Fault escalation ARCH_EXCEPT with reason 3
i use a bluetooth sample code
it works on DK board correctly but on my custom PCB it is reseting board after this line:
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),sd, ARRAY_SIZE(sd));
the err value is zero and the RTT log is here:
00> E: r0/a1:  0x00000003  r1/a2:  0x0002f6c8  r2/a3:  0x20006748
00> E: r3/a4:  0x*** Booting nRF Connect SDK v2.5.0 ***
00> Starting Bluetooth Peripheral LBS example
00> I: 8 Sectors of 4096 bytes
00> I: alloc wra: 0, fd0
00> I: data wra: 0, 1c
00> I: SoftDevice Controller build revision:
00> I: c5 93 ba a9 14 4d 8d 05 |.....M..
00> I: 30 4e 9b 92 d7 71 1e e8 |0N...q..
00> I: aa 02 50 3c             |..P<
00> I: HW Platform: Nordic Semiconductor (0x0002)
00> I: HW Variant: nRF52x (0x0002)
00> I: Firmware: Standard Bluetooth controller (0x00) Version 197.47763 Build 2370639017
00> I: No ID address. App must call settings_load()
00> Bluetooth initialized
00> I: Identity: DF:A5:7E:BD:0C:5D (random)
00> I: HCI: version 5.4 (0x0d) revision 0x1102, manufacturer 0x0059
00> I: LMP: version 5.4 (0x0d) subver 0x1102
00> Reset reason is 4
00> err  is 0
00> ************************E: MPSL ASSERT: 112, 2185
00> E: ***** HARD FAULT *****
00> E:   Fault escalation (see below)
00> E: ARCH_EXCEP*** Booting nRF Connect SDK v2.5.0 ***
my full code is here:
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/kernel.h>
#include <soc.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <zephyr/settings/settings.h>
#include <dk_buttons_and_leds.h>
#include <helpers/nrfx_reset_reason.h>
#define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED          DK_LED1
#define CON_STATUS_LED          DK_LED2
#define RUN_LED_BLINK_INTERVAL  1000
#define USER_LED                DK_LED3
#define USER_BUTTON             DK_BTN1_MSK
static bool app_button_state;
uint32_t reason;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	printk("Connected\n");
	dk_set_led_on(CON_STATUS_LED);
	printk("Disconnected (reason %u)\n", reason);
	dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static struct bt_conn_auth_info_cb conn_auth_info_callbacks;
static void app_led_cb(bool led_state)
	dk_set_led(USER_LED, led_state);
static bool app_button_cb(void)
	return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
	.led_cb    = app_led_cb,
	.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
	if (has_changed & USER_BUTTON) {
		uint32_t user_button_state = button_state & USER_BUTTON;
		bt_lbs_send_button_state(user_button_state);
		app_button_state = user_button_state ? true : false;
static int init_button(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printk("Cannot init buttons (err: %d)\n", err);
	return err;
	int blink_status = 0;
	int err;
	printk("Starting Bluetooth Peripheral LBS example\n");
	err = dk_leds_init();
	if (err) {
		printk("LEDs init failed (err %d)\n", err);
		return 0;
	err = init_button();
	if (err) {
		printk("Button init failed (err %d)\n", err);
		return 0;
	if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
		err = bt_conn_auth_cb_register(&conn_auth_callbacks);
		if (err) {
			printk("Failed to register authorization callbacks.\n");
			return 0;
		err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
		if (err) {
			printk("Failed to register authorization info callbacks.\n");
			return 0;
	mpsl_clock_hfclk_latency_set(MPSL_CLOCK_HF_LATENCY_BEST);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return 0;
	printk("Bluetooth initialized\n");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_lbs_init(&lbs_callbacs);
	if (err) {
		printk("Failed to init LBS (err:%d)\n", err);
		return 0;
	reason = nrfx_reset_reason_get();
	printk("Reset reason is %d\n",reason);
	for(int i=0; i<5; i++){
		dk_set_led(DK_LED1, (++blink_status) % 2);
		k_sleep(K_MSEC(500));
	printk("err  is %d\n",err);
	printk("************************");
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return 0;
		dk_set_led(DK_LED2, (++blink_status) % 2);
	printk("Advertising successfully started\n");
	for (;;) {
		dk_set_led(DK_LED3, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
what is the problem?
