I use the nrf connect sdk together with vscode.
My application is a workspace application with the following structure:
├── application
│ ├── build
│ ├── CMakeLists.txt
│ ├── prj.conf
│ ├── README.rst
│ ├── sample.yaml
│ ├── src
│ └── west.yml
├── boards
│ └── arm
└── external
├── bootloader
├── modules
├── nrf
├── nrfxlib
├── test
├── tools
└── zephyr
I have a working build configuration with my custom board. So the zephyr build systems seems to recognize everything correctly.
Unfortunately if I open my boards .dts file, vscode does no find the included nordic/nrf52840_qiaa.dtsi
file. furthermore the visual devicetree editor only shows the nodes defined in the boards .dts file but nothing from the included file from nordic.
So to my understanding, the extension does not (at least in my case) look for devicetree files in $ZEPHYR_BASE/dts/arm
. If I open a board .dts file from withing $ZEPHYR_BASE
, everything seems to work fine though.
"platform": {
"os": "linux",
"osVersion": "#14-Ubuntu SMP PREEMPT_DYNAMIC Tue Jan 16 08:57:02 UTC 2024",
"osKernel": "6.5.0-1013-oem",
"vscode": "1.86.1",
"electron": "27.2.3",
"node": "v18.17.1"
"system": {
"date": "2024-02-14T10:47:14.300Z",
"vscodeRoot": "/usr/share/code/resources/app",
"nrfConnectForDesktopInstalled": "unknown",
"vscodeUptime": "02:36:32",
"osUptime": "265:36:10",
"cpu": "11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz"
"workspace": {
"name": "nrf-test-project",
"workspaceFile": null,
"folders": [
"/home/bearsh/projects/nrf-test-project"
"sdks": [
"version": "v2.5.2",
"path": "/home/bearsh/ncs/v2.5.2"
"path": "/home/bearsh/projects/nrf-test-project"
"activeBuild": "/home/bearsh/projects/nrf-test-project/application/build",
"apps": [
"workspace": "/home/bearsh/projects/nrf-test-project",
"uri": "/home/bearsh/projects/nrf-test-project/application",
"buildConfigurations": [
"id": "/home/bearsh/projects/nrf-test-project/application/build",
"name": "build",
"boardId": "nina-b3_msr-a11",
"type": "Zephyr",
"isChild": false,
"isStale": false,
"taskBindings": {
"build": [],
"pristineBuild": [],
"flash": [],
"eraseAndFlash": []
"topdir": "/home/bearsh/projects/nrf-test-project",
"workspaceState": "workspace-ready",
"toolchains": [
"version": "2.5.2",
"path": "/home/bearsh/ncs/toolchains/7795df4459"
"connectedDevices": [
"serialNumber": "000504500059"
"deviceProvider": "nrfutil",
"tools": {
"/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.1",
"/opt/SEGGER/JLink/JLinkExe": "7.92k",
"/usr/local/bin/nrfjprog": "10.24.0",
"/home/bearsh/.local/bin/nrfutil": null,
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/cmake": "3.20.5",
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/west": "1.1.0",
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/python3": "3.8.2",
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/ninja": "1.9.0",
"/home/bearsh/ncs/toolchains/7795df4459/usr/bin/gperf": "3.1",
"/home/bearsh/ncs/toolchains/7795df4459/usr/bin/dtc": "1.4.7",
"/home/bearsh/ncs/toolchains/7795df4459/opt/bin/gn": "1871",
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/git": "2.37.3",
"gdbPath": "/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
"nrfutil": {
"nrfutil-device": {
"version": "2.0.0",
"binPath": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.11.301-linux-x64/platform/nrfutil/bin/nrfutil-device"
"nrfutil-toolchain-manager": {
"version": "0.14.1",
"binPath": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.11.301-linux-x64/platform/nrfutil/bin/nrfutil-toolchain-manager"
"environment": {
"westEnv": {
"ELECTRON_RUN_AS_NODE": "1",
"GIT_EXEC_PATH": "/home/bearsh/ncs/toolchains/7795df4459/usr/local/libexec/git-core",
"HOME": "/home/bearsh",
"PATH": "/home/bearsh/ncs/toolchains/7795df4459/usr/bin:/home/bearsh/ncs/toolchains/7795df4459/usr/bin:/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin:/home/bearsh/ncs/toolchains/7795df4459/opt/bin:/home/bearsh/ncs/toolchains/7795df4459/opt/nanopb/generator-bin:/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/aarch64-zephyr-elf/bin:/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/x86_64-zephyr-elf/bin:/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/go/bin:/usr/local/go/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/go/bin:/usr/local/go/bin",
"ZEPHYR_BASE": "/home/bearsh/projects/nrf-test-project/zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk",
"PYTHONPATH": "/home/bearsh/ncs/toolchains/7795df4459/usr/local/lib/python3.8:/home/bearsh/ncs/toolchains/7795df4459/usr/local/lib/python3.8/site-packages",
"USER": "bearsh"
"inherited": {
"PATH": "/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/go/bin:/usr/local/go/bin",
"USER": "bearsh"
"toolchainPath": "/home/bearsh/ncs/toolchains/7795df4459",
"toolchainBinPath": "/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin",
"toolchainVersion": "2.5.2"
"terminal": {
"defaultProfile": null
"config": {
"topdir": "",
"toolchain": {
"path": ""
"ozonePath": "",
"applications": [
"${workspaceFolder}/application"
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"debugging": {
"flash": true,
"bindings": {},
"justMyCode": true
"deviceProvider": "",
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": null,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask"
"terminalMode": "character"
"marus25.cortex-debug": {
"variableUseNaturalFormat": true,
"liveWatchRefreshRate": "300",
"armToolchainPath": null,
"armToolchainPrefix": "arm-none-eabi",
"gdbPath": null,
"objdumpPath": null,
"JLinkGDBServerPath": null,
"openocdPath": null,
"pyocdPath": null,
"PEGDBServerPath": null,
"stutilPath": null,
"stlinkPath": null,
"stm32cubeprogrammer": null,
"enableTelemetry": false,
"dbgServerLogfile": null
"extensions": {
"internal": {
"version": "2023.11.301",
"path": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.11.301-linux-x64",
"isActive": true
"version": "2023.10.17",
"path": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-terminal-2023.10.17",
"isActive": true
"version": "2023.11.120",
"path": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2023.11.120",
"isActive": true
"version": "2023.11.64",
"path": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2023.11.64",
"isActive": true
"external": {
"marus25.cortex-debug": "1.12.1",
"ms-vscode.cpptools": "1.18.5",
"ms-vscode.js-debug": "1.86.1",
"ms-vscode.js-debug-companion": "1.1.2",
"ms-vscode.vscode-js-profile-table": "1.0.8",
"dan-c-underwood.arm": "1.7.4",
"EditorConfig.EditorConfig": "0.16.4",
"Gruntfuggly.todo-tree": "0.0.226",
"josetr.cmake-language-support-vscode": "0.0.9",
"mcu-debug.debug-tracker-vscode": "0.0.15",
"mcu-debug.memory-view": "0.0.25",
"mcu-debug.peripheral-viewer": "1.4.6",
"mcu-debug.rtos-views": "0.0.7",
"mechatroner.rainbow-csv": "3.11.0",
"MS-CEINTL.vscode-language-pack-de": "1.85.2024020709",
"ms-dotnettools.vscode-dotnet-runtime": "2.0.1",
"ms-vscode-remote.remote-ssh": "0.108.0",
"ms-vscode-remote.remote-ssh-edit": "0.86.0",
"ms-vscode.hexeditor": "1.9.13",
"ms-vscode.remote-explorer": "0.4.1",
"stkb.rewrap": "1.16.3",
"streetsidesoftware.code-spell-checker": "3.0.1",
"streetsidesoftware.code-spell-checker-swiss-german": "1.2.1",
"ZixuanWang.linkerscript": "1.0.4"
