MCUboot should only timeout after hardware reset
Hi there,
I've made MCUboot work, but it always timeouts before loading the application firmware. I only want it to timeout after resetting the SoC via its RESET pin.
I added CONFIG_BOOTLOADER_MCUBOOT=y to my prj.conf, and my mcuboot.conf contains the following:
CONFIG_PINCTRL=y
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
CONFIG_LOG=y
CONFIG_SIZE_OPTIMIZATIONS=y
CONFIG_SERIAL=y
CONFIG_UART_LINE_CTRL=y
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_CDC_ACM=y
CONFIG_BOOT_SERIAL_PIN_RESET=y
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU=y
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=3000
CONFIG_BOOT_SERIAL_NO_APPLICATION=y
CONFIG_LOG_BACKEND_UART=y
CONFIG_LOG_BACKEND_RTT=n
My second issue is that I have to add the `-Dmcuboot_OVERLAY_CONFIG=/home/laci/projects/firmware-uhk/uhk/device/mcuboot.conf` west argument every time I build because the VS Code forgets it:
How can I persist this setting? The "Save Configuration as Preset" option doesn't make a difference.
Thanks in advance!
- Laci
