VSCode nRF DeviceTree: out of tree board: extension does not find .dtsi in ZEPHYR_BASE
I use the nrf connect sdk together with vscode.
My application is a workspace application with the following structure:
├── application
│ ├── build
│ ├── CMakeLists.txt
│ ├── prj.conf
│ ├── README.rst
│ ├── sample.yaml
│ ├── src
│ └── west.yml
├── boards
│ └── arm
└── external
├── bootloader
├── modules
├── nrf
├── nrfxlib
├── test
├── tools
└── zephyr
I have a working build configuration with my custom board. So the zephyr build systems seems to recognize everything correctly.
Unfortunately if I open my boards .dts file, vscode does no find the included nordic/nrf52840_qiaa.dtsi file. furthermore the visual devicetree editor only shows the nodes defined in the boards .dts file but nothing from the included file from nordic.
So to my understanding, the extension does not (at least in my case) look for devicetree files in $ZEPHYR_BASE/dts/arm. If I open a board .dts file from withing $ZEPHYR_BASE, everything seems to work fine though.
"platform": {
"os": "linux",
"osVersion": "#14-Ubuntu SMP PREEMPT_DYNAMIC Tue Jan 16 08:57:02 UTC 2024",
"osKernel": "6.5.0-1013-oem",
"vscode": "1.86.1",
"electron": "27.2.3",
"node": "v18.17.1"
"system": {
"date": "2024-02-14T10:47:14.300Z",
"vscodeRoot": "/usr/share/code/resources/app",
"nrfConnectForDesktopInstalled": "unknown",
"vscodeUptime": "02:36:32",
"osUptime": "265:36:10",
"cpu": "11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz"
"workspace": {
"name": "nrf-test-project",
"workspaceFile": null,
"folders": [
"/home/bearsh/projects/nrf-test-project"
"sdks": [
"version": "v2.5.2",
"path": "/home/bearsh/ncs/v2.5.2"
"path": "/home/bearsh/projects/nrf-test-project"
"activeBuild": "/home/bearsh/projects/nrf-test-project/application/build",
"apps": [
"workspace": "/home/bearsh/projects/nrf-test-project",
"uri": "/home/bearsh/projects/nrf-test-project/application",
"buildConfigurations": [
"id": "/home/bearsh/projects/nrf-test-project/application/build",
"name": "build",
"boardId": "nina-b3_msr-a11",
"type": "Zephyr",
"isChild": false,
"isStale": false,
"taskBindings": {
"build": [],
"pristineBuild": [],
"flash": [],
"eraseAndFlash": []
"topdir": "/home/bearsh/projects/nrf-test-project",
"workspaceState": "workspace-ready",
"toolchains": [
"version": "2.5.2",
"path": "/home/bearsh/ncs/toolchains/7795df4459"
"connectedDevices": [
"serialNumber": "000504500059"
"deviceProvider": "nrfutil",
"tools": {
"/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.1",
"/opt/SEGGER/JLink/JLinkExe": "7.92k",
"/usr/local/bin/nrfjprog": "10.24.0",
"/home/bearsh/.local/bin/nrfutil": null,
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/cmake": "3.20.5",
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/west": "1.1.0",
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/python3": "3.8.2",
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/ninja": "1.9.0",
"/home/bearsh/ncs/toolchains/7795df4459/usr/bin/gperf": "3.1",
"/home/bearsh/ncs/toolchains/7795df4459/usr/bin/dtc": "1.4.7",
"/home/bearsh/ncs/toolchains/7795df4459/opt/bin/gn": "1871",
"/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin/git": "2.37.3",
"gdbPath": "/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
"nrfutil": {
"nrfutil-device": {
"version": "2.0.0",
"binPath": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.11.301-linux-x64/platform/nrfutil/bin/nrfutil-device"
"nrfutil-toolchain-manager": {
"version": "0.14.1",
"binPath": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.11.301-linux-x64/platform/nrfutil/bin/nrfutil-toolchain-manager"
"environment": {
"westEnv": {
"ELECTRON_RUN_AS_NODE": "1",
"GIT_EXEC_PATH": "/home/bearsh/ncs/toolchains/7795df4459/usr/local/libexec/git-core",
"HOME": "/home/bearsh",
"PATH": "/home/bearsh/ncs/toolchains/7795df4459/usr/bin:/home/bearsh/ncs/toolchains/7795df4459/usr/bin:/home/bearsh/ncs/toolchains/7795df4459/usr/local/bin:/home/bearsh/ncs/toolchains/7795df4459/opt/bin:/home/bearsh/ncs/toolchains/7795df4459/opt/nanopb/generator-bin:/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/aarch64-zephyr-elf/bin:/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/x86_64-zephyr-elf/bin:/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/go/bin:/usr/local/go/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/go/bin:/usr/local/go/bin",
"ZEPHYR_BASE": "/home/bearsh/projects/nrf-test-project/zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk",
"PYTHONPATH": "/home/bearsh/ncs/toolchains/7795df4459/usr/local/lib/python3.8:/home/bearsh/ncs/toolchains/7795df4459/usr/local/lib/python3.8/site-packages",
"USER": "bearsh"
"inherited": {
"PATH": "/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/home/bearsh/opt/flutter/bin:/home/bearsh/go/bin:/home/bearsh/.npm/bin:/home/bearsh/.local/bin:/home/bearsh/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/go/bin:/usr/local/go/bin",
"USER": "bearsh"
"toolchainPath": "/home/bearsh/ncs/toolchains/7795df4459",
"toolchainBinPath": "/home/bearsh/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin",
"toolchainVersion": "2.5.2"
"terminal": {
"defaultProfile": null
"config": {
"topdir": "",
"toolchain": {
"path": ""
"ozonePath": "",
"applications": [
"${workspaceFolder}/application"
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"debugging": {
"flash": true,
"bindings": {},
"justMyCode": true
"deviceProvider": "",
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": null,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask"
"terminalMode": "character"
"marus25.cortex-debug": {
"variableUseNaturalFormat": true,
"liveWatchRefreshRate": "300",
"armToolchainPath": null,
"armToolchainPrefix": "arm-none-eabi",
"gdbPath": null,
"objdumpPath": null,
"JLinkGDBServerPath": null,
"openocdPath": null,
"pyocdPath": null,
"PEGDBServerPath": null,
"stutilPath": null,
"stlinkPath": null,
"stm32cubeprogrammer": null,
"enableTelemetry": false,
"dbgServerLogfile": null
"extensions": {
"internal": {
"version": "2023.11.301",
"path": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.11.301-linux-x64",
"isActive": true
"version": "2023.10.17",
"path": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-terminal-2023.10.17",
"isActive": true
"version": "2023.11.120",
"path": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2023.11.120",
"isActive": true
"version": "2023.11.64",
"path": "/home/bearsh/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2023.11.64",
"isActive": true
"external": {
"marus25.cortex-debug": "1.12.1",
"ms-vscode.cpptools": "1.18.5",
"ms-vscode.js-debug": "1.86.1",
"ms-vscode.js-debug-companion": "1.1.2",
"ms-vscode.vscode-js-profile-table": "1.0.8",
"dan-c-underwood.arm": "1.7.4",
"EditorConfig.EditorConfig": "0.16.4",
"Gruntfuggly.todo-tree": "0.0.226",
"josetr.cmake-language-support-vscode": "0.0.9",
"mcu-debug.debug-tracker-vscode": "0.0.15",
"mcu-debug.memory-view": "0.0.25",
"mcu-debug.peripheral-viewer": "1.4.6",
"mcu-debug.rtos-views": "0.0.7",
"mechatroner.rainbow-csv": "3.11.0",
"MS-CEINTL.vscode-language-pack-de": "1.85.2024020709",
"ms-dotnettools.vscode-dotnet-runtime": "2.0.1",
"ms-vscode-remote.remote-ssh": "0.108.0",
"ms-vscode-remote.remote-ssh-edit": "0.86.0",
"ms-vscode.hexeditor": "1.9.13",
"ms-vscode.remote-explorer": "0.4.1",
"stkb.rewrap": "1.16.3",
"streetsidesoftware.code-spell-checker": "3.0.1",
"streetsidesoftware.code-spell-checker-swiss-german": "1.2.1",
"ZixuanWang.linkerscript": "1.0.4"
  • Hello all
    How can I check if my environment already has this release (v2024.2.418) ?
    I am using SDK and toolchain v2.6.1 throuhg VSCode extension and it seems my overlay is not seeing none nrf9160*.dtsi from boards.  I tried to include explicitly on my overlay with:
    #include <zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_common.dtsi>
    But build raises:
    -- Found devicetree overlay: lte.overlay
    In file included from <command-line>:
    ./lte.overlay:1:10: fatal error: zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_common.dtsi: No such file or directory
    My application is out-of-tree (one level above zephyr , nrf, etc)
