uart_callback_set returns -ENOSYS
I have two projects using different boards.
First one (uses attached board = btLTE_nrf52840) works fine. The application are similar in that both make use of the UARTE driver.
The second one (uses attached board = w5500_nrf52840) uses the W5500 Ethernet driver. This application works fine except that in the case of the second board, uart_callback_set() returns error -ENOSYS. I have seen other cases reported for the same issue, but I have not been able to determine why this is the case.
I must be something to do with the settings or the board.
I would appreciate any assistance.
I include the im7851.code.zipplementation for both boards, the config settings for working and none working applicayion as well as the
common uart code.
Parents Reply
    The problem is likely that the uart0 instance is used by the NET_SHELL that you have enabled in your prj.conf file. In /build/zephyr/zephyr.dts, we can see:
    	chosen {
    		zephyr,shell-uart = &uart0;
    You can either disable NET_SHELL in your prj.conf:
    CONFIG_NET_SHELL=n
    Or assign it to another uart instance in your board overlay:
    	chosen {
    		zephyr,shell-uart = &uart1;
    Both these alternatives resolved the error in your test application.
    Jørgen
