Configuring nRF5340 for RF measurements
How to configure nRF5340 for RF measurements. which programs can be flashed to the device to get 100% TX and 100% RX and measure the RF parameters
  • Hi, As you can see here it does not make sense to measure both VDD_HV and VDD."
    By default, the high voltage regulator is configured to source external components from the VDD pin. To save power this feature must be disabled. For details, see High voltage mode."
    Is the device running in HV mode? Also, is this a custom board? I'm not sure that you would gain anything to measure the current consumption since if it is a custom boards you it can be hard to correlate power consumption with RX effect.
    Regards
    Runar
  • Hi Runar,
    What did you mean by custom mode I'm using a nRF5340 DK and putting it into modes like advertisement using nRF connect in V S Code.
    So my question here is at that time, which of these rails(VDD & VDD_HV) can give the chips current consumption at these modes.
    Arun
  • runsiv said:
    I was supposed  to write custom board. Since you are using the DK we have guide for current measurement here
    Regards
    Runar
  • ->I'm following this same method mentioned in the document in section "measure average current with ampere meter".
    -----> You power meter is set to what would be channel 2 while you are sending at channel 37
          channel 2 is frequency 2408 right? I'm the power meter to frequency 2402.
    ------>You are running a sweep over a single channel, I would rather use the constant carrier wave as you would with the current config only stay at channel 37 for 50ms
                Can you please guide me configure the same?
     ---->Your test setup is still a mystery to me
               I'm connecting the DK to my laptop through USB cable, flashing the "radio test" example, giving commands to the DK using Tera Term, like the log shared earlier. Connecting the external antenna(J1) to the power meter. VDD and VDD_HV points to the ammeter.
    Arun
     Connect your current measurement to P22 as stated in the link I have given you. It might be that i misunderstood, but it sounds to be like you have 1 cable attached to p22 and one to P23. The device should not be in Hv mode so I see no reason to measure there
    I'm not sure I follow, you would you measure on another channel then where you are sending?
    instead of using the start_rx_sweep, use start_rx
    Could you name the instrument? We use network or spectrum analyser when we look at RF so I just want to be sure that is not something I have overlooked here. Especially since there might be signal loss depended on the connection between the DK and the measurement instrument
    Regards
    Runar
    I'm sending Tx from channel 37(which is 2402) and trying to measure from channel 37 itself, setting frequency as 2042.
    But why you were saying I would've set channel to 2 in power meter.
    Arun
  • Hi
    start_channel
    <channel>
    Start channel for the sweep or the channel for the constant carrier (in MHz, as difference from 2400 MHz).
    If you want to send on 2402MHz you would need to use channel 2.
    Regards
    Runar
