SBOM installation fail
Windows 11, Intel i7, python 3.11.3, pip 24.0
I am trying to use sbom following the instructions here (https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/scripts/west_commands/sbom/README.html) using:
pip3 install -r nrf/scripts/requirements-west-ncs-sbom.txt
When I run the pip command (I tried both pip and pip3), the installation fails with the following:
copying build\lib\licensedcode\data\rules\epl-2.0_or_apache-2.0_or_gpl-2.0_with_classpath-exception-2.0_or_gpl-2.0_with_openjdk-exception_1.RULE -> build\bdist.win-amd64\wheel\.\licensedcode\data\rules
error: could not create 'build\bdist.win-amd64\wheel\.\licensedcode\data\rules\epl-2.0_or_apache-2.0_or_gpl-2.0_with_classpath-exception-2.0_or_gpl-2.0_with_openjdk-exception_1.RULE': No such file or directory
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for scancode-toolkit
Failed to build scancode-toolkit
ERROR: Could not build wheels for scancode-toolkit, which is required to install pyproject.toml-based projects
So far:
  • I tried to see what's wrong with those directories or files but I cannot find on my computer where the files are being copied from and to.  I tried searching for the files that did copy but cannot find them.
  • I could not capture the whole thing but the attached file has the beginning and the end.
Collecting jinja2 (from -r v2.5.2/nrf/scripts/requirements-west-ncs-sbom.txt (line 1))
  Using cached Jinja2-3.1.3-py3-none-any.whl.metadata (3.3 kB)
Collecting scancode-toolkit==31.2.6 (from scancode-toolkit[full]==31.2.6->-r v2.5.2/nrf/scripts/requirements-west-ncs-sbom.txt (line 2))
  Using cached scancode-toolkit-31.2.6.tar.gz (15.9 MB)
  Installing build dependencies: started
  Installing build dependencies: finished with status 'done'
  Getting requirements to build wheel: started
  Getting requirements to build wheel: finished with status 'done'
  Preparing metadata (pyproject.toml): started
  Preparing metadata (pyproject.toml): finished with status 'done'
Collecting attrs!=20.1.0,>=18.1 (from scancode-toolkit==31.2.6->scancode-toolkit[full]==31.2.6->-r v2.5.2/nrf/scripts/requirements-west-ncs-sbom.txt (line 2))
  Using cached attrs-23.2.0-py3-none-any.whl.metadata (9.5 kB)
Building wheels for collected packages: scancode-toolkit
  Building wheel for scancode-toolkit (pyproject.toml): started
  Building wheel for scancode-toolkit (pyproject.toml): finished with status 'error'
Any ideas?
