How to configure nRF5340 for RF measurements. which programs can be flashed to the device to get 100% TX and 100% RX and measure the RF parameters
Hi Runar,
I've updated the NCS version now but I'm facing these error on building an example,
this issue is facing in Both NCS versions, v2.3 and v2.5.2.
please help me resolve this.
Arun
Hi Runar,
Here the documentation is discussing on how to carry out the measurement right?
I'm asking you which number to be taken into consideration as the chips current consumption in these different states.
Arun
Hi
just so that we are on the same page. You are trying to build the peripheral_lbs sample now?
Could you update the toolchain so it aligns with the SDK version, do a pristine build and if it fails, post the log output. Just copy paste the log from the terminal and go back here, insert -> code and past it
Regards
Runar
yes I'm trying to build peripheral_lbs sample.
there is no toolchain of v2.5.2 available, I tried downloading tool chain v2.4.3 but it is failing to update.
what do you mean by printine build?
to create the project again?
Reagrds,
Arun
That sounds very strange. You should be able to see multiple newer toolchain versions then 2.4.3, could you post the error message you get?
If you select the round arrow you do a pristine build and rebuild the entire project, however it is not worth doing until the toolchain and sdk version is aligned.
Regards
Runar
