How to configure nRF5340 for RF measurements. which programs can be flashed to the device to get 100% TX and 100% RX and measure the RF parameters
I'm a bit unsure of what you mean. if you want to measure the current draw of the DK you should follow the guide so your setup is correct. Since the DK has a extra circuits outside the nrf5340 you need to have the correct setup so you don't measure the current draw of the whole DK. As for numbers, you could for example compare your numbers to the online power profiler tool
Regards
Runar
Hi Runar,
Other than measuring the current consumption using Online power profile tool, is there anyway I can measure the current consumed by nRF5340 at these states?
The tool chain issue is solved on setting " set default toolchain".
can you also guide me in achieving the below states?
1, sleep
2, BLE Advertisement
3, BLE Scan
4,BLE Connected
5,active TX and RX
Arun
Good to hear that is fixed
I don't think we have a samples that covers all that you are asking for. But we do have a BLE power profiling sample
If you have more questions regarding optimizing for current I would suggest to create a new ticket as we try to keep it to one topic for each thread
Regards
Runar
I'm not asking one example to execute all these states but all the examples that can put the device in these states.
Arun
We don't have any list of which examples enters the different states. I would recommend to either use the mentioned sample as it is made for power profiling or create a sample that suits your needs. If I misunderstood you, please try to reword the question.
Regards
Runar
