANSPORT_BT=y
    CONFIG_MCUMGR_TRANSPORT_BT_AUTHEN=n
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
    CONFIG_BASE64=y
    CONFIG_SHELL=y
    CONFIG_SHELL_BACKEND_SERIAL=n
    CONFIG_MCUMGR_TRANSPORT_SHELL=y
    CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=2475
    CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=4608
    # Enable the LittleFS file system.
    CONFIG_FILE_SYSTEM=y
    CONFIG_FILE_SYSTEM_LITTLEFS=y
    # Enable file system commands
    CONFIG_MCUMGR_GRP_FS=y
    # Enable the storage erase command.
    CONFIG_MCUMGR_GRP_ZBASIC=y
    CONFIG_MCUMGR_GRP_ZBASIC_STORAGE_ERASE=y
    CONFIG_CLOCK_CONTROL_NRF_SHELL=n
    CONFIG_DEVICE_SHELL=n
    CONFIG_DEVMEM_SHELL=n
    CONFIG_FLASH_SHELL=n
    .conf for xiao ble for the same
    # Zephyr
    # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
    CONFIG_BT_HCI_VS_EXT=y
    CONFIG_BT_CTLR=y
    CONFIG_NUM_IRQS=48
    CONFIG_PINCTRL=y
    CONFIG_GPIO=y
    CONFIG_TINYCRYPT=y
    CONFIG_PM_DEVICE=y
    # CONFIG_BT_USER_PHY_UPDATE is not set
    # Devicetree Info
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_TI_INA219_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_CDC_ACM_UART_ENABLED=y
    # Modules
    # Drivers
    # end of Drivers
    # Libraries
    # end of Libraries
    CONFIG_BT_BUF_CMD_TX_COUNT=2
    CONFIG_NORDIC_QSPI_NOR=y
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set
    # CONFIG_MCUMGR_TRANSPORT_BT_AUTHEN is not set
    # CONFIG_IMG_ERASE_PROGRESSIVELY is not set
    CONFIG_NORDIC_QSPI_NOR_STACK_WRITE_BUFFER_SIZE=4
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
    # Subsystems
    # Bootloader
    # end of Bootloader
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LL_SOFTDEVICE=y
    # SoftDevice Controller
    CONFIG_BT_LL_SOFTDEVICE_BUILD_TYPE_LIB=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1536
    CONFIG_BT_RX_STACK_SIZE=1536
    # CONFIG_BT_CTLR_SDC_LLPM is not set
    # CONFIG_BT_CTLR_SDC_QOS_CHANNEL_SURVEY is not set
    CONFIG_BT_CTLR_SDC_PERIPHERAL_COUNT=1
    # CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_CENTRAL_ACL_EVENT_SPACING_DEFAULT=7500
    # CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT_OVERRIDE is not set
    CONFIG_BT_CTLR_SDC_PERIODIC_ADV_EVENT_LEN_DEFAULT=7500
    CONFIG_BT_CTLR_SDC_TX_PACKET_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PACKET_COUNT=2
    CONFIG_BT_CTLR_SDC_SCAN_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_PERIODIC_SYNC_BUFFER_COUNT=3
    CONFIG_BT_CTLR_SDC_RX_PRIO=6
    # CONFIG_BT_CTLR_DF is not set
    CONFIG_BT_LL_SOFTDEVICE_PERIPHERAL=y
    # CONFIG_BT_LL_SOFTDEVICE_MULTIROLE is not set
    # CONFIG_BT_LL_SOFTDEVICE_EXPERIMENTAL_ISO is not set
    CONFIG_BT_CTLR_FAL_SIZE=8
    CONFIG_BT_CTLR_ECDH_LIB_OBERON=y
    # CONFIG_BT_CTLR_ECDH_LIB_TINYCRYPT is not set
    CONFIG_BT_CTLR_ECDH_STACK_SIZE=900
    # CONFIG_BT_CTLR_ECDH_IN_MPSL_WORK is not set
    # CONFIG_BT_CTLR_SDC_EVENT_TRIGGER is not set
    # end of SoftDevice Controller
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_CONN_CTX is not set
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    # CONFIG_BT_DIS is not set
    CONFIG_BT_GATT_AUTO_SEC_REQ=y
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    # CONFIG_BT_RPC_STACK is not set
    # CONFIG_BT_CENTRAL is not set
    # CONFIG_BT_OBSERVER is not set
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_ACL_RX_COUNT=6
    CONFIG_BT_BUF_EVT_RX_SIZE=68
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=43
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=65
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_HCI_VS_EVT is not set
    # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_RPA=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_LOG is not set
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_DEBUG_MONITOR_RTT is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=1300
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_LONG_WQ_INIT_PRIO=50
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=0
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_AUDIO is not set
    # CONFIG_BT_HOST_CRYPTO is not set
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=8
    CONFIG_BT_CONN_TX_MAX=3
    # CONFIG_BT_CONN_PARAM_ANY is not set
    CONFIG_BT_AUTO_PHY_UPDATE=y
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    # CONFIG_BT_REMOTE_INFO is not set
    CONFIG_BT_SMP=y
    # CONFIG_BT_PASSKEY_KEYPRESS is not set
    # CONFIG_BT_PRIVACY is not set
    CONFIG_BT_SIGNING=y
    # CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
    # CONFIG_BT_SMP_SC_PAIR_ONLY is not set
    # CONFIG_BT_SMP_SC_ONLY is not set
    # CONFIG_BT_SMP_OOB_LEGACY_PAIR_ONLY is not set
    # CONFIG_BT_SMP_DISABLE_LEGACY_JW_PASSKEY is not set
    # CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
    # CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set
    # CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set
    # CONFIG_BT_FIXED_PASSKEY is not set
    # CONFIG_BT_USE_DEBUG_KEYS is not set
    CONFIG_BT_BONDABLE=y
    # CONFIG_BT_BONDING_REQUIRED is not set
    # CONFIG_BT_BONDABLE_PER_CONNECTION is not set
    # CONFIG_BT_STORE_DEBUG_KEYS is not set
    CONFIG_BT_SMP_ENFORCE_MITM=y
    CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=7
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    CONFIG_BT_L2CAP_RESCHED_MS=1000
    # CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    CONFIG_BT_ATT_ENFORCE_FLOW=y
    CONFIG_BT_ATT_PREPARE_COUNT=0
    CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    CONFIG_BT_GATT_DYNAMIC_DB=y
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    # CONFIG_BT_GATT_CLIENT is not set
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
    CONFIG_BT_MAX_PAIRED=1
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=1
    CONFIG_BT_ECC=y
    # CONFIG_BT_TINYCRYPT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    CONFIG_BT_CRYPTO=y
    # DFU
    # end of DFU
    # CONFIG_EMDS is not set
    # Networking
    # nRF Cloud
    # end of nRF Cloud
    # end of Networking
    # NFC
    # end of NFC
    # Debug
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    CONFIG_MPSL_FEM_API_AVAILABLE=y
    CONFIG_MPSL_THREAD_COOP_PRIO=6
    # Partition Manager
    CONFIG_PM_PARTITION_SIZE_LITTLEFS=0x6000
    CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x6000
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    # nRF Security
    # Audio Module
    # end of Subsystems
    # Libraries
    # Binary libraries
    # Log levels
    # end of Log levels
    CONFIG_MULTITHREADING_LOCK=y
    # end of Libraries
    # Device Drivers
    CONFIG_ENTROPY_CC3XX=y
    CONFIG_HW_CC3XX=y
    CONFIG_SENSOR=y
    # CONFIG_BH1749 is not set
    # CONFIG_SENSOR_SIM is not set
    # CONFIG_SENSOR_STUB is not set
    # CONFIG_PMW3360 is not set
    # CONFIG_PAW3212 is not set
    CONFIG_CLOCK_CONTROL_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=1
    CONFIG_TEMP_NRF5_MPSL=y
    # Test
    # Mocks
    # end of Mocks
    # end of Test
    # MCUboot
    # end of MCUboot
    # PSA RNG support
    # PSA AEAD support
    # PSA MAC support
    # PSA Hash support
    CONFIG_BOOTLOADER_MCUBOOT=y
    # Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # CONFIG_NRFX_CLOCK is not set
    CONFIG_NRFX_NVMC=y
    CONFIG_NRFX_POWER=y
    CONFIG_NRFX_QSPI=y
    CONFIG_NRFX_TWIM=y
    CONFIG_NRFX_TWIM1=y
    # CONFIG_SEGGER_RTT_CUSTOM_LOCKING is not set
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    CONFIG_SEGGER_RTT_SECTION_NONE=y
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    CONFIG_ZCBOR=y
    # CONFIG_ZCBOR_CANONICAL is not set
    # CONFIG_ZCBOR_STOP_ON_ERROR is not set
    # CONFIG_ZCBOR_VERBOSE is not set
    # Nordic nrfxlib
    CONFIG_MPSL=y
    CONFIG_MPSL_BUILD_TYPE_LIB=y
    CONFIG_NRF_OBERON=y
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    # CONFIG_TINYCRYPT_SHA256 is not set
    # CONFIG_TINYCRYPT_ECC_DH is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    CONFIG_TINYCRYPT_AES_CMAC=y
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.0.0+0"
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    # end of Modules
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC=y
    CONFIG_HAS_SWO=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    CONFIG_ISA_THUMB2=y
    CONFIG_FAULT_DUMP=2
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    CONFIG_ZERO_LATENCY_IRQS=y
    CONFIG_ZERO_LATENCY_LEVELS=1
    CONFIG_ARM_MPU=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_ARM=y
    CONFIG_MPU=y
    # Cache Options
    CONFIG_MULTITHREADING=y
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    CONFIG_WAITQ_DUMB=y
    CONFIG_BOOT_DELAY=0
    # Atomic Operations
    # Timer API Options
    CONFIG_POLL=y
    CONFIG_EVENTS=y
    CONFIG_XIP=y
    # Security Options
    # CONFIG_STACK_CANARIES is not set
    CONFIG_STACK_POINTER_RANDOM=0
    # SMP Options
    # Device Options
    # Device Drivers
    CONFIG_CLOCK_CONTROL_NRF_FORCE_ALT=y
    # CONFIG_CLOCK_CONTROL_NRF_SHELL is not set
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_ENTROPY_INIT_PRIORITY=50
    CONFIG_ENTROPY_NRF5_RNG=y
    # CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
    CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
    CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
    CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
    CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
    CONFIG_ENTROPY_BT_HCI=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_JESD216=y
    CONFIG_FLASH=y
    # CONFIG_FLASH_JESD216_API is not set
    # CONFIG_FLASH_SHELL is not set
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_SOC_FLASH_NRF=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE is not set
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    CONFIG_SOC_FLASH_NRF_TIMEOUT_MULTIPLIER=10
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    CONFIG_NORDIC_QSPI_NOR_INIT_PRIORITY=41
    # CONFIG_GPIO_SHELL is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_HWINFO=y
    # CONFIG_HWINFO_SHELL is not set
    CONFIG_HWINFO_NRF=y
    CONFIG_I2C=y
    # CONFIG_I2C_SHELL is not set
    # CONFIG_I2C_STATS is not set
    # CONFIG_I2C_CALLBACK is not set
    # CONFIG_I2C_RTIO is not set
    # CONFIG_I2C_DW_LPSS_DMA is not set
    # CONFIG_I2C_TARGET is not set
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_NRFX_TWIM=y
    CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
    CONFIG_I2C_INIT_PRIORITY=50
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    CONFIG_SENSOR_INIT_PRIORITY=90
    # CONFIG_SENSOR_ASYNC_API is not set
    # CONFIG_SENSOR_SHELL is not set
    # CONFIG_SENSOR_SHELL_BATTERY is not set
    # CONFIG_SENSOR_INFO is not set
    # Device Drivers
    # CONFIG_ICM42688_DECODER is not set
    CONFIG_INA219=y
    CONFIG_VCMP_IT8XXX2_INIT_PRIORITY=90
    CONFIG_TEMP_NRF5_FORCE_ALT=y
    CONFIG_TEMP_NRF5=y
    CONFIG_TMP112_FULL_SCALE_RUNTIME=y
    CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
    # Timer drivers
    CONFIG_NRF_RTC_TIMER_LOCK_ZERO_LATENCY_IRQS=y
    CONFIG_USB_NRFX=y
    # C Library
    CONFIG_PICOLIBC=y
    CONFIG_PICOLIBC_IO_FLOAT=y
    # end of C Library
    # Deprecated
    # end of Deprecated
    CONFIG_CRC=y
    # CONFIG_CRC_SHELL is not set
    CONFIG_RING_BUFFER=y
    CONFIG_NOTIFY=y
    CONFIG_BASE64=y
    CONFIG_ONOFF=y
    CONFIG_REBOOT=y
    CONFIG_FNMATCH=y
    # CONFIG_POSIX_FS is not set
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # end of Bluetooth Host
    CONFIG_BT_CTLR_LE_ENC_SUPPORT=y
    CONFIG_BT_CTLR_EXT_REJ_IND_SUPPORT=y
    CONFIG_BT_CTLR_DATA_LEN_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PRIVACY_SUPPORT=y
    CONFIG_BT_CTLR_EXT_SCAN_FP_SUPPORT=y
    CONFIG_BT_CTLR_PHY_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_PHY_2M_SUPPORT=y
    CONFIG_BT_CTLR_PHY_CODED_SUPPORT=y
    CONFIG_BT_CTLR_ADV_EXT_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_ADV_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_PERIODIC_RSP_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_SENDER_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_TRANSFER_RECEIVER_SUPPORT=y
    CONFIG_BT_CTLR_ADV_ISO_SUPPORT=y
    CONFIG_BT_CTLR_SYNC_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CENTRAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_PERIPHERAL_ISO_SUPPORT=y
    CONFIG_BT_CTLR_CHAN_SEL_2_SUPPORT=y
    CONFIG_BT_CTLR_SCA_UPDATE_SUPPORT=y
    CONFIG_BT_CTLR_CONN_RSSI_SUPPORT=y
    CONFIG_BT_CTLR_ECDH_SUPPORT=y
    CONFIG_BT_CTLR_LE_POWER_CONTROL_SUPPORT=y
    # CONFIG_BT_LL_SW_SPLIT is not set
    # BLE Controller configuration
    CONFIG_BT_CTLR_CRYPTO=y
    CONFIG_BT_CTLR_HCI_VS_BUILD_INFO=""
    # CONFIG_BT_CTLR_TX_PWR_PLUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_7 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_6 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_5 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_3 is not set
    # CONFIG_BT_CTLR_TX_PWR_PLUS_2 is not set
    CONFIG_BT_CTLR_TX_PWR_0=y
    # CONFIG_BT_CTLR_TX_PWR_MINUS_4 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_8 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_12 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_16 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_20 is not set
    # CONFIG_BT_CTLR_TX_PWR_MINUS_40 is not set
    CONFIG_BT_CTLR_TX_PWR_DBM=0
    CONFIG_BT_CTLR_TX_PWR_ANTENNA=0
    # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL is not set
    # BLE Controller features
    CONFIG_BT_CTLR_LE_ENC=y
    CONFIG_BT_CTLR_ECDH=y
    CONFIG_BT_CTLR_EXT_REJ_IND=y
    CONFIG_BT_CTLR_LE_PING=y
    CONFIG_BT_CTLR_DATA_LENGTH=y
    CONFIG_BT_CTLR_PHY=y
    # CONFIG_BT_CTLR_CONN_RSSI is not set
    # CONFIG_BT_CTLR_LE_POWER_CONTROL is not set
    # CONFIG_BT_CTLR_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_CTLR_PRIVACY=y
    CONFIG_BT_CTLR_RL_SIZE=8
    CONFIG_BT_CTLR_PHY_2M=y
    # CONFIG_BT_CTLR_PHY_CODED is not set
    CONFIG_BT_CTLR_CHAN_SEL_2=y
    # CONFIG_BT_CTLR_ADV_EXT is not set
    # CONFIG_BT_CTLR_SET_HOST_FEATURE is not set
    # CONFIG_BT_CTLR_PERIPHERAL_ISO is not set
    # CONFIG_BT_CTLR_HCI_CODEC_AND_DELAY_INFO is not set
    # CONFIG_BT_CTLR_ASSERT_HANDLER is not set
    # CONFIG_BT_SHELL is not set
    # CONFIG_BT_EAD is not set
    # Debugging Options
    CONFIG_PRINTK=y
    # CONFIG_DEBUG_THREAD_INFO is not set
    CONFIG_MCUBOOT_IMG_MANAGER=y
    # CONFIG_MCUBOOT_SHELL is not set
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # File Systems
    CONFIG_APP_LINK_WITH_FS=y
    CONFIG_FILE_SYSTEM_MAX_TYPES=2
    CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1
    # CONFIG_FILE_SYSTEM_SHELL is not set
    # CONFIG_FILE_SYSTEM_MKFS is not set
    # CONFIG_FAT_FILESYSTEM_ELM is not set
    # LittleFS Settings
    CONFIG_FS_LITTLEFS_NUM_FILES=4
    CONFIG_FS_LITTLEFS_NUM_DIRS=4
    CONFIG_FS_LITTLEFS_READ_SIZE=16
    CONFIG_FS_LITTLEFS_PROG_SIZE=16
    CONFIG_FS_LITTLEFS_CACHE_SIZE=64
    CONFIG_FS_LITTLEFS_LOOKAHEAD_SIZE=32
    CONFIG_FS_LITTLEFS_BLOCK_CYCLES=512
    # end of LittleFS Settings
    CONFIG_FS_LITTLEFS_FC_HEAP_SIZE=0
    CONFIG_FS_LITTLEFS_HEAP_PER_ALLOC_OVERHEAD_SIZE=32
    CONFIG_FS_LITTLEFS_FMP_DEV=y
    # CONFIG_FS_LITTLEFS_BLK_DEV is not set
    # CONFIG_FILE_SYSTEM_EXT2 is not set
    # CONFIG_FCB is not set
    CONFIG_NVS=y
    # CONFIG_NVS_LOOKUP_CACHE is not set
    # Logging
    # end of Logging
    CONFIG_MEM_ATTR=y
    # Device Management
    CONFIG_MCUMGR=y
    # CONFIG_MCUMGR_MGMT_NOTIFICATION_HOOKS is not set
    # CONFIG_MCUMGR_MGMT_HANDLER_USER_DATA is not set
    CONFIG_MCUMGR_SMP_CBOR_MAX_MAIN_MAP_ENTRIES=15
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_DECODING_LEVEL_2=y
    CONFIG_MCUMGR_SMP_CBOR_MAX_DECODING_LEVELS=2
    CONFIG_MCUMGR_SMP_CBOR_MIN_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_CBOR_MAX_ENCODING_LEVELS=0
    CONFIG_MCUMGR_SMP_SUPPORT_ORIGINAL_PROTOCOL=y
    # CONFIG_MCUMGR_SMP_VERBOSE_ERR_RESPONSE is not set
    # CONFIG_MCUMGR_SMP_LEGACY_RC_BEHAVIOUR is not set
    # SMP Client
    # CONFIG_SMP_CLIENT is not set
    # end of SMP Client
    # Command Handlers
    CONFIG_MCUMGR_GRP_FS_MAX_FILE_SIZE_64KB=y
    # CONFIG_MCUMGR_GRP_FS_MAX_FILE_SIZE_4GB is not set
    CONFIG_MCUMGR_GRP_FS_MAX_OFFSET_LEN=3
    # CONFIG_MCUMGR_GRP_FS_DL_CHUNK_SIZE_LIMIT is not set
    CONFIG_MCUMGR_GRP_FS_FILE_STATUS=y
    # CONFIG_MCUMGR_GRP_FS_CHECKSUM_HASH is not set
    CONFIG_MCUMGR_GRP_FS_PATH_LEN=64
    CONFIG_MCUMGR_GRP_FS_FILE_SEMAPHORE_TAKE_TIME=100
    CONFIG_MCUMGR_GRP_FS_FILE_AUTOMATIC_IDLE_CLOSE_TIME=4000
    # CONFIG_MCUMGR_GRP_IMG_USE_HEAP_FOR_FLASH_IMG_CONTEXT is not set
    CONFIG_MCUMGR_GRP_IMG_UPDATABLE_IMAGE_NUMBER=1
    # CONFIG_MCUMGR_GRP_IMG_VERBOSE_ERR is not set
    CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_SECONDARY=y
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_CONFIRM_NON_ACTIVE_IMAGE_ANY is not set
    # CONFIG_MCUMGR_GRP_IMG_ALLOW_ERASE_PENDING is not set
    # CONFIG_MCUMGR_GRP_IMG_DIRECT_UPLOAD is not set
    # CONFIG_MCUMGR_GRP_IMG_REJECT_DIRECT_XIP_MISMATCHED_SLOT is not set
    # CONFIG_MCUMGR_GRP_IMG_FRUGAL_LIST is not set
    # CONFIG_MCUMGR_GRP_IMG_VERSION_CMP_USE_BUILD_NUMBER is not set
    # CONFIG_MCUMGR_GRP_IMG_MUTEX is not set
    CONFIG_MCUMGR_GRP_OS_RESET_MS=250
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_ONLY_SUPPORTED_STATS=y
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_USE_THREAD_NAME_FOR_NAME=y
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT_USE_THREAD_IDX_FOR_NAME is not set
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT_USE_THREAD_PRIO_FOR_NAME is not set
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_MAX_NUM_THREADS=50
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_THREAD_NAME_LEN=32
    CONFIG_MCUMGR_GRP_OS_TASKSTAT_SIGNED_PRIORITY=y
    # CONFIG_MCUMGR_GRP_OS_TASKSTAT_STACK_INFO is not set
    CONFIG_MCUMGR_GRP_OS_ECHO=y
    # CONFIG_MCUMGR_GRP_OS_INFO is not set
    # CONFIG_MCUMGR_GRP_OS_BOOTLOADER_INFO is not set
    CONFIG_MCUMGR_GRP_STAT_MAX_NAME_LEN=32
    # end of Command Handlers
    # Transports and Transport Related Configuration Options
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_THREAD_PRIO=3
    CONFIG_MCUMGR_TRANSPORT_REASSEMBLY=y
    CONFIG_MCUMGR_TRANSPORT_NETBUF_COUNT=4
    CONFIG_MCUMGR_TRANSPORT_NETBUF_MIN_USER_DATA_SIZE=8
    CONFIG_MCUMGR_TRANSPORT_NETBUF_USER_DATA_SIZE=8
    # CONFIG_MCUMGR_TRANSPORT_DUMMY is not set
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MIN_INT=6
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_MAX_INT=9
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_LATENCY=0
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_TIMEOUT=42
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RESTORE_TIME=5000
    CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL_RETRY_TIME=1000
    CONFIG_MCUMGR_TRANSPORT_SHELL_MTU=256
    CONFIG_MCUMGR_TRANSPORT_SHELL_RX_BUF_COUNT=2
    # CONFIG_MCUMGR_TRANSPORT_SHELL_INPUT_TIMEOUT is not set
    # end of Transports and Transport Related Configuration Options
    # Networking
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # end of Networking
    # Power Management
    CONFIG_PM_DEVICE_RUNTIME=y
    # Portability
    # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
    CONFIG_XOSHIRO_RANDOM_GENERATOR=y
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # SD
    # end of SD
    CONFIG_SHELL=y
    CONFIG_SHELL_BACKENDS=y
    # CONFIG_SHELL_BACKEND_SERIAL is not set
    # CONFIG_SHELL_BACKEND_RTT is not set
    # CONFIG_SHELL_BACKEND_DUMMY is not set
    # CONFIG_SHELL_MINIMAL is not set
    # CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set
    CONFIG_SHELL_STACK_SIZE=2048
    CONFIG_SHELL_BACKSPACE_MODE_DELETE=y
    CONFIG_SHELL_CMD_BUFF_SIZE=256
    CONFIG_SHELL_PRINTF_BUFF_SIZE=30
    CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80
    CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24
    CONFIG_SHELL_ARGC_MAX=20
    CONFIG_SHELL_TAB=y
    CONFIG_SHELL_TAB_AUTOCOMPLETION=y
    CONFIG_SHELL_ASCII_FILTER=y
    CONFIG_SHELL_WILDCARD=y
    CONFIG_SHELL_ECHO_STATUS=y
    # CONFIG_SHELL_START_OBSCURED is not set
    CONFIG_SHELL_VT100_COMMANDS=y
    CONFIG_SHELL_VT100_COLORS=y
    # CONFIG_SHELL_GETOPT is not set
    CONFIG_SHELL_METAKEYS=y
    CONFIG_SHELL_HELP=y
    CONFIG_SHELL_HELP_OPT_PARSE=y
    CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=y
    CONFIG_SHELL_HISTORY=y
    CONFIG_SHELL_HISTORY_BUFFER=512
    CONFIG_SHELL_STATS=y
    CONFIG_SHELL_CMDS=y
    CONFIG_SHELL_CMDS_RESIZE=y
    # CONFIG_SHELL_CMDS_SELECT is not set
    CONFIG_SHELL_CMD_ROOT=""
    CONFIG_SHELL_AUTOSTART=y
    CONFIG_SHELL_CMDS_RETURN_VALUE=y
    CONFIG_KERNEL_SHELL=y
    CONFIG_KERNEL_SHELL_REBOOT_DELAY=0
    # CONFIG_DEVICE_SHELL is not set
    # CONFIG_DEVMEM_SHELL is not set
    CONFIG_STATS=y
    # CONFIG_STATS_SHELL is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_MAP_SHELL is not set
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    # CONFIG_STREAM_FLASH_ERASE is not set
    # end of Storage
    # Testing
    # end of Testing
    CONFIG_USB_DEVICE_BLUETOOTH_BIG_BUF=y
    # CONFIG_USB_DFU_CLASS is not set
    # Linker Options
    # Linker Sections
    # Compiler Options
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # Build Options
    # Boot Options
    # end of Zephyr
    mcuboot.conf
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
    CONFIG_LOG=n
    CONFIG_CONSOLE=n
    CONFIG_UART_CONSOLE=n
    CONFIG_SERIAL=n
    Understood. Then it should be enabled in both app + mcuboot.
    I'm just using hello_world, with your .config, to replicate the issue; which could be a reason why I'm seeing a bit of a different outcome.
    By enabling QSPI_NOR in both mcuboot and prj.conf, I do see a low current consumption, but only after I power cycle the board. The initial programming process highly likely left the qspi flash in a powered up state.
    Could you see if you see the same after a power-cycle?
    This is a good improvement, but as you mention; still a bit high. Is there anything else running on your board that can cause this leakage in sleep? Like another sensor or similar?
    Håkon
  • Thanks Håkon,
    Tried this and added CONFIG_NORDIC_QSPI_NOR=y  to both conf files, but no noticeable change
    power cycle doesn't help either
    I tried flashing the smp_svr sample with overlay-bt.conf fragment. It draws around 0.6mA in default configuration. Adding QSPI_NOR does not really make a big change, but adding just these two lines increases current draw to 1.9-2 mA, which is honestly quite confusing.
    CONFIG_PM_DEVICE=y
    Disabling serial and logging reduces current draw to 1.5mA
    I tried out smp_svr so that both of us can have a common project to work with...
    no sensors were active, this is the current drawn by the xiao ble alone... This is the normal variant too, not "xiao ble sense" which would've had extra sensors on board
    I do not have a xiao ble device, so my testing has been performed with your configuration on a nRF52840-DK.
    Could we try to take this step-by-step, to see when the current consumption jumps to 1.5 mA?
    Scenario 1: blinky with CONFIG_SERIAL=n, no mcuboot/QSPI
    Scenario 2: blinky with CONFIG_SERIAL=n, no mcuboot, QSPI enabled
    Scenario 3: blinky with CONFIG_SERIAL=n, with mcuboot, QSPI enabled
    Remember to power cycle in between.
    Kind regards,
    Håkon
