send pwm to motor via button press
I am trying to have the dk (i have the 10036 preview) send pwm signals to a motor controller so that i can direct its speed. I have based a lot of the code below of thisutorial as well as some questions here in the dev zone but I can't seem to figure out why there's no signal going out.
I can get the motors to start, stop, and change direction but that's just by setting the right output pins which only happens if i comment out all the pwm code (init, start(), stop()), the motor spins at the factory default setting which isn't very high. Below is all the code i put in that pertains to pwm. Please point me in the right direction, thank you
APP_PWM_INSTANCE(PWM1,1);
// A flag indicating PWM status.
static volatile bool pwmReady = false;
// PWM callback function
void pwm_ready_callback(uint32_t pwm_id)
    pwmReady = true;
// Motor #1
int PWMA = 1; //Speed control
int Motor1_1 = 12; //Direction
int Motor1_2 = 13; //Direction
void init_motors(void)
  // set up GPIOs
  nrf_gpio_cfg_output(Motor1_1);
  nrf_gpio_cfg_output(Motor1_2);
static void PWMinit(void)
  app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(9000L, 15);
  pwm1_cfg.pin_polarity[0] = APP_PWM_POLARITY_ACTIVE_HIGH;
  app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
  app_pwm_enable(&PWM1);
void pwm_stop(void)
		//Stop PWM
		app_pwm_disable(&PWM1);
		nrf_drv_gpiote_out_task_disable(PWMA);
void pwm_start(void)
    nrf_drv_gpiote_out_task_enable(PWMA);
    while (app_pwm_channel_duty_set(&PWM1, 0, 95) == NRF_ERROR_BUSY);
// Function for handling the data from the Nordic UART Service.
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data,
                             uint16_t length)
  if (strstr((char*)(p_data), RECORD)) {
  else if (strstr((char*)(p_data), SHUFFLE)) {
  else if (strstr((char*)(p_data), STOP)) {
    pwm_stop();
		nrf_drv_gpiote_out_task_disable(Motor1_1);
		nrf_gpio_pin_clear(Motor1_1);
		nrf_drv_gpiote_out_task_disable(Motor1_2);
		nrf_gpio_pin_clear(Motor1_2);
  else if (strstr((char*)(p_data), PLAY)) {
  else if (strstr((char*)(p_data), FORWARD)) {
    pwm_start();
		nrf_gpio_pin_set(Motor1_2);
  else if (strstr((char*)(p_data), REWIND)) {
    pwm_start();
		nrf_gpio_pin_set(Motor1_1);
Then in main loop
#define APP_TIMER_PRESCALER  0    /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS 6    /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE 4  /**< Size of timer operation queues. */
// Application main function.
    uint32_t err_code;
    // set up timers
    APP_TIMER_INIT(APP_TIMER_PRESCALER,
                   APP_TIMER_OP_QUEUE_SIZE, false);
    // initlialize BLE
    ble_stack_init();
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
		PWMinit();
    // start BLE advertizing
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    // init GPIOTE
    // init PPI
    // intialize UART
    uart_init();
    // intitialize motors
    init_motors();
    1. When you use PWM library, I think it configures the gpio pins to output and you do not have to do it explicitly unless you need different drive currents.
    2. I see in your init_motors function that you need to control two motors but your PWM_Init function is only inlitializing pwm library with only one pin and one channel. You need to use APP_PWM_DEFAULT_CONFIG_2CH for controlling two pwm outputs.
    3. It is not acceptable to ignore return codes of functions like app_pwm_init. How would you know if this function has failed for some reason? please handle or atleast check if functions are returning with errors.
  • Oh ok, i was following the tutorial and thats what it did in terms of setting up the motors. Yeah changing direction on command is pretty important so i want to set that up and that works fine with what i have, Just no PWM is going to the motor controller that controls the motors.
    oh i am very new to all this and i had no idea thats what APP_ERROR_CHECK(err_code) did.. I'll be sure not to leave it out any longer.
    But i took out init_motors(), added the APP_ERROR_CHECK, and had the same enable pwm called when the button of the uart_function is pushed and still no activity from the motor. Is there something else I am missing?
  • Did you all APP_ERROR_CHECK to all functions that are not "void"?
  • I did, but not initially. I do believe that i am successfully sending pwm signals to the motor controller (l293d) from the dk. I think the problem was that in this line app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(9000L, 15); i was telling it to go to the wrong pin on the motor controller. I changed the 15 to the pin go to one of the motor controller's input pins and it seems that go the signal across. The problem I am having now is that the motor only makes a humming sound when it is told to turn but I believe that is a problem with the amount of power I am using. I have a 1.5-3v motor and i am using the dk 5v pin to power both the motor controller logic and the motor, so i think the fix here would be to get additional power supply for the motor...right?
  • sounds like it is power range problem, maybe the motor needs power amplifier !!
