Linker error on building DFU over USB sample with particle argon board
I'm trying to get the DFU over USB sample (zephyr\samples\subsys\usb\dfu) on a particle_argon board up and running and get the following linker error:
undefined reference to `__device_dts_ord_102'
If I disable the KConfig CONFIG_BOOTLOADER_MCUBOOT then the error is gone and the build works.
I've already checked the Troubleshooting Guide (https://docs.zephyrproject.org/latest/build/dts/troubleshooting.html) and the both devicetree_generated.h files (the mcuboot and the application). These are the following entries with 102:
  • build_argon\mcuboot\zephyr\include\generated\devicetree_generated.h
    102 /soc/spi@40023000
  • build_argon\zephyr\include\generated\devicetree_generated.h
    102 /soc/radio@40001000/ieee802154
If I check these peripherals in the device tree (zephyr.dts), both are enabled with status = "okay";
I really don't know where that error comes from, I hope you guys can help me:
The same sample works fine with a nrf52840_dk board.
Thanks and Best Regrads,
Phobios
P.S.: I've added the build output and the zephyr.dts from the application:
Build_Output (was not possible to add it as code)
https://drive.google.com/file/d/1-hA4r95GLm78oiTzMrDskGiw8AcXbx7x/view
build_argon\zephyr\zephyr.dts
/dts-v1/;
	#address-cells = < 0x1 >;
	#size-cells = < 0x1 >;
	model = "Particle Argon";
	compatible = "particle,argon", "particle,feather";
	chosen {
		zephyr,entropy = &cryptocell;
		zephyr,flash-controller = &flash_controller;
		zephyr,console = &uart0;
		zephyr,uart-mcumgr = &uart0;
		zephyr,shell-uart = &uart0;
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
		zephyr,ieee802154 = &ieee802154;
	aliases {
		led0 = &user_led;
		led1 = &status_red;
		led2 = &status_green;
		led3 = &status_blue;
		sw0 = &mode_button;
		sw1 = &reset_button;
		spi-flash0 = &mx25l32;
		watchdog0 = &wdt0;
	soc {
		compatible = "nordic,nrf52840-qiaa", "nordic,nrf52840", "nordic,nrf52", "simple-bus";
		interrupt-parent = < &nvic >;
		ranges;
		nvic: interrupt-controller@e000e100 {
			compatible = "arm,v7m-nvic";
			reg = < 0xe000e100 0xc00 >;
			interrupt-controller;
			#interrupt-cells = < 0x2 >;
			arm,num-irq-priority-bits = < 0x3 >;
			phandle = < 0x1 >;
		systick: timer@e000e010 {
			compatible = "arm,armv7m-systick";
			reg = < 0xe000e010 0x10 >;
			status = "disabled";
		ficr: ficr@10000000 {
			compatible = "nordic,nrf-ficr";
			reg = < 0x10000000 0x1000 >;
			status = "okay";
		uicr: uicr@10001000 {
			compatible = "nordic,nrf-uicr";
			reg = < 0x10001000 0x1000 >;
			status = "okay";
			gpio-as-nreset;
		sram0: memory@20000000 {
			compatible = "mmio-sram";
			reg = < 0x20000000 0x40000 >;
		clock: clock@40000000 {
			compatible = "nordic,nrf-clock";
			reg = < 0x40000000 0x1000 >;
			interrupts = < 0x0 0x1 >;
			status = "okay";
		power: power@40000000 {
			compatible = "nordic,nrf-power";
			status = "okay";
			gpregret1: gpregret1@4000051c {
				compatible = "nordic,nrf-gpregret";
				reg = < 0x4000051c 0x1 >;
				status = "okay";
			gpregret2: gpregret2@40000520 {
				reg = < 0x40000520 0x1 >;
				status = "okay";
		radio: radio@40001000 {
			compatible = "nordic,nrf-radio";
			reg = < 0x40001000 0x1000 >;
			interrupts = < 0x1 0x1 >;
			status = "okay";
			ieee802154-supported;
			ble-2mbps-supported;
			ble-coded-phy-supported;
			tx-high-power-supported;
			ieee802154: ieee802154 {
				compatible = "nordic,nrf-ieee802154";
				status = "okay";
		uart0: feather_serial: uart@40002000 {
			reg = < 0x40002000 0x1000 >;
			interrupts = < 0x2 0x1 >;
			status = "okay";
			current-speed = < 0x1c200 >;
			pinctrl-0 = < &uart0_default >;
			pinctrl-1 = < &uart0_sleep >;
		i2c0: arduino_i2c: feather_i2c: i2c@40003000 {
			compatible = "nordic,nrf-twi";
			#size-cells = < 0x0 >;
			reg = < 0x40003000 0x1000 >;
			clock-frequency = < 0x61a80 >;
			interrupts = < 0x3 0x1 >;
			status = "okay";
			pinctrl-0 = < &i2c0_default >;
			pinctrl-1 = < &i2c0_sleep >;
		spi0: spi@40003000 {
			max-frequency = < 0x7a1200 >;
			easydma-maxcnt-bits = < 0x10 >;
		i2c1: i2c@40004000 {
			reg = < 0x40004000 0x1000 >;
			clock-frequency = < 0x186a0 >;
			interrupts = < 0x4 0x1 >;
		spi1: spi@40004000 {
		nfct: nfct@40005000 {
			compatible = "nordic,nrf-nfct";
			reg = < 0x40005000 0x1000 >;
			interrupts = < 0x5 0x1 >;
			status = "okay";
		gpiote: gpiote@40006000 {
			compatible = "nordic,nrf-gpiote";
			reg = < 0x40006000 0x1000 >;
			interrupts = < 0x6 0x5 >;
			status = "okay";
		adc: feather_adc: adc@40007000 {
			compatible = "nordic,nrf-saadc";
			reg = < 0x40007000 0x1000 >;
			interrupts = < 0x7 0x1 >;
			status = "okay";
			#io-channel-cells = < 0x1 >;
			phandle = < 0xd >;
		timer0: timer@40008000 {
			compatible = "nordic,nrf-timer";
			reg = < 0x40008000 0x1000 >;
			cc-num = < 0x4 >;
			max-bit-width = < 0x20 >;
			interrupts = < 0x8 0x1 >;
			prescaler = < 0x0 >;
		timer1: timer@40009000 {
			reg = < 0x40009000 0x1000 >;
			cc-num = < 0x4 >;
			interrupts = < 0x9 0x1 >;
			phandle = < 0xb >;
		timer2: timer@4000a000 {
			reg = < 0x4000a000 0x1000 >;
			cc-num = < 0x4 >;
			interrupts = < 0xa 0x1 >;
		rtc0: rtc@4000b000 {
			compatible = "nordic,nrf-rtc";
			reg = < 0x4000b000 0x1000 >;
			cc-num = < 0x3 >;
			interrupts = < 0xb 0x1 >;
			clock-frequency = < 0x8000 >;
			prescaler = < 0x1 >;
		temp: temp@4000c000 {
			compatible = "nordic,nrf-temp";
			reg = < 0x4000c000 0x1000 >;
			interrupts = < 0xc 0x1 >;
			status = "okay";
		rng: random@4000d000 {
			compatible = "nordic,nrf-rng";
			reg = < 0x4000d000 0x1000 >;
			interrupts = < 0xd 0x1 >;
			status = "okay";
		ecb: ecb@4000e000 {
			compatible = "nordic,nrf-ecb";
			reg = < 0x4000e000 0x1000 >;
			interrupts = < 0xe 0x1 >;
			status = "okay";
		ccm: ccm@4000f000 {
			compatible = "nordic,nrf-ccm";
			reg = < 0x4000f000 0x1000 >;
			interrupts = < 0xf 0x1 >;
			length-field-length-8-bits;
			status = "okay";
		wdt: wdt0: watchdog@40010000 {
			compatible = "nordic,nrf-wdt";
			reg = < 0x40010000 0x1000 >;
			interrupts = < 0x10 0x1 >;
			status = "okay";
		rtc1: rtc@40011000 {
			reg = < 0x40011000 0x1000 >;
			cc-num = < 0x4 >;
			interrupts = < 0x11 0x1 >;
		qdec: qdec0: qdec@40012000 {
			compatible = "nordic,nrf-qdec";
			reg = < 0x40012000 0x1000 >;
			interrupts = < 0x12 0x1 >;
		comp: comparator@40013000 {
			compatible = "nordic,nrf-comp";
			reg = < 0x40013000 0x1000 >;
			interrupts = < 0x13 0x1 >;
		egu0: swi0: egu@40014000 {
			compatible = "nordic,nrf-egu", "nordic,nrf-swi";
			reg = < 0x40014000 0x1000 >;
			interrupts = < 0x14 0x1 >;
			status = "okay";
		egu1: swi1: egu@40015000 {
			reg = < 0x40015000 0x1000 >;
			interrupts = < 0x15 0x1 >;
			status = "okay";
		egu2: swi2: egu@40016000 {
			reg = < 0x40016000 0x1000 >;
			interrupts = < 0x16 0x1 >;
			status = "okay";
		egu3: swi3: egu@40017000 {
			reg = < 0x40017000 0x1000 >;
			interrupts = < 0x17 0x1 >;
			status = "okay";
		egu4: swi4: egu@40018000 {
			reg = < 0x40018000 0x1000 >;
			interrupts = < 0x18 0x1 >;
			status = "okay";
		egu5: swi5: egu@40019000 {
			reg = < 0x40019000 0x1000 >;
			interrupts = < 0x19 0x1 >;
			status = "okay";
		timer3: timer@4001a000 {
			reg = < 0x4001a000 0x1000 >;
			cc-num = < 0x6 >;
			interrupts = < 0x1a 0x1 >;
		timer4: timer@4001b000 {
			reg = < 0x4001b000 0x1000 >;
			cc-num = < 0x6 >;
			interrupts = < 0x1b 0x1 >;
		pwm0: pwm@4001c000 {
			compatible = "nordic,nrf-pwm";
			reg = < 0x4001c000 0x1000 >;
			interrupts = < 0x1c 0x1 >;
			#pwm-cells = < 0x3 >;
		pdm0: pdm@4001d000 {
			compatible = "nordic,nrf-pdm";
			reg = < 0x4001d000 0x1000 >;
			interrupts = < 0x1d 0x1 >;
		acl: acl@4001e000 {
			compatible = "nordic,nrf-acl";
			reg = < 0x4001e000 0x1000 >;
			status = "okay";
		flash_controller: flash-controller@4001e000 {
			compatible = "nordic,nrf52-flash-controller";
			partial-erase;
			flash0: flash@0 {
				compatible = "soc-nv-flash";
				erase-block-size = < 0x1000 >;
				write-block-size = < 0x4 >;
				reg = < 0x0 0x100000 >;
				partitions {
					boot_partition: partition@0 {
						label = "mcuboot";
						reg = < 0x0 0xc000 >;
					slot0_partition: partition@c000 {
						label = "image-0";
						reg = < 0xc000 0x67000 >;
					slot1_partition: partition@73000 {
						label = "image-1";
						reg = < 0x73000 0x67000 >;
					scratch_partition: partition@da000 {
						label = "image-scratch";
						reg = < 0xda000 0x1e000 >;
					storage_partition: partition@f8000 {
						label = "storage";
						reg = < 0xf8000 0x8000 >;
		ppi: ppi@4001f000 {
			compatible = "nordic,nrf-ppi";
			reg = < 0x4001f000 0x1000 >;
			status = "okay";
		mwu: mwu@40020000 {
			compatible = "nordic,nrf-mwu";
			reg = < 0x40020000 0x1000 >;
			status = "okay";
		pwm1: pwm@40021000 {
			reg = < 0x40021000 0x1000 >;
			interrupts = < 0x21 0x1 >;
		pwm2: pwm@40022000 {
			reg = < 0x40022000 0x1000 >;
			interrupts = < 0x22 0x1 >;
		spi2: spi@40023000 {
			compatible = "nordic,nrf-spi";
			reg = < 0x40023000 0x1000 >;
			interrupts = < 0x23 0x1 >;
			status = "okay";
			cs-gpios = < &gpio0 0x11 0x1 >;
			pinctrl-0 = < &spi2_default >;
			pinctrl-1 = < &spi2_sleep >;
			mx25l32: mx25l3233f@0 {
				compatible = "jedec,spi-nor";
				reg = < 0x0 >;
				spi-max-frequency = < 0x4c4b400 >;
				wp-gpios = < &gpio0 0x16 0x1 >;
				hold-gpios = < &gpio0 0x17 0x1 >;
				size = < 0x2000000 >;
				has-dpd;
				t-enter-dpd = < 0x2710 >;
				t-exit-dpd = < 0x186a0 >;
				jedec-id = [ C2 20 16 ];
				sfdp-bfp = [ E5 20 F1 FF FF FF FF 01 44 EB 08 6B 08 3B 04 BB EE FF FF FF FF FF 00 FF FF FF 00 FF 0C 20 0F 52 10 D8 00 FF ];
		rtc2: rtc@40024000 {
			reg = < 0x40024000 0x1000 >;
			cc-num = < 0x4 >;
			interrupts = < 0x24 0x1 >;
		i2s0: i2s@40025000 {
			compatible = "nordic,nrf-i2s";
			reg = < 0x40025000 0x1000 >;
			interrupts = < 0x25 0x1 >;
		usbd: zephyr_udc0: usbd@40027000 {
			compatible = "nordic,nrf-usbd";
			reg = < 0x40027000 0x1000 >;
			interrupts = < 0x27 0x1 >;
			num-bidir-endpoints = < 0x1 >;
			num-in-endpoints = < 0x7 >;
			num-out-endpoints = < 0x7 >;
			num-isoin-endpoints = < 0x1 >;
			num-isoout-endpoints = < 0x1 >;
			status = "okay";
		uart1: uart@40028000 {
			reg = < 0x40028000 0x1000 >;
			interrupts = < 0x28 0x1 >;
			status = "okay";
			current-speed = < 0xe1000 >;
			pinctrl-0 = < &uart1_default >;
			pinctrl-1 = < &uart1_sleep >;
		qspi: qspi@40029000 {
			compatible = "nordic,nrf-qspi";
			reg = < 0x40029000 0x1000 >, < 0x12000000 0x8000000 >;
			reg-names = "qspi", "qspi_mm";
			interrupts = < 0x29 0x1 >;
		pwm3: pwm@4002d000 {
			reg = < 0x4002d000 0x1000 >;
			interrupts = < 0x2d 0x1 >;
		spi3: spi@4002f000 {
			reg = < 0x4002f000 0x1000 >;
			interrupts = < 0x2f 0x1 >;
			max-frequency = < 0x1e84800 >;
			rx-delay-supported;
			rx-delay = < 0x2 >;
		gpio0: gpio@50000000 {
			compatible = "nordic,nrf-gpio";
			gpio-controller;
			reg = < 0x50000000 0x200 0x50000500 0x300 >;
			#gpio-cells = < 0x2 >;
			status = "okay";
			port = < 0x0 >;
			phandle = < 0x6 >;
		gpio1: gpio@50000300 {
			gpio-controller;
			reg = < 0x50000300 0x200 0x50000800 0x300 >;
			ngpios = < 0x10 >;
			status = "okay";
			port = < 0x1 >;
			phandle = < 0xc >;
		cryptocell: crypto@5002a000 {
			compatible = "nordic,nrf-cc310";
			reg = < 0x5002a000 0x1000 >;
			status = "okay";
			cryptocell310: crypto@5002b000 {
				compatible = "arm,cryptocell-310";
				reg = < 0x5002b000 0x1000 >;
				interrupts = < 0x2a 0x1 >;
	pinctrl: pin-controller {
		compatible = "nordic,nrf-pinctrl";
		i2c0_default: i2c0_default {
			phandle = < 0x4 >;
			group1 {
				psels = < 0xc001a >, < 0xb001b >;
		i2c0_sleep: i2c0_sleep {
			phandle = < 0x5 >;
			group1 {
				low-power-enable;
		spi2_default: spi2_default {
			phandle = < 0x7 >;
			group1 {
				psels = < 0x40013 >, < 0x50014 >, < 0x60015 >;
		spi2_sleep: spi2_sleep {
			phandle = < 0x8 >;
			group1 {
				low-power-enable;
		uart0_default: uart0_default {
			phandle = < 0x2 >;
			group1 {
				psels = < 0x6 >, < 0x10008 >;
		uart0_sleep: uart0_sleep {
			phandle = < 0x3 >;
			group1 {
				low-power-enable;
		uart1_default: uart1_default {
			phandle = < 0x9 >;
			group1 {
				psels = < 0x25 >, < 0x10024 >, < 0x20027 >, < 0x30026 >;
		uart1_sleep: uart1_sleep {
			phandle = < 0xa >;
			group1 {
				low-power-enable;
	rng_hci: entropy_bt_hci {
		compatible = "zephyr,bt-hci-entropy";
		status = "okay";
	sw_pwm: sw-pwm {
		compatible = "nordic,nrf-sw-pwm";
		generator = < &timer1 >;
		clock-prescaler = < 0x0 >;
	cpus {
		cpu@0 {
			device_type = "cpu";
			compatible = "arm,cortex-m4f";
			reg = < 0x0 >;
			itm: itm@e0000000 {
				compatible = "arm,armv7m-itm";
				reg = < 0xe0000000 0x1000 >;
				swo-ref-frequency = < 0x1e84800 >;
	leds {
		compatible = "gpio-leds";
		user_led: led_0 {
			gpios = < &gpio1 0xc 0x0 >;
			label = "User LED";
		status_red: led_1 {
			gpios = < &gpio0 0xd 0x1 >;
			label = "Red LED";
		status_green: led_2 {
			gpios = < &gpio0 0xe 0x1 >;
			label = "Green LED";
		status_blue: led_3 {
			gpios = < &gpio0 0xf 0x1 >;
			label = "Blue LED";
	gpio_keys {
		compatible = "gpio-keys";
		mode_button: button_0 {
			gpios = < &gpio0 0xb 0x11 >;
			label = "Mode Button";
			zephyr,code = < 0x13c >;
		reset_button: button_1 {
			gpios = < &gpio0 0x12 0x11 >;
			label = "Reset Button";
			zephyr,code = < 0xb >;
	mesh_header: connector {
		compatible = "particle-gen3-header";
		gpio-map-mask = < 0xffffffff 0xffffffc0 >;
		gpio-map-pass-thru = < 0x0 0x3f >;
		gpio-map = < 0x0 0x0 &gpio0 0x1a 0x0 >, < 0x1 0x0 &gpio0 0x1b 0x0 >, < 0x2 0x0 &gpio1 0x1 0x0 >, < 0x3 0x0 &gpio1 0x2 0x0 >, < 0x4 0x0 &gpio1 0x8 0x0 >, < 0x5 0x0 &gpio1 0xa 0x0 >, < 0x6 0x0 &gpio1 0xb 0x0 >, < 0x7 0x0 &gpio1 0xc 0x0 >, < 0x8 0x0 &gpio1 0x3 0x0 >, < 0x9 0x0 &gpio0 0x6 0x0 >, < 0xa 0x0 &gpio0 0x8 0x0 >, < 0xb 0x0 &gpio1 0xe 0x0 >, < 0xc 0x0 &gpio1 0xd 0x0 >, < 0xd 0x0 &gpio1 0xf 0x0 >, < 0xe 0x0 &gpio0 0x1f 0x0 >, < 0xf 0x0 &gpio0 0x1e 0x0 >, < 0x10 0x0 &gpio0 0x1d 0x0 >, < 0x11 0x0 &gpio0 0x1c 0x0 >, < 0x12 0x0 &gpio0 0x4 0x0 >, < 0x13 0x0 &gpio0 0x3 0x0 >, < 0x14 0x0 &gpio0 0xb 0x0 >, < 0x15 0x0 &gpio0 0x12 0x0 >;
	feather_header: feather_connector {
		compatible = "adafruit-feather-header";
		gpio-map = < 0xc 0x0 &gpio0 0x1a 0x0 >, < 0xd 0x0 &gpio0 0x1b 0x0 >, < 0xe 0x0 &gpio1 0x1 0x0 >, < 0xf 0x0 &gpio1 0x2 0x0 >, < 0x10 0x0 &gpio1 0x8 0x0 >, < 0x11 0x0 &gpio1 0xa 0x0 >, < 0x12 0x0 &gpio1 0xb 0x0 >, < 0x13 0x0 &gpio1 0xc 0x0 >, < 0x14 0x0 &gpio1 0x3 0x0 >, < 0xa 0x0 &gpio0 0x6 0x0 >, < 0x9 0x0 &gpio0 0x8 0x0 >, < 0x8 0x0 &gpio1 0xe 0x0 >, < 0x7 0x0 &gpio1 0xd 0x0 >, < 0x6 0x0 &gpio1 0xf 0x0 >, < 0x5 0x0 &gpio0 0x1f 0x0 >, < 0x4 0x0 &gpio0 0x1e 0x0 >, < 0x3 0x0 &gpio0 0x1d 0x0 >, < 0x2 0x0 &gpio0 0x1c 0x0 >, < 0x1 0x0 &gpio0 0x4 0x0 >, < 0x0 0x0 &gpio0 0x3 0x0 >;
	sky13351: sky13351 {
		compatible = "skyworks,sky13351";
		vctl1-gpios = < &gpio0 0x19 0x1 >;
		vctl2-gpios = < &gpio0 0x2 0x1 >;
	vbatt {
		compatible = "voltage-divider";
		io-channels = < &adc 0x3 >;
		output-ohms = < 0x200b20 >;
		full-ohms = < 0x2c5790 >;
