ADC negative voltage
I've already read a lot in the forum, but I'm not quite sure yet.
Is it possible to measure an AC voltage with the ADC? Normally no, but in the documentation a resistor ladder is mentioned which should allow the measurement of positive and negative voltage.
Can I use it to measure an AC voltage that oscillates around 0?
Or can I measure either positive or negative voltage, depending on how the register is set?
  • Yes, turn on both 160k bias resistors and AC couple the AC signal with a capacitor. Peak-Peak voltage must be within the VDD, typically 3 volts max
    //                        |                 nRF52840                     |
    //                        |    VDD                                       |
    //                        |     |   Option                               |
    //                        |     +-|   160k                               |
    //                        |       |<- High                               |
    //                        |     +-|   Bias                               |
    //             ||C        |     |                                        |
    //     +-------||---------O-----#------------#------#--> P0.nn SAADC     |
    //     |       ||         |     |   Option   |      |    Ref = Int       |
    //     |                  |     +-|   160k  +++     |                    |
    //     |                  |       |<- Low   | |   -----                  |
    //     @                  |     +-|   Bias  | |   -----                  |
    //     @                  |     |           +++     | 2.5pF              |
    //     @  AC              |     |            |1M0   |                    |
    //     | Pk-Pk < 3 volts  |    ===          ===    ===                   |
    //     +------------------0-----+                                        |
