Handle the BLE Event in nRF connect SDK?
hi,
I am using nRF5340 SoC in my application. I am using BLE in that application. i am beginner to nrf connect sdk so, I have few question regarding BLE implementation.
1). In nrf sdk17.1.0,  we can  handle the ble event and advertisement event using registering callback handler function. But in nrf connect sdk 2.5.2 sdk i diden't found to handle the ble data.
ex.    BLE Event
    ret_code_t err_code = NRF_SUCCESS;
            NRF_LOG_INFO("Disconnected.");
            _connFlag = false;
            SF_SystemOff();
            //if(!SF_GetChargingStatus() && !GW_GetChargingStatus())
            // // LI_LedStateOn(LI_IDLE);
            BCM_NotifyTimerDisable();
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            _advFlag=false;
            SF_SystemOn();
            _connFlag = true;
              LI_LedStateOn(LI_BLE_CONN);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
ex: For advertisement Event
    ret_code_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            _advFlag = true;
        case BLE_ADV_EVT_IDLE:
            NRF_LOG_INFO("Device advertisment off");
    ble_advertising_init_t init;
i am use ble handle in NRF SDK like above.
So in nrf connect sdk is there any way to handle the advertising and ble event? or how can i handle the advertising event and ble event?
please refer me any particular example regarding BLE Event.
Thank you.
    Thenk you for detail replay.
    Can you please suggest extended advertising example?
    How are you restarting the advertisement after a disconnection? Can you show me the code?
    I am not start the advertisement after disconnect,  its automatically started advertisement . For your rferance  i was set advertisement data as below.
    static const struct bt_data ad[]={
            BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR | BT_LE_AD_LIMITED)),
            BT_DATA_BYTES(BT_DATA_UUID16_ALL,
    		        BT_UUID_16_ENCODE(BT_UUID_BAS_VAL),
    				BT_UUID_16_ENCODE(BT_UUID_DIS_VAL)),
    		//BT_DATA(BT_DATA_MANUFACTURER_DATA, DEVICE_MANUF_NAME, DEVICE_MANUF_NAME_LEN)
    static const struct bt_data sd[]={
        BT_DATA_BYTES(BT_DATA_UUID128_ALL, CUSTOM_DATA_SERVICE_UUID_VAL),
    And started advertiseing as below
    void bt_ready(void)
    	int err;
    	if (IS_ENABLED(CONFIG_SETTINGS)) {
    		settings_load();
    	err = bt_le_adv_start(BT_LE_ADV_CONN_NAME, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
    	if (err) {
    		printk("Advertising failed to start (err %d)\n", err);
    		return;
    	// adv_value=true;
    	printk("Advertising successfully started\n");
    I only do this for advertisement. please let me know if i am wrong.
    Thank you in advance.
    The periodic advertising sample use extended advertising.
    Can you share your whole project?
    regards
    Jared
  • hi jared,
    Here i share the project.
    Thank you.
    In
    	if (err) {
    		return;
    Redefine BT_LE_ADV_CONN_NAME
    with:
    #define BT_LE_ADV_CONN_NAME BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE |BT_LE_ADV_OPT_ONE_TIME,  \
    					    BT_LE_ADV_OPT_USE_NAME, \
    					    BT_GAP_ADV_FAST_INT_MIN_2, \
    					    BT_GAP_ADV_FAST_INT_MAX_2, NULL)
    regards
    Jared
  • hi,
    Thank you for quick response.
    I modify the code as you suggest but in this case advertisement will stop after connection.
    But understand my requirement after connection advertise will not going to stop. advertisement will stop after 1 minute from disconnection happen.
    so my requirement is advertisement will stop after 1 minute from disconnection.
    Thanks and regard
    Gautam.
